Asphalt Shingles On Bow Window-Hip Caps??
Old 08-14-2006, 03:56 PM   #1
warrenc's Avatar
I'm in the process of roofing (asphalt) a multiple hip roof over a bow window and have 5 hips converging at the peak, where they join an existing gable ridge. How do I finish the top with the hip caps. I expect the last 2-3 caps will start overlapping and will need to deal with this along with the last cap that ties in with the existing roof. Sorry if I'm not making this clear.
warrenc is offline
Old 08-14-2006, 06:08 PM   #2
Tom R's Avatar
Re: Asphalt Shingles On Bow Window-Hip Caps??
Man, - - that is a tough one.
Sure wasn't designed with the finish in mind.
Can't say I really know the answer, - - but seems like the best you can do is 'butt-cut' them as they start running into each other, - - and as you get to the top layers, - - make them lap as many 'hips' as possible to keep the number of layers from piling up so sky-high.
Come to think of it, - - I think when I got to within about say, - - 4 rows from the top, I'd 'lay-in' a flashing (system) 'over and above' (and across), - - then I could 'cheat' the layers above that without worrying about creating leaks.
Maybe someone else knows better, - - that's the best I got . . .
Tom R is online now
Old 08-14-2006, 06:25 PM   #3
Moderator
Double-A's Avatar
Sounds like a job for Double R-D.
River Rat Dad will be along, I'm sure. I bet he's seen one or two of these critters in his time.
New York Times, July 20, 2006
Double-A is offline
Old 08-14-2006, 08:40 PM   #4
River Rat Dad's Avatar
Trade: Roofing, siding, framing
Run all hips up at the same time. As they meet at the top the three in the middle will "disappear" under the two on the outside. As the two on the outside cover them stop the middle ones at that point. it will make sense when you see all 5 come together....
River Rat Dad is offline
Old 08-14-2006, 08:49 PM   #5
Lemme rephrase... you don't actually have to take all 5 up at the same time. Just stop 2 feet short of the top on each till all 5 are there. Then the middle linebacker should dissapear under the two outside linebackers when they get within 6" of each other. then the two outside linebackers will disappear under the cornerbacks when they get within 6". It will all make sense when you get there...
Old 08-14-2006, 10:04 PM   #6
Tom R's Avatar
Ya, - - but ain't part of his question about the big pileup after the play is over and the whistle is blown??
Tom R is online now
Old 08-14-2006, 11:24 PM   #7
warrenc's Avatar
I'm in trouble. I don't play football . . .
I'll give it try tomorrow. Thanks for the help.
Warren
warrenc is offline
Old 08-15-2006, 05:43 PM   #8
RooferJim's Avatar
Trade: roofing
finish it off with a piece of copper or lead. lay it in dry first and make sure it looks good.
RooferJim
www.jbennetteroofing.com
"never underestimate the intellegence of a rain drop"
RooferJim is offline
Replacement Window Question? Max10 Windows, Siding and Doors 34 02-27-2010 06:15 PM
Owens corning a solid strip of tar nolo Roofing 26 01-29-2008 01:25 AM
Reusing asphalt shingles AbeBarker Roofing 8 04-19-2007 08:16 PM
Touching up Light Asphalt Shingles slickshift Painting & Finish Work 11 08-09-2006 09:58 PM
metal vs. asphalt shingles jlandry Roofing 2 12-18-2005 09:54 PM
