Architectural Shingle Repair ?
Old 08-10-2017, 06:38 PM   #1
We Fix Houses's Avatar
Trade: Remodeling / Carpentry
Rewards Points: 1,900
Did my first architectural shingle repair today while repl a leaking vent cap.
Three tab repair...no problem. Flat bar, upper course, sealant...got all that. These threw me for a while this morning.
Kind of say yay, or nay to the method I came up with...and add comments.
Since these are laminated, no vanes you can leave a partial shingle -- cutting it back leaving a sq end as long as it's min 6" from the next butt joint ?? Yes ?
Then just carry on, cut back as needed -- placing new shingles over butt joints, etc, etc ?
Steve
We Fix Houses is offline
Old 08-10-2017, 09:12 PM   #2
Shingler extraordinaire
A&E Exteriors's Avatar
Trade: Roofing, Framing, siding, decks
Rewards Points: 10,568
Re: Architectural Shingle Repair ?
Petty much the same process as a 3 tab repair. bonus being you can cut a shingle wherever and not worry about keyways
A&E Exteriors is online now
Old 08-11-2017, 02:17 AM   #3
Mordekyle's Avatar
Rewards Points: 2,934
A cool trick I learned is you can replace the rubber boot on Oatey brand pipe jacks. Leave the galvanized flashing, but change out the donut.
I still charge nearly the same.
Mordekyle is online now
Old 08-11-2017, 06:52 AM   #4
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 1,609
You don't even have to change it, just slide on a new collar. If that's the problem.
https://www.menards.com/main/plumbin...1181161&ipos=2
Big Johnson is offline
Old 08-11-2017, 09:49 AM   #5
Thanks for the input. This was a 12" x 16" cap for bath exhaust. Had several nails into the top part. Had to repl about 6 shingles.
Steve
Old 08-12-2017, 07:08 AM   #6
Gutter Hanger
CrescentGutter's Avatar
Trade: Seamless gutters
Rewards Points: 593
Sounds like you sorted it out just fine. I had to do something similar to my own pellet stove chimney. The installers simply placed the boot/flashing on top of the architectural shingles and siliconed the snot out of it. Of course it didn't take long for it to begin leaking.
Peeled up several shingles with a flat bar, slid boot down to the deck and reshingled & tarred around the boot as necessary. No problems several years later.
Time loves to be wasted. From that waste there is no salvage. - Henry Ford
CrescentGutter is offline
foundation repair question ctcarpenter Masonry 26 06-25-2012 06:25 PM
Need to hire full time repair man/woman in phoenix arizona, now!! Phoenix8 Help Wanted or Looking For Work 24 05-16-2012 05:39 PM
Tool repair - small items Hmbldr Tools & Equipment 11 05-10-2012 07:55 PM
can I repair minor chips at shingle edges? tersh Roofing 6 03-03-2010 04:25 PM
Can anyone identify this architectural shingle color? eModPro Roofing 5 09-23-2009 12:31 PM
