Aluminum Coil Question
Old 03-11-2009, 06:05 PM   #1
Interior Remodeling
Eric K's Avatar
Trade: Interior Remodeling
My grandparents had a "sun porch" installed about 5 years ago, on the 4x4 wolimized post they wrapped them with aluminum coil stock (fascia material). At the bottom of the one post the aluminum is almost rotting away. Looks like rust, but its completely white. I can pick it off and crumble it. Its only up off the sill where the 4x4 rests 4" up. The rest is fine. Is this a chemical reaction to the wolimized wood or cement ledge? Any help is appricated.
Eric K is offline
Old 03-11-2009, 06:11 PM   #2
KemoSabe
loneframer's Avatar
Re: Aluminum Coil Question
It is probably electrolosis, I'm not an authority on the subject but I've been told that is the case, more likely due to contact with a galvanized connector. I have also read on the aluminum coil box that it should not be used over treated lumber.
loneframer is offline
Old 03-11-2009, 06:28 PM   #3
Capra aegagrus
Tinstaafl's Avatar
Aluminum should not be used in direct contact with this wood, unless an adequate physical barrier separates the aluminum from the wood or the manufacturer ensures the performance of the aluminum product.
http://www.archchemicals.com/Fed/WOL...e/hardware.htm
Tinstaafl is online now
Old 03-11-2009, 08:03 PM   #4
Interior Remodeling
Eric K's Avatar
This is what I suspected. Thanks fellas.
Eric K is offline
Old 03-24-2009, 12:12 PM   #5
ARF housework's Avatar
Trade: roofs
i need help how much are metal roofs going for
ARF housework is offline
Old 03-24-2009, 01:12 PM   #6
Crash Test Dummy
ChainsawCharlie's Avatar
Trade: Landscaping
That depends on how far they are going.
ChainsawCharlie is offline
Radiant heat pipe install question im4snow HVAC 6 03-09-2011 07:28 AM
Question for GC re: rough/final cleans britanie General Discussion 6 06-07-2009 07:42 PM
Cost Plus Question randybelk@comca Business 16 09-11-2008 10:09 PM
