Aerial Roofing Photos And Specs
Old 09-17-2009, 08:00 PM   #1
Insuranceclaims
Guest
Insuranceclaims's Avatar
Posts: n/a
While many of you roofers may be familiar with this vendor, I thought I would list the link, in case someone may find it useful.
Eagleview Technolgies. Oops, I can't list a link yet. So search for this company on google or the first name.com
I am an insurance restorer and former adjuster. This company, last Spring, teamed with Xactimate, an insurance estimating software, to provide aerial roofing photos and drawings/specs.
I hope it helps.
Mark
Old 09-18-2009, 09:10 AM   #2
Grumpy
Guest
Grumpy's Avatar
Posts: n/a
Re: Aerial Roofing Photos And Specs
I use google maps in combination with a new constrution take off tool I recently aquired. I've tested it and it's very accurate, no substitution for an onsite inspection, but great for double checking if you're second guessing yourself.
Old 09-19-2009, 12:41 AM   #3
Steep Team
Guest
Steep Team's Avatar
Posts: n/a
Grumpy
Please expand on what you are using.
Old 09-21-2009, 03:45 PM   #4
Grumpy
Guest
Grumpy's Avatar
Posts: n/a
www.thebluebook.com has a free software available to their members called vu360. I've actually been bidding new construction which I usually just toss away ITB's since I got this software. After using it for a few days I decided to import a google map image and see how it worked and it worked well.
So the steps are go to google maps and capture the screen making sure to get the key. Then calibrate the measurement tool in vu360 to the key on the google map which is like 25' or something. You can really do alot like get linear measurements, surface areas, perimiters, even volume. All with a point and click. To be honest the program is so powerful I am suprised that it's free.
