Adding Pitch To A Flat Roof.
Old 03-07-2008, 06:57 PM   #1
PAPERSTREETROOFING.COM
PAPERSTREET's Avatar
Trade: roofing
Bidding on re-roofing a motel. existing roof is flat with numerous pipe extrusions(close to 200) Roughly 2 for every square. Contractor is adding trusses to bring pitch to 6/12. We will install metal after trusses/decking are finished. My question is this: Do all pipe protrusions have to be lengthened and put through new roof? Would adequate ventilation in the metal roof allow us not to do this? Anyone dealt with this kind of thing before? Thanks for the help.
Noah
www.paperstreetroofing.com
Quality Metal Roofing
PAPERSTREET is offline
Old 03-07-2008, 07:04 PM   #2
Ed the Roofer's Avatar
Trade: Roofing Contractor
Re: Adding Pitch To A Flat Roof.
Code should address that situation. I would imagine, that the gasseous expulsion from storm sewers and the carbon dioxide from heat vents would eliminate that option. Talk to an HVAC/Plumbing contractor for that specific advice.
Maybe some can be tied together, to reduce the amount of roof top protrusions.
2 per square, what a pain in the butt!
I know that heat vents have to extend above the peak of the roof in our local codes.
Ed
Ed the Roofer is offline
Old 03-07-2008, 07:13 PM   #3
Trade: roofing
Yeah, 12 inches is our code here for all PVC obtrusions. I considered having them tied together, I just hope they can get 8-10 into 1!
Noah
Old 03-07-2008, 08:38 PM   #4
Roofing and Architectural
Renegade's Avatar
Trade: Roofing and Architectural Metals
100 to 1 would be even better. lol
Done what your doing a time or two. Always extended everything up through the new roof, am sure that would pretty much be a universal code. The majority of them aren't a major hassle to do. Like they said, try having them tie as many together as possible, should have plenty of room to work under that 6/12.
Renegade is offline
Adding Story over flat roof residence gust0261 Remodeling 7 11-10-2007 04:52 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Flat roof over garage leaking under exterior walk out door IHI Roofing 18 05-30-2006 10:28 PM
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 21 01-16-2006 02:36 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
