3 Seasons Room Keeps Leaking - Roofing - Contractor Talk
Old 02-25-2011, 05:00 PM   #1
contractorjay's Avatar
Trade: Roofing Siding Gutters Windows
Rewards Points: 250
we re-roofed and re-sided a house with a 3 seasons room attached about 3 years ago. the first year, the friggin thing keeps leaking. we step flashed the entire thing and it still kept leaking. the second time we went back, we applied ice & water over the step flashing and under the shingles. the leaking stopped up until this winter's major snow storm. the snow got stacked real high and i'm guessing it permeated through the siding and behind the step flashing. should i go back and raise the ice & water a few feet higher on the wall?
contractorjay is offline
Old 02-25-2011, 06:36 PM   #2
Tom Struble's Avatar
Trade: siding
Rewards Points: 20
Re: 3 Seasons Room Keeps Leaking
sounds like its leaking higher up on the wall,any windows up there?
Tom Struble is offline
Old 02-25-2011, 06:44 PM   #3
Rewards Points: 250
no windows. the second time we we repaired it, we took a hose and sprayed it all over and no leak occurred.
Old 02-25-2011, 07:03 PM   #4
Trade: siding
Rewards Points: 20
hmm...yea those leaks can be a nightmare sometimes
what kind of siding you dealing with? is there a wrb under it?if there is does it overlap the step flashing? any pics?
Old 02-25-2011, 07:42 PM   #5
wannabe
WNYcarpenter's Avatar
Trade: carpentry
Rewards Points: 1,000
If it's a three season room...what season do they not use it?
Sorry If I'm not helping with the cure, but if the area is supposed to be turned off in winter it should be thermally isolated from the main house and remain cold.
IMO, if the room is heated in winter and the heat loss causes ice dams and leaks it then becomes a four season room and needs to be treated that way.
Otherwise, there are more serious issues.
I can see the shared wall not being insulated when it is to be considered an outside wall.
WNYcarpenter is offline
Old 02-25-2011, 07:47 PM   #6
Rewards Points: 250
this is actually the first time hearing 3 seasons room needing to be isolated. most homeowners just do not find that it makes sense leaking would occur once their new roof is put on. they've had leak issues prior to our services and we did our best to put attention during the install. hopefully it wont leak again, otherwise im going to karate chop someone. hard.
Old 02-25-2011, 07:54 PM   #7
tinner666's Avatar
If you put storm shield on top of the step flashing, you really created a huge leak problem. On top of whatever other issues you had.
Frank Slate Roof Repairs, Richmond, Va.
tinner666 is offline
Old 02-25-2011, 07:54 PM   #8
Rewards Points: 250
i had an install completed on a house without any soffits this past summer. it is an older home and it pretty much is just wall meet roof type of deal. new windows, new siding with dow foam boards, new roof, and new gutters. during the winter they called and said the gutter is leaking water. i'm like wtf? how is that possible since it should all be frozen. it turns out the house was over insulated. the attic was getting too warm thus melting the snow off the roof. when the melted water traveled go the gutters (away from the warm attic) it froze. this continued cycle allow the ice to back up under the shingles.
the roof has continuous ridge vents. out of the 3 gables, 2 are vented. we vented the third gable and it seems like the issue is resolved. i told them they need attic insulation to stop warm air from traveling into their attic. they didnt believe us and still call us bs.
Old 02-25-2011, 07:55 PM   #9
Rewards Points: 250
then what do you suggest? my initial concept is that, it will create a barrier. just like how the valley should be applied with ice & water shield.
Old 02-25-2011, 08:00 PM   #10
tinner666's Avatar
Pictures would be nice. Storm shield goes under the roof and step flashing, then up the wall. The steps get weaved into the shingles normally.
Old 02-25-2011, 08:09 PM   #11
wannabe
Trade: carpentry
Originally Posted by contractorjay View Post
i
I can't explain the science, but gable vents counteract with the ridge vent....you should seal the gable vents with a continuous ridge vent....
Old 02-25-2011, 08:10 PM   #12
Rewards Points: 250
really? even though the problems solved?
Old 02-25-2011, 08:12 PM   #13
tinner666's Avatar
What's the pitch? I've doen a couple of low pitch ones by using dimensionals with a 6"+ dutch-lap. They've been under 12" to 24" snow with no issues. Going on 12 years for some of them. Like this.
The builder's own house. He insisted on the shingles. Elks, 4" exposure, dutch-lapped. 2 valleys and a dead end hip.
3 seasons room keeps leaking-low-pitch1.jpg   3 seasons room keeps leaking-low-pitch2.jpg   3 seasons room keeps leaking-low-pitch3.jpg   3 seasons room keeps leaking-low-pitch4.jpg   3 seasons room keeps leaking-low-pitch5.jpg
The Following User Says Thank You to tinner666 For This Useful Post:
Tom Struble (02-26-2011)
Old 02-25-2011, 08:17 PM   #14
wannabe
Trade: carpentry
A three season room is essentially a glorified porch/sunroom. Looking from the inside out, the shared walls are exterior walls.
Old 02-25-2011, 08:18 PM   #15
Rewards Points: 250
i think the pitch was like a 4 or 5/12. cant remember exactly. the step flashing was put on after we installed ice & water. looks like a mess i know.
Old 02-25-2011, 08:19 PM   #16
tinner666's Avatar
Any other pix?
Old 02-25-2011, 08:20 PM   #17
Rewards Points: 250
Any other pix?
just this one. there is where the seasons room meets the wall of the house, pretty much.
Old 02-25-2011, 08:21 PM   #18
Jeff
jkfox624's Avatar
Trade: master turd burglar
Rewards Points: 502
If im not mistaken doesnt it created a negative pressure affect that can pull air through the ridge vent bringing moisture/rain with it?
jkfox624 is offline
Old 02-25-2011, 08:23 PM   #19
tinner666's Avatar
Is that a sag in the roof? Or optical illusion?
Old 02-25-2011, 08:24 PM   #20
Rewards Points: 250
i would have to say shadowing. no sagging on my roofs.
The Following User Says Thank You to contractorjay For This Useful Post:
tinner666 (02-25-2011)
brick chimney leaking? dave_dj1 Masonry 7 04-03-2010 04:33 PM
Goodman Units are leaking freon BiggersJunior HVAC 24 01-21-2010 07:19 AM
What brought mold to this room and how to clean it? Eric S General Discussion 10 09-18-2009 10:52 PM
Whats up with the CHAT ROOM? MZ-HANDYMAN General Discussion 9 08-06-2009 10:55 AM
Room to room fan Larry007 HVAC 5 11-24-2006 12:07 PM
