3/12 Pitch Help...
Old 07-14-2007, 10:24 PM   #1
ecooke21's Avatar
Trade: Rremodeling..finish carpentry, etc
3/12 Pitch Help...
I dont do much roofing. but I need to do my dormer roof.. I have a 3/12 pitch.. can I use regular architectural shingles? or do I need a special roofing material? rubber? tar? rolled?
sorry if its a rookie question..
BTW, I live in rhode island.. winters can get rough.. and we have a decent amount of rain..
A bunch of little rabbit turds banding together usually just makes one bigger piece of crap. -Mike Finley
ecooke21 is offline
Old 07-15-2007, 12:53 AM   #2
Expert Roofer
theroofinggod's Avatar
Trade: ROOFING/HOME IMPROVEMENTS-WINDOWS/SIDING/GUTTERING/COPPER WORK,ETC
Send a message via MSN to theroofinggod Send a message via Yahoo to theroofinggod
Re: 3/12 Pitch Help...
3 ON 12 IS ON THE BORDERLINE,you can use entire ice shield w/good ventilation,or install 30# like S.I.S.,Sorry a little more than double coverage w/the sucessive laps 17-18"apart-you`ll be ok w/30 yr architecturals,or 3-tabs-the 3-tabs will lay flatter
Last edited by theroofinggod; 07-15-2007 at 12:54 AM. Reason: extended explanation
theroofinggod is offline
Old 07-15-2007, 07:18 PM   #3
Bah Humbug!
Grumpy's Avatar
Why use architecturals on a roof that can't be seen such as a dormer? 3/12 is border line, I'd use modified bitumen for sure. Look into the self adhering kind so you don't burn down the house.
Grumpy is offline
Old 07-15-2007, 11:59 PM   #4
Expert Roofer
you get a longer warranty out of the shingle applications,and depending on the lay of the property you may see the roof,Iuse theself adhered sbs`s for 2 on 12 +less pitches
Minimum Pitch for Metal Roofing jproffer Roofing 39 08-22-2011 09:45 AM
How to fiqure roof pitch? JPV123 Roofing 16 03-25-2011 03:36 PM
What is the lowest pitch roof everyone is comfortable with putting in a skylight? mikeybobo Roofing 10 03-03-2007 11:34 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
