Trade: Residential Construction
1:12 Pitch Roof And Water Pooling
I have modern house I am working on with a 1:12 pitch roof. The roof is a commercial grade torch down that does not leak. I have noticed after a rain that there is some areas in which water pools less and a 1/8 inch by 3 feet in diameter. 99.99999999% of the water drains out but because the slope isn't perfect or high pitched, there is some left over water. The left over water evaporates in a day.
I have talked to my roofer and he says that because of the pitch of the roof not every single drop of water is going drain. I want to get this straightened out with repairs if necesssary before I give him his final check. Anyone have any advice? If the roof doesn't leak, is there any concern? Home inspectors have complained about this before, but inspectors I have seen all complain about something - that is their job. |
#2 | |
It's all about the Avatar
Trade: I have no face!
Re: 1:12 Pitch Roof And Water PoolingQuote:
According to GAF and the other manufacturers, water that evaporates within 48 hours does NOT constitute standing water. Mod-Bit is 4mm thick and each lap will be 8mm thick. That will create a lot of 1/8" pools of water. a 2/12 slope would have been nicer.
Are all the seams sealed? Are the walls done properly? Any fishmouths? These will be your concerns.
Frank Slate Roof Repairs, Richmond, Va. |
#4 | |
It would likely fall back on my framer and/or truss company but it is probably not worth it if GAF says standing has to be around longer than 48 hours.
Thanks for your input! Quote:
