#21 | |
I used to think so.......
Re: Zip System Sheathing, Anybody Using It?Quote:
While the Zip plywood is still stacked and banded, I sprayed the edges with aerosol spray adhesive. It worked out nice. Now I do that with all my plywood that might be exposed to rain for any length of time. |
#22 | |
The top was exposed fir post and pine liner - I only papered that because it wasn't Zip Wall plywood. And it was an inch past the lower section. (Lower span 16'-0" - add-on sunroom span 16'-2") All kinds of fun to make that work out right. Whenever you get to "do" a Lindal Cedar Home, most of the lumber is provided in the package. The lower space was NIC in their package so Zip wall was used. So far I have not Tyvek'd over Zip Wall stuff. Like the garage I am adding to. The existing wall got the wrap - the upper is good to go. I just used the Zip tape to tape along the top edge of the Tyvek to keep any condensed moisture from getting behind the wrap.
#23 |
Looks good loneframer. First time I've seen this stuff. Can't find anything about pricing though.
How does it compare to 1/2" osb + 15# felt? |
#24 | |
KemoSabe
#25 |
KemoSabe
Re: Zip System Sheathing, Anybody Using It? |
#26 |
KemoSabe
#27 |
KemoSabe
#28 | |
KemoSabe
#29 | |
Trade: little bit of this and that
#30 | |
I have worked on an 8:12 zip roof in the rain doing fascia. It does feel grippier (until you hit the tape)
#31 |
so it's at least double the cost of osb and tyvek, what's the advantage over tyvek?
#32 |
Trade: contractor
sounds heavy to me
#33 |
Been looking at it, pricey, but may be worth it, i have a little problem with the swelling and particle board core. Is it heavy to work with? G
#34 |
So did you put felt over this stuff for a shingle application with a 3:12? Or do you trust it that much
Democracy is two wolves and a lamb deciding what's for dinner. Liberty is a well-armed lamb contesting the vote. |
#35 | |
KemoSabe
I have pushed my share of each up the side of this building. |
#36 | |
Grand Rapids Remodeling
![]() www.phbconstruction.com Last edited by Paulie; 11-16-2009 at 05:20 PM. |
#37 | |
KemoSabe
![]() ![]() BTW, I'm not that young and not nearly as strong as I was 20 years ago. |
#38 | |
Trade: framing/remodeling
#39 | |
KemoSabe
Damn, I hate getting old.
#40 |
wannabe
Trade: carpentry
Nice work Wallmax! Sure makes for a nice, crisp looking shell.
"I knew I lost my wallet as soon as I threw my pants over the fence". -'lil jarhead bro when asking for a wire transfer... |
| Unique project - mobile CCTV system | mobilecam | Low Voltage | 14 | 10-19-2009 08:22 PM |
| Frost on underside of roof sheathing | ApexCS | Remodeling | 5 | 01-15-2009 01:55 PM |
| Styrafoam wall system? | mhillis | General Discussion | 6 | 10-31-2008 06:58 AM |
| System Bonding Jumper vs. Main Bonding Jumper | Mark Twenhafel | NEC Discussion | 3 | 02-09-2008 06:15 PM |
| Systems Development List | Gordo | Business | 19 | 01-08-2007 07:28 PM |
