Young Trees
Old 03-14-2014, 10:26 PM   #1
Don
rotarex's Avatar
Trade: Renovator/ Builder
Rewards Points: 508
Young Trees
so i just finished framing 2 basements and 1 laundry room over a 4 months period. now i haven't done any framing of interior construction for over 2 years
Usually when i frame walls i use blocking to keep the wood from twisting, but i see everyone does without, so i figure ill do it also, now all my wood used were hand pick and straight and with what ever crown on 1 side.
after the walls was framed, we went to another job to get that started for about 2 weeks gone, (this was for all 3 framing jobs)
we came back to Drywall and finish only to find some of the biggest crowns happening. and the crowns didnt happen on 1 side but both front and back. so it looked like a bunch of idiots framed the wall, now after drywall went on the wall waved.
in the 10 years i been doing this i have never seen wood do this or this bad.
should i just sticker the wood in the basement (strapped) for about 2 weeks before framing, to avoid this?
Custom Decks
Custom aquarium all salt water
Renovation
next on my list............planting trees for all those material i used
rotarex is offline
Old 03-14-2014, 10:48 PM   #2
ubcguy89's Avatar
Trade: carpenter/ interior systems
Rewards Points: 742
Re: Young Trees
Use metal studs... Problem solved! Your walls will be dead nuts straight, and if your just doing partitions you can use 25g which when bought at a commercial supplier it's comparable to wood
ubcguy89 is offline
Old 03-14-2014, 10:54 PM   #3
Don
rotarex's Avatar
Rewards Points: 508
Re: Young Trees
I usually only build bulkheads with steel, but with the walls the cost on everything goes up, electrical, plumbing, and labour time.
who knows might have to evolve that way
Custom Decks
Renovation
rotarex is offline
Old 03-15-2014, 10:21 AM   #4
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
Re: Young Trees
Was it all the studs or a few here and there? If it was the majority I'd say it was a bad bundle you got if it's a few I've had this happen a couple times. I take my saw cut it in the middle about half way through the 3 1/2 side and sister it up with a straighter stud.
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
Old 03-15-2014, 05:42 PM   #5
Don
rotarex's Avatar
Rewards Points: 508
Re: Young Trees
Id say it was more than just a few. and on 3 different jobs and 3 different suppliers. usually i expect a twist here and there but this was crown which i never seen before like this. i know the wood is young. so im thinking acclimate it before i start
Custom Decks
Renovation
rotarex is offline
Old 03-16-2014, 10:32 AM   #6
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: Young Trees
It's hard to say if yours are any worse than what we have to deal with as all our material in "sun dried" and moves at will to some degree.
The better contractors that I work with do what's called "paper and plane" prior to cover. This a combination of using an electric plane to remove a crown and applying card board strips on the reverse side to build out bow. The strips are about 1/16" thick x 1 1/2" wide and are made just for this.
This takes quite a bit of time but worth the effort if you are selling a quality product. Smooth wall looks so much better.
Gus Dering is offline
Old 03-16-2014, 05:14 PM   #7
Don
rotarex's Avatar
Rewards Points: 508
Re: Young Trees
Thanks Gus. I was thinking the same thing.
But along the lines of, leaving the wood to acclimate in the basement for 2 weeks, then plain the minor crowns.
But honestly, how customers are, they wanna see action, and not watch wood dry haha.
they will call your phone till it lights on fire once you start a job and don't show up for 2 weeks, even if its in writing.
But this is something i am going to try and ill give my results if i remember. im sure this topic will come up again
Custom Decks
Renovation
rotarex is offline
Old 03-16-2014, 05:20 PM   #8
txgencon's Avatar
Rewards Points: 384
Re: Young Trees
Yellow pine will do it almost every time. I doubt that's what you have. I'm pretty sure YP is a southern thing. It pains me to see amateurs loading them up at the box stores because they're cheaper. I think all they're good for is for making forming stakes.
I used to think a lot of the people I encountered were stupid - then I realized how much I was overestimating them.
txgencon is offline
Old 03-17-2014, 01:52 PM   #9
Joey17's Avatar
Re: Young Trees
We always straighten our walls before the drywall is hung. Usually using a long straight edge and cutting the bowed studs and use shims to straighten them back out.
Joey17 is offline
Old 03-17-2014, 03:34 PM   #10
TimelessQuality's Avatar
Trade: GC/Remodeling
Rewards Points: 1,730
Re: Young Trees
If you know there'll be a delay, maybe put a temp stiffback on the backside to hold the plane as they acclimate...
-Steve
TimelessQuality is offline
Old 03-17-2014, 03:44 PM   #11
bodean614's Avatar
Trade: Carpentry/cabinetry/ estimating
Rewards Points: 91
Re: Young Trees
5/8 drywall would help with this. But always straighten before Dw.
bodean614 is offline
Ash Trees - Treating for Emerald Ash Borer artinall Landscaping 15 01-17-2014 07:34 PM
Dam Trees txgencon Excavation & Site Work 3 07-20-2012 03:53 PM
dealing w/ city/state re: removal of trees AustinDB Landscaping 4 03-22-2009 10:54 PM
