Trade: Carpentry & Remodeling
Window & Door Schedule
I have yet to see a decent window and door schedule. The Architect plots the centers of the openings and thats it! On the Elevations there may sometimes be a window size ( 3057) And a note describing the type(ex. Pella). But i still have to look in the Pella book to find every R.O.Or the window salesman will give us the takeoff sheet with all the windows and R.O.'s and i find where they go plot #'s he has done. Is this the normal way of doing things for you guys?? Or is this Architect Lazy?
Do what you would do, as if i won't Do anything after you Did It! |
Motorboatin' son of a ...
Re: Window & Door Schedule
There should be a schedule on the plans that call out the door and window sizes. Example: 3'0" x 6'8" door. Frame the opening two inches wider and the header height should be 82".
Yea that's fine for a door,and i do know header hts. But we often have combo units and the such. And like i mentioned ,sometimes, we have the actual size. Not always. And i hope you dont add 2" all around for your windows cause your nailing flange will barely be catching, at least on the windows we use most of the time. And there is never a schedule, that was kind of why i posted.
Do what you would do, as if i won't Do anything after you Did It! Last edited by D.Foster; 01-03-2009 at 11:11 AM. |
#4 | |
Re: Window & Door ScheduleQuote:
#5 | |
not all, but sometimes, plans are drawn like that because it is not known the brand of door or windows that will be used. Leaving room for variations. This should cause the one who is building the plans to ask what brand will be installed. Sometimes a builder will request they be left out if the plans will be used over & over to allow for product changing as desired. And sometimes it is because, as with any of us, a H/O ask where to cut cost, this is one place the Arch can safely cut cost. Other times, I just do not know why!!!
Proud to help make a house your Home Never judge another by one's own intelligence |
#6 | |
#7 | |
always building
Trade: general constructiion
Hey D Just my 2 cents but i like to use the CYA approach when it comes to plans. Cuz we all know that just because it says so on the plans doesn't mean its correct.
in the case of windows especially. "we had no idea driveways cost that much.. we had to downgrade on the windows..i'm sure that you got the memo!!! "or "we got a smokin deal on the flooring so we upgraded the windows...i'm sure you got the memo right??? what im getting at is the best tool in your belt is communication. especially when it comes to those self evident questions that don't need to be asked. ask'em and ask'em again cuz nobody makes a livin with there catspaw. pick it up once put it where it goes. good luck in you future
#9 | |
| estimating guide for windows? | Grumpy | Windows, Siding and Doors | 20 | 11-26-2010 08:18 PM |
| Replacement Window Question? | Max10 | Windows, Siding and Doors | 34 | 02-27-2010 06:15 PM |
| Window insida Tile Shower | orson | Remodeling | 13 | 12-24-2008 10:45 PM |
| Reno Window Screw Up | Bummie | Windows, Siding and Doors | 15 | 12-22-2008 10:33 PM |
| Window Sub Files Bankruptcy-Warranty Issues | remodel chick | Windows, Siding and Doors | 12 | 11-23-2008 10:11 PM |
