Trade: Engineer & Ret. GC
What's Your Preferred Methods For Exposed Rafter Tails?
What do you do when you want to see the deck underside as v-groove planking when you look up?
How about getting enough thickness of deck for shingle nails not to poke through? I cannot count on the roofer to remember to bring, and actually use, short nails. Saw the rafters? Sister on falsies, dropped? Build up at the edge, then create a taper with wood shingles on top of the deck above the lip? Tell us something we don't know. |
#2 | |
Re: What's Your Preferred Methods For Exposed Rafter Tails?Quote:
I lay the carsiding on the rafters then deck with 5/8" so that roofing nails don't penetrate. Haven't had anyone ask for open soffits on their house.
We used 1/2" ccx plugged and you'd get an occasional nail poke through. Whoever hires the roofer is responsible for telling the roofer to use shorter nails or angle them slightly.
Trade: Build, Remodel, Roofing, Siding etc...
We do the same as above. Install whatever it is that will be exposed, then install 1/2" CDX staggered seam over that. We still use 1" roofing nails to ensure no penetrations are made through on the interior side. It has to be a joint effort on both parties, the carpenter/framer and the roofers. If you are worried about them using nails that are too long, buy a box of one inch roofers for them, and make sure you are there waiting for them when they do it to advise them on this.
Spencer |
We have only done it using false tails sistered alongside either rafters or trusses, with the tails dropped about 5/8" from plane to accommodate the either square or v-groove t&g pine planking. We go 5/8 for all roof sheathing, and that goes over, so our nail base is 1-1/4.
About like shown here in this pic sequence (not mine, we don't paint much here, all stain). http://imageevent.com/meadowview/job...sedraftertails I was hoping to learn something new. |
Lots of work, so that it looks
like nobody did anything.
#7 | |
BLDG Inspector, G.C
Trade: BLDG Inspector, G.C
Yes definitly. If you want the job done right have you or someone you trust there to make sure. |
Re: What's Your Preferred Methods For Exposed Rafter Tails?![]() Train station, Middlebury, VT Interesting tails from about 1885. How about doing the scab-on tails dropped so as to then use 1-1/2" v-groove t&g, the drop set so the t&g planes with the sheathing, above. No double sheathing at overhang, no problem with nails, lotsa nice beef for pinning on that little teensie fascia you're going to do with deco tails like these. Last edited by UpNorth; 09-24-2009 at 09:57 PM. |
I just use 1/2" LP siding board laid upside down. Just remind the roofer how much fun it is to clip nails and caulk each hole.
Official CT Greeter!
Trade: General Construction
never had the request
"Your problem does not constitute an emergency on my part"
Trade: siding/windows
This porch was just built last week, I didnt do it, I was just doing the siding here but the guy building the porch seemed to know his stuff....he used 3/4 t+g with I believe 1/2" ply....no nails poking through
Motorboatin' son of a ...
I always just installed T&G and never had the roofer use nails that were too long.
![]() Full size photo: http://i37.tinypic.com/24ypqux.jpg Last edited by BKFranks; 09-25-2009 at 01:42 PM. |
Trade: Framing and General Construction
I have done a few different things. actual t&g with short roofing nails, double sheet the roof (overkill), I have even made pseudo t&g out of 3/4 ply with grooves routed into it 8" oc for a bigger look. I have also done "inserts" under the sheeting of either sanded plywood or t&g (real pain in butt) Seems like everytime I have to do this is on something with a real big overhang so then it is extra aggravating
#14 | |
Trade: Framing Contractor
I've always done it by dropping the tail down 3/4" for 1x and then sheathing with 5/8".
Joe Carola |
Trade: Carpentry / Fencing / Decks
I have done one in the past where I notched the top side of the rafters for the T&G, the ply was then laid over.
www.ParkerFenceandDeck.com |
Not bad, notching. Saves wood, labor about the same and maybe even less than sistering a false tail.
The only downside, and those that frame with precision will say, so what!, and they are right, but for exposed tails, you want razor edge straightness out at the fascia line. With sistered on tails, you can set them to a string or laser line. With sliced rafters, you may need to trim a little after setting all, and if those tails have doodled-up ends, you'll need to be careful. |
| Rafter Tail Trimming | KentWhitten | Framing | 56 | 09-15-2010 09:49 PM |
| Pergola Tails | Jaketoo | Decks & Fencing | 36 | 06-25-2009 08:51 PM |
| Is there a fancy term for this type of rafter tail? | LetItBeLEED | Framing | 18 | 06-12-2009 09:53 AM |
| How to Become a Preferred Contractor for Homeowners Insurace Claims | Maryland Window | General Discussion | 4 | 03-23-2009 01:45 AM |
| rafter table/span question | bobbrown | Framing | 14 | 11-14-2006 07:13 PM |
