Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 09-28-2009, 06:20 PM   #1
Trade: General Contracting, Remodeling
What do you nail your wall sheathing with?
I was wondering what you guys nail your wall sheathing with? 7'16" crown staples or 8d nails? That new shear wall code requires 8d nails every three inches on some walls and it made me question why we stapled everywhere else.
forsmant is offline   Reply With Quote
Old 09-28-2009, 06:27 PM   #2
Framer
Warren's Avatar
Trade: framing/remodeling
Anytime we use real plywood, we always use nails. Whenever it is osb, we use staples. The nails tend to blow apart the osb, while the staples don't seem to have the holding power to prevent the plywood from lifting. Shear walls specifically call for nailing and sometimes other hardware, as well as different header details.
"Stop wasting lumber. It doesn't grow on trees ya know! Oh wait, it does."
Warren is offline   Reply With Quote
Old 09-28-2009, 06:40 PM   #3
Thanks.
Old 09-28-2009, 06:47 PM   #4
Jeff
Trade: home builder/remolder
We use 8d on OSB and can agree with the blowing it apart at times. Gotta keep after the pressure of the gun or the guys get to blowing em clear through the sheet. Often wondered why 6's wouldnt be enough though if its not a shear wall.
jkfox624 is offline   Reply With Quote
Old 09-28-2009, 07:02 PM   #5
Trade: Home remodeling, additions, new construction
I usually use 8d nails without much problem.
mradam is offline   Reply With Quote
Old 09-28-2009, 07:04 PM   #6
Trade: Framing Contractor
I use 8d ring shank with cdx. Rarely use osb. When I did I used 8d ring shank.
Joe Carola
Joe Carola is online now   Reply With Quote
Old 09-28-2009, 07:24 PM   #7
IHI
IHI's Avatar
8's and the quick adjust tips on the guns make all the difference in the world, seems to be alot easier for me to just pull it back a click or two vs messing with air pressure, some of my guns get rather finicky at anything below 100psi.
We did help recently on a big room addition, the guy who sold it never had the materials needed for the job and we ran him out of nails sheeting everything so he brings up a staple gun and staples. I've seen it done a few times, but it was my stubborn state of mind to get the job done with what i am used to doing so i just lent out some nails from my stash.
With staples do you have to fire more in frequently in the feilds and butts?
IHI is offline   Reply With Quote
Old 09-28-2009, 07:28 PM   #8
genecarp's Avatar
Same here.
genecarp is online now   Reply With Quote
Old 09-28-2009, 07:28 PM   #9
When I am stapling, I put one every 6 inches and about every four in the butts. I was just wondering what was better.
Old 09-28-2009, 07:47 PM   #10
WarnerConstInc.'s Avatar
Trade: Sure, what you got?
Hand pound 8's.
Really, I do. No more than I have to do it, it's kind of relaxing!
Originally Posted by Gus Dering View Post
It may be just a gateway tool to the hard stuff. Be careful
WarnerConstInc. is offline   Reply With Quote
Old 09-28-2009, 08:01 PM   #11
framerman's Avatar
Trade: Framing, Custom Carpentry, Architectural Design
OK, just wanted to point this out. The question is....
what do you nail your wall sheathing with?
and the answer to that question is always....
nails
If you asked what kind of fasteners.....
If one advances confidently in the direction of one's dreams,
and endeavors to live the life which one has imagined,
one will meet with a success unexpected in common hours
~Henry David Thoreau
framerman is online now   Reply With Quote
Old 09-28-2009, 08:07 PM   #12
Plausible Deniability
JumboJack's Avatar
8d or 10d's.What ever the plans say.
"The problem with socialism is that eventually you run out of other people's money."
JumboJack is offline   Reply With Quote
Old 09-28-2009, 08:10 PM   #13
nails
Forgive my lack of proper grammar.
Old 09-28-2009, 10:00 PM   #14
Since I still have my old ancient Bostitch sheathing stapler and a pallet of galvanized staples I still use staples, and use 8d nails on the shear panels.
And 1/2" crown not 7/16", and never have a problem with them pulling out, They seem to stay in better than the nails, and if a panel has to be pulled off will rip right through the wood and stay in the stud instead of pulling out of the stud with the panel.
Kgmz is offline   Reply With Quote
Old 09-29-2009, 05:58 PM   #15
Trade: Repair/Remodel
Staples were made illegal around here about 12 years ago. It's always 8d nails, the question is what diameter. The plans will specify what type of nails, the stronger shear walls require structural I plywood with .141 diameter nails.
KennMacMoragh is offline   Reply With Quote
Old 09-29-2009, 09:31 PM   #16
Is this a King County thing?
As far as I know King County is using the IRC code same as every other county in the state, and staples are allowed under the IRC, except in engineered shear panels where 8d nails are specified. A engineered shear panel can be specified with staples and is allowed in the IRC, but most engineers just specify 8d's.
Check IRC Table R602.3(2)
I looked at the King County DDES website, and I didn't see any exceptions or sections not adopted applying to this. The only chapters not adopted are 11, and 25 thru 40.
16.05.010 Adoption. The International Residential Code for One- and Two-Family Dwellings Code, as amended in chapter 51-52 WAC, effective July 1, 2007, as published by or jointly with the International Code Council, Inc., together with appendices, amendments, additions, deletions and exceptions hereinafter adopted by reference, together with the Washington state building code and with King County modifications which shall be adopted and codified in this chapter are adopted as the King County International Residential Code for One- and Two-Family Dwellings code and hereinafter referred to as the International Residential Code, "IRC." Chapter 11 and Chapters 25 through 40 are not adopted. The energy code is regulated by chapter 51-11 WAC; the plumbing code is regulated by chapter 51-56 WAC; the electrical code is regulated by chapter 296-46B WAC; and Appendix G is included in adoption of the International Residential Code. (Ord. 15802 § 74, 2007: Ord. 14914 § 269, 2004).
Old 09-29-2009, 09:45 PM   #17
Trade: Foreman/Co-owner/Carpeneter
Just replying
I'm going to have to jump on the 8d bandwagon. As long as I've been swinging a club people have been using 8's. I've never actually used staples to fasten sheathing to a wall. I've had to remove it before and usually whosoever initially applied it decided it would be a good idea to use no less than 167 staples per sheet. Now that wouldn't be a problem except when I was a young lad starting out and encountered said situation, job safety was, (as it should be) a must. So I was therefore required to remove all 167 fasteners from the sheet, and boy was it fun. Yes, I understand that one must remove nails as well, however, it's not very often you encounter some trigger happy fella that wants to see just how many nails a standard sheet of plywood can accommodate. So, yeah, 8d ring shank has been the norm to which I've encountered. Just sayin...
Adam13 is offline   Reply With Quote
Old 09-30-2009, 04:11 PM   #18
Trade: Framing and General Construction
I prefer staples in osb due to it being quicker.. I am also careful to leave a small expansion gap along the edges. regular ply seems to pull tight better with nails. I wish plywood was a hair shorter than 8' so I could leave a little crack at the ends too
cbfx3 is offline   Reply With Quote
Old 09-30-2009, 05:34 PM   #19
BLDG Inspector, G.C
Trade: BLDG Inspector, G.C
BINGO.
Here the 2007 CBC Which is based on the 2006 IBC. Table 2304.9.1 Fastening Schedule allows staples but are not commonly used around here. As stated above it's best to use whatever the plans say.
spdtrx is offline   Reply With Quote
Old 10-01-2009, 05:17 PM   #20
The plans you guys frame from must be detailed and well put together. I have never seen a plan that calls out specific fasteners for wall sheathing. Perhaps I am not looking at it well enough or our plans suck. I am leaning toward the latter. I only brought this up because 8d nails have more shear strength than staples. I was going to suggest we use 8d's instead of staples on every wall, not just the shear walls at my work, but wanted to know what everyone else was doing.
Railroad Tie Retaining Wall Question SDFConstruction Landscaping 11 09-27-2009 02:25 PM
4' CMU retaining wall. ruskent Masonry 6 07-15-2009 10:48 PM
Wall papered brick wall repaint sparehair Painting & Finish Work 1 12-28-2008 08:01 PM
CMU wall repair mcgyverdc Masonry 6 12-04-2008 04:48 PM
Backyard office, retaining, and privacy wall Team Scream Masonry 8 08-02-2007 10:27 PM
