Web Floor Trusses That Are Not Accurate
Old 02-22-2018, 06:09 PM   #1
youngcarpenter's Avatar
Trade: Carpentry: Frame to Finish
Rewards Points: 92
What do you do when your web floor trusses that are supposed to be 174" but range 3/8" +/- They just showed up and Ill be setting them Saturday but I decided today to measure them and see if they were accurate and well some of them were.
My experience in floors is with I joists and 2 by's. Ive only done 1 house with the web truss floor joists. So far Im not a fan. Im young and not claiming to be the worlds greatest or experienced carpenter just looking for some advice from someone who has experienced this
youngcarpenter is offline
Old 02-22-2018, 06:14 PM   #2
B.Johnson's Avatar
Trade: Builder
Rewards Points: 1,424
Re: Web Floor Trusses That Are Not Accurate
If they are 3/8 to long cut them. If they are 3/8 to short nail a block on the side to pad it out. Did you check the ends for square?
Home Designer Series Software
B.Johnson is offline
Old 02-22-2018, 06:56 PM   #3
mrcat's Avatar
Trade: Pole Barns, Residential Framing
Rewards Points: 426
Trusses are very seldom right on, you just have to learn how to fudge a little here a little there to make it come out right
Sent from my SM-G900V using Tapatalk
mrcat is offline
The Following 2 Users Say Thank You to mrcat For This Useful Post:
Framer53 (02-22-2018), Justin Rhoades (03-03-2018)
Old 02-22-2018, 06:58 PM   #4
Rewards Points: 92
they can not be cut
Old 02-22-2018, 07:00 PM   #5
Rewards Points: 92
That was what I thought. I was sorta hoping there was some magical fix
Old 02-22-2018, 07:48 PM   #6
B.Johnson's Avatar
Trade: Builder
Originally Posted by youngcarpenter View Post
they can not be cut
3/8" off the end of a floor truss? I'm calling B.S. You might want to call your salesperson.
But you do what you have to do...
The Following User Says Thank You to B.Johnson For This Useful Post:
Old 02-22-2018, 07:52 PM   #7
Rewards Points: 92
The engineered web floor trusses cannot be cut. It is written in the packet that comes with them from the manufacturer.
Old 02-22-2018, 07:55 PM   #8
B.Johnson's Avatar
Trade: Builder
And while you have your salesperson on the phone, tell him that you want them to pick up the trusses, re-engineer them to the correct length and send them back.
Those papers that say to not cut or modify the truss is not talking about cutting 3/8" off the end. But seriously, check with the engineers to make sure it's ok.
The Following 5 Users Say Thank You to B.Johnson For This Useful Post:
Golden view (02-22-2018), Inner10 (02-23-2018), Justin Rhoades (03-03-2018), rrk (02-22-2018), SmallTownGuy (02-25-2018)
Old 02-22-2018, 07:56 PM   #9
B.Johnson's Avatar
Trade: Builder
Check with the engineers and get back with me on that.
Old 02-22-2018, 08:07 PM   #10
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,481
I am not gonna check with an engineer for a couple of long floor trusses. If it is just one or two, you could dado out a little bit of the rim joist.
Easy Gibson
Warren is online now
The Following User Says Thank You to Warren For This Useful Post:
mrcat (02-22-2018)
Old 02-22-2018, 08:09 PM   #11
Rewards Points: 92
Haha I should send them back! Maybe Im being a little anal about cutting 3/8". What Im really worried about is the inspector noticing and being a pain. Mabye If I cut em and then dirty up the cut so it doesn't look like fresh wood I might fool him haha
Old 02-22-2018, 08:12 PM   #12
Rewards Points: 92
So that would be my method too but they don't have a normal rim joist they use a 2x4 rim joist notched in to them like this
http://www.precisionrooftrusses.com/_images/t-floor.jpg
Old 02-22-2018, 09:10 PM   #13
Big Johnson's Avatar
Trade: Contractor and Grunt
Rewards Points: 3,420
they can not be cut
Should have bought this kind.
Web Floor Trusses that are not accurate-b1a49ab0-4f43-4b31-af9f-6efb05c275b4.jpeg
Big Johnson is offline
fjn (05-27-2018)
Old 02-22-2018, 09:23 PM   #14
Rewards Points: 92
I would be using I joists if it were up to me but its not. Not my company Im just an employee using what my boss buys!
Old 02-22-2018, 09:48 PM   #15
CPMKW's Avatar
Trade: GC PM
Rewards Points: 242
Match your overhangs and shortfalls on each end. Ie center the truss.
String your notched rim board. Pound it out till it is straight. Add side blocks if necessary.
Sent from my SM-G930W8 using Tapatalk
CPMKW is offline
Old 02-22-2018, 09:54 PM   #16
Sure, I can do that...
jlhaslip's Avatar
Trade: carpentry/renovations
Rewards Points: 190
Let the painter or siding guy worry about it.
jlhaslip is offline
The Following 3 Users Say Thank You to jlhaslip For This Useful Post:
B.Johnson (02-23-2018), fjn (05-27-2018), SmallTownGuy (02-25-2018)
Old 02-23-2018, 05:17 AM   #17
B.Johnson's Avatar
Trade: Builder
Me either. I'd cut 'em.
Edit: The point in checking with the engineer would be to learn if it's ok to cut 3/8" off. Might help in the future, and ease the youngcarpenter's mind.
Old 02-23-2018, 04:36 PM   #18
Geometrist
Warren's Avatar
Yep. I have trimmed a few in my day also. Probably a lot more than a few.
Easy Gibson
Old 02-23-2018, 05:08 PM   #19
Rewards Points: 92
I like that! I think ill give that a go
The Following User Says Thank You to youngcarpenter For This Useful Post:
Fouthgeneration (02-23-2018)
Old 02-23-2018, 06:43 PM   #20
edward trowelhands
Golden view's Avatar
Trade: Diplomat
Rewards Points: 4,302
You never, ever, ever want to cut a truss. Unless it's a tail or 3/8" off a long floor truss.
Golden view is offline
Framer53 (02-23-2018)
eagle view not very accurate IMO Grumpy Roofing 24 10-15-2013 11:35 PM
Is quartzlock 2 coverage estimate accurate? First-time user. geoffhazel Tiling 9 03-24-2013 08:50 PM
most accurate mitre saw benno Tools & Equipment 19 10-27-2010 07:08 PM
What is the most Accurate method to measure for siding? SidingWindows Windows, Siding and Doors 20 03-21-2010 09:06 PM
Accurate miter tip Gus Dering Finish Carpentry 18 11-15-2009 09:57 PM
