Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 10-08-2009, 04:19 PM   #1
Trade: Residential & Commercial Remodeling / Roofing
Warmboard Installation
We will be framing an addition soon and the plans have changed to include Warmboard as the subfloor instead of traditional methods.
The company says the framing contractor should be the one who installs this, and it does not seem too technical. Although it is quite a bit more technical than throwing down some OSB.
My questions are: Does anyone have experience with this product? Any tips, hints, etc.? And most importantly, since I have already been awarded the contract...are there justifiable reasons why I should increase the cost of installing this (takes longer, need a PHD) ?
More info is available at http://www.warmboard.com/technical-i...install-guide/
innovous is offline   Reply With Quote
Old 10-08-2009, 04:46 PM   #2
Internet Creep
angus242's Avatar
Trade: Kitchen/Bath Remodeling, Tile
Hell yes there is!!! Keeping the channels aligned is imperative. That will surely add time to your installation. Also, not sure if you have a typical method to your installs but you will most likely have to follow a schematic from either Warmboard or the designer/engineer that laid out the system in the first place. Finally, you will probably also end up hand routing some of the channels.
I cannot tell you how much time, but definitely add something. Don't lose your ass!
"If you're good at something, never do it for free."
angus242 is offline   Reply With Quote
Old 10-08-2009, 04:53 PM   #3
genecarp's Avatar
It is a project, i have installed similar systems by stadler, they supply me with full floorplans showing zone locations, feeds and returns. G
genecarp is online now   Reply With Quote
Old 10-08-2009, 05:02 PM   #4
Thanks guys.
Gene -- do you recall your production output for the stadler systems?
After accounting for time to sort the panels, additional time for cutting (thicker, cuts need to be perfect, and requires carbide blade), adding time to line up, check, line up, check, and line up the channels I see this adding 2 days to my overall schedule at the bare minimum.
Not to mention I am sure someone would like me to warranty this
Old 10-08-2009, 08:14 PM   #5
Trade: Design/Build Remodeler
Thanks guys.
...........I see this adding 2 days to my overall schedule at the bare minimum.
How big is the addition?
"Time stays long enough for those who use it"
Leonardo da Vinci (1452-1519)
DaVinciRemodel is offline   Reply With Quote
Old 10-08-2009, 08:30 PM   #6
You'll also need their router templates. Warmboard sells them - but ours have been sitting in storage for a few years collecting dust - let me know.
Old 10-08-2009, 10:50 PM   #7
When I first posted it was about 1,050sf that was getting the Warmboard. Now it has scaled back to just over 280sf. Right now I am planning to add an extra day.
As far as the router templates...I will talk with Warmboard and see if they are automatically included with the install pack, I will send you a pm.
Thanks.
Old 10-08-2009, 11:00 PM   #8
genecarp's Avatar
Thanks guys.
Fiest time, 2 days, play it safe. G
Help with some various Installation Methods AcademyHardwood Flooring 2 08-18-2009 06:46 PM
$199 Carpet Installation For Your Entire House. Celtic Flooring 68 06-28-2009 08:09 PM
Installation under house AFlo General Discussion 48 05-25-2009 02:56 PM
Finishing windows before installation??? nwksremodeler Windows, Siding and Doors 9 03-11-2009 07:32 PM
Exterior Door Installation BoydS Remodeling 59 02-20-2009 04:54 PM
