Using Header Hangers
Old 02-05-2009, 02:50 PM   #41
Re: Using Header Hangers
Originally Posted by bwalley View Post
More as in quantity, they may have less canopy.
Have you ever seen a tree plantation?
An old growth forest?
The density is far greater in
the old growth forest.
That is why plantation lumber
is so inferior to that harvested
in a natural forest, whether virgin
or second growth.
neolitic is offline
Old 02-05-2009, 02:53 PM   #42
Pompass Ass
bwalley's Avatar
or second growth.
I know the difference between the two, but what does that have to do with the number of tree's?
I never said we have more quality trees today than before, just more.
Why do you think we like wood that comes from south america (Rain Forest) more than plantation wood?
bwalley is offline
Old 02-05-2009, 03:11 PM   #43
Hard for me to believe that
with this reduction in area
we are able to some how
pack in more trees?
That's all.
neolitic is offline
Old 02-05-2009, 03:23 PM   #44
Tom Struble's Avatar
Trade: siding
before the turn of the century on the east coast of the U.S. many areas were deforested with the wood becoming fuel for heating and iron works and the like.
Tom Struble is offline
Old 02-05-2009, 03:29 PM   #45
Originally Posted by tomstruble View Post
before the turn of the century on the east coast of the U.S. many areas were deforested with the wood becoming fuel for heating and irion works and the like.
I will buy more trees now
than in 1900, that is a
provable fact, and it shows up
in the graph.
neolitic is offline
Old 02-06-2009, 12:25 AM   #46
MarkmillerConst's Avatar
Trade: General Contractor, AutoCad Design, Carpentry
Not only are the HH weaker than a trimmer, but when you install the door into a single 2x stud, just wait intill the first time the door jets slammed. This whole desire to be green has forgotten that if the end result means rebuilding, there is no savings. Also mining iron ore is a lot more environmentally unfriendly than growing a tree in a plantation.
As long as I'm ranting, the reason they make us use hangers in the first place is because too many hacks couldn't aim a nail. A little quality goes a long way.
MarkmillerConst is offline
Old 02-06-2009, 12:37 AM   #47
Trade: siding
well you can take your graph and.......
Old 02-06-2009, 07:41 AM   #48
Sorry, didn't intend to
confuse anyone with facts.
neolitic is offline
Old 02-06-2009, 08:04 AM   #49
Trade: siding
no im sorry
Old 02-12-2009, 01:21 AM   #50
Framer53's Avatar
Trade: Framing
I don't have enough posts to cut and paste yet, I think I am 1 short.
Framer53 is offline
Old 02-12-2009, 01:23 AM   #51
Framer53's Avatar
Trade: Framing
http://plancksconstant.org/blog1/200...annot_see.html
Here is one answer to your chart.
I have read and will try to find that, the number is higher because of mass deforestration of the NE US
Framer53 is offline
Old 02-12-2009, 09:14 AM   #52
As long as one can suspend
all natural law, and common sense,
okay.
neolitic is offline
Old 11-08-2011, 03:51 AM   #53
dmh's Avatar
I want to pull out the trimmers and use an HH44 over an interior door. I need a 2" bigger door for a client with a wheelchair.
Has anyone done this? NAHB says I can do it... but would like to hear from someone who has.
Ground floor condo, one unit above.
thanks
dmh is offline
Old 11-08-2011, 12:13 PM   #54
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
All I can say is;
I miss the hell out of Neo
Gus Dering is offline
Old 11-08-2011, 12:40 PM   #55
Construction Philosopher
A.T.C.'s Avatar
Trade: Builder
Whatever happened to the ol' boy? Just kinda fell off the face of the earth??
A little Learning is a dang'rous Thing;
Drink deep, or taste not the Pierian Spring:
There shallow Draughts intoxicate the Brain,
And drinking largely sobers us again. -Alexander Pope
A.T.C. is online now
Old 11-11-2011, 05:06 AM   #56
richardframing's Avatar
Trade: wood framing
HUC hanger to 5.25 by 7.25 2.0 lvl post with hga10kt top and bottom of post with hd19 hold down. 4ply lvl top and bottom sills of windows with hga10kt on top and bottom, awsome. Will take some pics. Engineered framing at its greatest.
Actually concealed hangers should be used on windows 10' or bigger or tall walls. If you ask me theres just to much wood in tall walls these days. To much cold jointing for a climate like calgary. If using a lvl and regular wood studs for wall studs care should be used to order 5.25 instead of 5.5 because the regular wood will shrink and the lvl will remain the same.
richardframing is offline
Old 11-11-2011, 05:07 AM   #57
Trade: wood framing
Old 11-11-2011, 06:00 AM   #58
pappagor's Avatar
Trade: general contractor
You can get the same R Value in a wall framed 16" O.C. as 24" O.C.
Saving a few studs on a house is not a good idea IMO, how much energy is being saved on a few studs versus a steel bracket?
I never have framed 24" O.C. and never will, I would rather spend a few more dollars on framing than to skimp on a few studs.
Building codes are the minimum standard, just because it is allowed by code, does not mean it is a good idea.
the average 3500 sq ft home has 12 ft of wall that is studs that are not need for any thing other then waste. hangers are very good i use them on all my headers . i like 12 ft of insulation over studs
pappagor is offline
Old 11-11-2011, 06:05 AM   #59
General Contractor
greg24k's Avatar
I never used these hangers on the window header, but I am wondering if they would require slight packing out if the opening will have a sheetrock return, because if not, IMO, each corner will be out at least 1/4" + at the top after taping is done, and if the blinds being installed on the inside, it will make the window look out of whack... maybe not so much noticeable on a smaller window opening, but if you have 6/0-3/0 window it will be noticed.
greg24k is offline
Old 11-11-2011, 06:08 AM   #60
ohiohomedoctor's Avatar
Just make the sheetrockers scarf the back of the drywall.
ohiohomedoctor is online now
Joist hangers for the real 2 inch wood barny94@hotmail Remodeling 15 01-04-2012 09:28 PM
triple 2x6 header allowed or 4 ply? woodworkbykirk Framing 10 11-21-2008 09:51 PM
Window Header question??? davinci Framing 2 10-16-2008 11:21 PM
Is this an incorrect header Maplehead Carpentry Picture Post 10 10-06-2008 07:54 AM
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
