Using Header Hangers
Old 02-03-2009, 04:02 PM   #21
Pompass Ass
bwalley's Avatar
Re: Using Header Hangers
Originally Posted by jaros bros. View Post
The energy efficiency is in transfer of the studs. I think it was JLC that published an article with a study on two different houses framed each way, one regular and one with advanced framing. I believe the savings were about $1000 or so a year...but then again I think they used foam on the exterior. Anyone else remember reading that article.
The downside of course is not being able to nail your trim as easily. The building isn't going to be weak because it has passed engineering and code approval. There's no need to put a 2x12 header in when a 2x6 will do.
Josh Jaros
How much heat transfer are you going to get through a 2x6?
a 2x6 has an R Value of about 7, so you lose a little bit, but I don't see how it could be $1,000 a year.
In a straight run a 40' wall, with no windows will take 21 studs at 24" O.C. and at 16" O.C. it will be 31, so 10 more studs, 15" of a reduction in R value is not a big deal.
I seriously doubt there would be much noticable difference in energy costs between a house framed 24" O.C. Versus 16" O.C.
bwalley is offline
Old 02-03-2009, 04:25 PM   #22
jcalvin's Avatar
Originally Posted by bwalley View Post
That is like people buying the Hybrid cars, yet they cost more and the the batteries and the nickel mines are not enviro friendly.
You may save some wood, but then you have the energy required to make the steel brackets.
Wood is a renewable resource.
But that is what we do in America. We rob peter to pay paul. A couple people start crying about the disappearing forest, so we figure out how to make it out of steel. Then they cry about how expensive it is and how dangerous it is to work in a foundry, then we etc...you get the point.
Cal
You hired WHO
jcalvin is offline
Old 02-03-2009, 04:28 PM   #23
Pompass Ass
bwalley's Avatar
We have more trees in the United States today than we did before the beginning of the industrial revolution.
Yet the tree huggers are always crying about something.
I know a guy who was saying we need to get rid of all of the C02, because we have 50% more C02 today than we did in the past and we are going to run out of oxygen, I asked him how the trees would survive without C02.
bwalley is offline
Old 02-03-2009, 05:38 PM   #24
D.Foster's Avatar
Trade: Carpentry & Remodeling
Whats the Best R value for a window? 2 or 3. By having jacks you are basically extending the size of the window,since the are such a heat loss, but with a better R value. I think someone said a stud is R 7. Six of one....Your not saving much buy not having jacks.
Do what you would do, as if i won't Do anything after you Did It!
D.Foster is offline
Old 02-03-2009, 05:48 PM   #25
BIG D
ribuilder's Avatar
Trade: Carpenter/Builder/Contractor
I think I'm too dumb to debate on this one
remember what you did right, then do it again!
ribuilder is offline
Old 02-03-2009, 06:07 PM   #26
D.Foster's Avatar
Haha, no c'mon
D.Foster is offline
Old 02-03-2009, 09:40 PM   #27
Kgmz's Avatar
Originally Posted by precisionbuild View Post
To get your official's approval, it is an alternate. That's why you need the manufacturer's numbers. It's alternative to the table, hence the footnote. And that's why it states approved hanger, but doesn't give a list of approved hangers. The approval will be based on complies with the
intent of the provisions of this code, and that the material,
method or work offered is, for the purpose intended, at least the
equivalent of that prescribed in this code.
My post was to show you could use them, and to back up yours.
My bad, your right about that.
I guess it really depends on the jurisdiction. Around here it is not a problem if it is in the IRC and if it is in the Simpson book. And is just considered another standard and really not alternative anymore.
Kgmz is online now
Old 02-04-2009, 08:49 AM   #28
ehighley's Avatar
Trade: General contracting
There are windows made in Canada with fiberglass frames that have an R-factor of 14. I havent been at this site long enough to provide the link. It wont allow me too.
ehighley is offline
Old 02-04-2009, 09:00 AM   #29
Pompass Ass
bwalley's Avatar
In Florida if the plans show jacks, they must be used.
If the project is not built as drawn, we get tagged and have to either build it as drawn or revise the drawings.
The plans are not just plans they establish a record for how the project is supposed to be built.
The building inspectors do not allow us to make changes in the field, without getting the plans revised and getting approval from the building department.
I have had some plans come to me for commercial buildouts that showed 24" O.C. framing, but we changed to 16" O.C., we can do that in the field, but if the plans show 16" O.C., even though code allows us to use 24" O.C. it has to be shown as a revision.
On one commercial remodel, the guy I hired to do the plans made a mistake in assuming the walls around the entire bathroom were existing firewalls, they were not required all around the bathroom, just on 1 wall in the corridoor, but since he showed them as being firewalls, we had to build them, or go through a revision, we didn't have time to wait on a revision, so we built the firewalls, because they were on the plans.
I now go over the plans very thoroughly when working with Architects and draftsmen to show them how I want it drawn.
bwalley is offline
Old 02-04-2009, 02:15 PM   #30
D.Foster's Avatar
Wow, didnt know that. What is the R on the glass?? Cuz that was kinda what i was talkin about, there is usually more sq. inches of glass than sash & frame. And do you know the approx cost of these windows? Ithink you should be able to type out the link manually, right?
D.Foster is offline
The Following User Says Thank You to D.Foster For This Useful Post:
ehighley (02-04-2009)
Old 02-04-2009, 04:34 PM   #31
topsail's trimcat
woodworkbykirk's Avatar
i framed up a house like this last year, it didnt have structural sheathing only rigid foam, when the siders came they flipped because there was nothing to nail the cape cod trim to. 2 days later we recieved a work order from the builder to install backing at all the ro's and corners so they would have something to nail to
on the same note i still find the idea of no jack stud questionable the king will be more free to move and with a door thats not something you want
woodworkbykirk is offline
The Following 2 Users Say Thank You to woodworkbykirk For This Useful Post:
D.Foster (02-04-2009), seifconst (02-05-2009)
Old 02-04-2009, 05:54 PM   #32
ehighley's Avatar
The website is thermotechfiberglass dot com
ehighley is offline
Old 02-04-2009, 05:57 PM   #33
ehighley's Avatar
Try DOW SIS (Structural Insulated Sheathing). It combines OSB and Foam. Great to work with for added wall stability
ehighley is offline
Old 02-04-2009, 09:10 PM   #34
Kgmz's Avatar
Did the walls have let in bracing? I hope so.
With this type of framing, the sheathing and nailing of it is even more important than with a normal wall.
Around here I have never seen a advanced framed building that does not have plywood or OSB sheathing. And they did put foam on top of the sheathing.
Kgmz is online now
Old 02-05-2009, 11:45 AM   #35
BuriedHammer's Avatar
Trade: Building/Remodeling
i framed up a house like this last year, it didnt have structural sheathing only rigid foam . . .
24" oc framing + foam??? Yikes!!!
BuriedHammer is offline
Old 02-05-2009, 12:51 PM   #36
We have more trees in the United States today than we did before the beginning of the industrial revolution........
Prove that please.
neolitic is offline
Old 02-05-2009, 01:08 PM   #37
D.Foster's Avatar
I have a book called "A Natural History of Trees,Of Eastern and Central North America", By Donlad Culross Peattie
Not a very up to date book, but an interesting read about the virgin White Pine in Colonial times, and how it was nearly wiped out by the british empire for it's diversity. At one point it was illegal for colonists to harvest the tree for there own use, because it was "property" of the Empire.
At time of print (1948) the author states that white pine was in the neighborhood of 14 billion bd ft in the U.S. And 8.7 billion in Canada.
Whether that is more than before the industrial rev i don't know.
Interesting book though.
D.Foster is offline
Old 02-05-2009, 01:43 PM   #38
Pompass Ass
bwalley's Avatar
Prove that please.
I will dig up the information but where the stat comes from is all of the trees that are planted for lumber, paper, restoration projects etc.
bwalley is offline
Old 02-05-2009, 02:16 PM   #39
Kind of difficult to believe
since this country was practically
solidly forested from the Atlantic
seaboard well west of the Mississippi.
If one looks at a current satellite
photograph, it would be difficult to
determine where all of these "extra"
trees are concealed.
Perhaps under all of that farmland
and pavement?
neolitic is offline
The Following User Says Thank You to neolitic For This Useful Post:
D.Foster (02-05-2009)
Old 02-05-2009, 02:44 PM   #40
Pompass Ass
bwalley's Avatar
and pavement?
More as in quantity, they may have less canopy.
bwalley is offline
Joist hangers for the real 2 inch wood barny94@hotmail Remodeling 15 01-04-2012 09:28 PM
triple 2x6 header allowed or 4 ply? woodworkbykirk Framing 10 11-21-2008 09:51 PM
Window Header question??? davinci Framing 2 10-16-2008 11:21 PM
Is this an incorrect header Maplehead Carpentry Picture Post 10 10-06-2008 07:54 AM
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
