Unscrewed/unnailed Bottom Wall Plate
Old 02-17-2017, 06:41 AM   #1
MikeJSchorah's Avatar
Rewards Points: 2
Need to build a temporary partition wall in a basement. The bottom plate can't be screwed or nailed due to there being a laminate floor and needing the option to someday remove the wall without any damage to the floor. I suspect I should use some type of foam strip product underneath the bottom wall plate. And since the wall is temporary, the top plate will be screwed, not nailed. Since the bottom wall plate is not to be attached to the floor, studs will be 12" on center, instead of 16" on center. The studs will be nailed to the bottom wall plate (and of course the top wall plate). Might use a double bottom wall plate. There will also be a standard 36" pre-hung interior door installed. My question is... Could the bottom wall plate float unattached to the laminate floor?
MikeJSchorah is offline
Old 02-17-2017, 07:03 AM   #2
MarkJames's Avatar
Trade: Handyman Services
Rewards Points: 8,587
Re: Unscrewed/unnailed Bottom Wall Plate
If it floats, you're basically making a curtain, not a wall. Glue it. Or make it free-standing with some braces.
MarkJames is online now
CharlieDelta (02-17-2017)
Old 02-17-2017, 07:32 AM   #3
Contractor of the Month
Inner10's Avatar
Trade: Control Systems
Rewards Points: 8,970
What you want is a pressurized wall, look it up.
Inner10 is offline
The Following 2 Users Say Thank You to Inner10 For This Useful Post:
EricBrancard (02-17-2017), MikeJSchorah (02-18-2017)
Old 02-17-2017, 06:01 PM   #4
Box Builder
Morning Wood's Avatar
Rewards Points: 8,212
Is this an exterior wall, or an interior load bearing/non load bearing job?
Morning Wood is online now
Old 02-17-2017, 06:52 PM   #5
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 979
Putting the studs on 12 inch centers does absolutely nothing to help the wall.
Easy Gibson
Warren is offline
The Following 4 Users Say Thank You to Warren For This Useful Post:
antonioooooooo (02-19-2017), Big Shoe (02-27-2017), MikeJSchorah (02-18-2017), NJGC (02-27-2017)
Old 02-17-2017, 06:53 PM   #6
tjbnwi's Avatar
Rewards Points: 4,318
Masking tape on floor, hot glue on masking tape, wall plate on hot glue. Be careful with faster length to install studs.
tjbnwi is offline
brhokel606 (02-18-2017)
Old 02-17-2017, 08:38 PM   #7
General Contractor
greg24k's Avatar
Rewards Points: 6,858
Build it right or walk away from it.
You strap yourself into this and something happens you will regret this for a long time. Seen this crap before and the outcome will bite you.
greg24k is online now
griz (02-17-2017)
Old 02-17-2017, 09:08 PM   #8
Fire up the BBQ
griz's Avatar
Rewards Points: 3,490
read this post again....
griz is offline
Old 02-17-2017, 09:11 PM   #9
Punching above his weight
Easy Gibson's Avatar
Trade: What do you need?
Rewards Points: 3,410
I feel like the error here is thinking the laminate floor is valuable. Screw right through that crap. Nobody's going to want it in 10 years... if that garbage even makes it that far.
Originally Posted by Irishslave View Post
Guess this is Easy's world now ....I'm just livin in it
Easy Gibson is offline
The Following 3 Users Say Thank You to Easy Gibson For This Useful Post:
griz (02-17-2017), NJGC (02-27-2017), Unger.const (02-18-2017)
Old 02-17-2017, 10:09 PM   #10
Unger.const's Avatar
Rewards Points: 1,954
I get the sneaky feeling this isn't a contractor asking. One post (this one) no info on their profile.
My other guess is a contractor said not to do this as Greg24k did. And now homeowner is now trying to get a bunch of pro's to say otherwise.
Unger.const is offline
The Following 2 Users Say Thank You to Unger.const For This Useful Post:
brhokel606 (02-18-2017), hdavis (02-27-2017)
Old 02-26-2017, 11:50 PM   #11
Vision Framing's Avatar
Trade: framing
Rewards Points: 8
why not just put a curtain up? what you're asking is silly.
Vision Framing is offline
Old 02-27-2017, 01:13 AM   #12
Professional
Str8Ahead's Avatar
Rewards Points: 106
Why are you partitioning off the room? If it's to, say, make a bedroom then nail that thing down and don't worry about the flooring. If its more temporary do you really need a wall? The partition is not load bearing so you can go 16" o.c. for your 1/2" rock no problem.
Straight Ahead Construction
Fairbanks, Alaska
http://straightaheadconstructionllc.com/
Follow on Facebook
Str8Ahead is offline
Old 02-27-2017, 04:20 AM   #13
Big Shoe's Avatar
Rewards Points: 1,652
Double sided tape. Done it a hundred times. DuPont exterior.
Sent from my iPad using Tapatalk
Expect the Unexpected
Big Shoe is online now
Old 02-27-2017, 05:26 AM   #14
maxwage's Avatar
Rewards Points: 773
Could be a renter asking as well...
I'm a beast at everything I do.
I buy tools. Not brands.
maxwage is offline
5 coats of new paint peeled right off wall 18delta Painting & Finish Work 53 12-27-2015 02:13 PM
Attaching bottom plate to hardwood floor kevbo Remodeling 6 06-19-2014 03:36 PM
galvanized nails for the bottom plate. Friend Framing 26 06-27-2013 09:58 PM
Leveling wall for tile. DKnafo Tiling 32 06-04-2013 10:56 PM
Help on finding a wall plate Kent Whitten Electrical 25 12-23-2008 05:30 PM
