Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 02-22-2007, 06:17 AM   #1
Trade: Trim Carpentry
trim for sharp metal edge
We need something to keep little kids from cutting themselves on the cut edge of barn metal- it's the roofing of an overhang (just an interior creative thing) attached to the wall in a Children's Church hallway.
It's low enough a child might jump and cut themselves on it-
We thought about getting some metal bent in a 1"x1"x1" U to wrap the edge, but that would still leave some chance of getting cut (by the u channel)
The metal edge profile is about 1"
Is there a vinyl or plastic product?
stucco exp joint?
My partner considered buying some liquid rubber dip.....
Thanks in advance for any ideas.
Mike Meyering is offline   Reply With Quote
Old 02-22-2007, 08:07 AM   #2
bill r's Avatar
Trade: residential (marine) piers
McMaster-Carr in NJ has sponge/foam profiles that would do the job, if you can figure some way to keep them in place.
bill r is offline   Reply With Quote
Old 02-22-2007, 10:29 AM   #3
How about the foam water noodles used in swimming pools? I believe they're hollow so you should be able to slice them lengthwise and slip/glue them on.
Dustball is offline   Reply With Quote
Old 02-22-2007, 09:15 PM   #4
By barn metal, do you mean typical corrugated tin? They manufacture (assumming that they still do) a wood strip , flat on the bottom, and profiled to the corrugations that is used as a closure strip. You could apply a bead of construction adhesive, apply a few clamps, then send a few short metal screws , or even pop rivets if you did not want to have scew heads visible, from the top. When it is set, recruit a few "volunteers" to dress the sharp edge of the tin with some wet/dry paper or small files.
troubleseeker is offline   Reply With Quote
Old 02-23-2007, 12:18 AM   #5
Moderator
Double-A's Avatar
I'd try an automotive style product, although I bet there is something made just for that purpose.
Take a look at this
New York Times, July 20, 2006
Double-A is offline   Reply With Quote
Old 02-23-2007, 05:19 AM   #6
Why not some kind of wood trim or if you want a rustic look some 2x2 around the edges like a picture frame. If you got something soft like Pine, you could even tap it into the metal a little so it sinks into the wood and looks even more finished.
Kgmz is offline   Reply With Quote
Metal Roofing question? fullhouse Roofing 6 11-04-2009 07:25 AM
Old School Trim ??? mobjack68 Finish Carpentry 27 09-17-2008 05:26 PM
metal cold roof question ..... Vermonster Roofing 30 09-06-2007 12:30 AM
Proposals...... AAPaint Painting & Finish Work 3 08-25-2007 08:47 AM
