Plumber / Carpenter
Treated Joists
i had a GC that insisted on making all the floor joists ACQ. Fine, we made all the beams and joists from it. I myself had crowned every joist. 2 months later the GC said i screwed up. I went back and there was gaps like 1/2" in 8' across the floor! Then she started to have problems with the joints at the ceiling and walls cracking, caulk at the cabinets started to crack, and her hardwood floor started to buckle. I think its because the treated joists swell and contract and twist all weird ways (Look at a deck). Do you think these problems may be related to the treated joists?
#2 | |
Re: Treated JoistsQuote:
dries out. Up side is, it's stable now.
Plumber / Carpenter
Re: Treated Joists
yes it is stable now, but you should see her kitchen!
Re: Treated Joists
yes, acq as far as i am concerned should not be used interior. do some research, confirm that it was improperly used, push blame to the contractor. that was a stupid call on his or her part.
Trade: Building/Remodeling
Re: Treated Joists
I built a house with a guy once who insisted we use treated for the triple 2x10 main beam down the center, supposedly since the house was on a crawlspace and therefore the beam would be exposed to high humidity...(?)
Sometime during mechanicals I was down there jacking the beam and slipping about 1/4" of shims under that beam due to shrinkage of the treated wood drying out.... So I would agree with neo yeah you have some shrinkage there from the treated, which sounds a little more severe than my beam droop... sorry
Trade: Deck Builder
Re: Treated Joists
Unless it's KD after treatment TP should not be used inside. I've seen TP deck boards shrink a good 1/2" or more once dried out, no reason joist in a house wouldn't do the same thing once dried out too.
Re: Treated Joists
Is there a such thing as KD pt?
I like Green things
Re: Treated Joists
PT for framing in a house, that is a really, really, really silly idea.
They used to use wet lumber back in the day 1900 and earlier. But they would put up the shell of the house and then let it sit for a year before thay did anything else. Those things are tight now. |
Trade: GC - Jobsite superintendent - General tool collector
Re: Treated Joists
project phase 2:
Bondo or Demo... choose your weapon
-----oo00oo----- If i understood the source of my addiction I would get help, meanwhile I'll just buy another tool today. -----oo00oo-----
Re: Treated Joists
Look for KDAT, Kiln Dried After Treatment,
it's out there, but comes dearly.
Trade: Framing
Re: Treated Joists
wondering does she have big green lines running through her kitchen ceiling now?
If at first you don't succeed hit it harder! |
| Sistering Sagging Floor Joists.... | AllGoNoShow | Construction | 22 | 02-25-2011 04:37 PM |
| Connecting wood floor joists to concrete block structure in century home. | bob_cntrctr | Masonry | 12 | 02-26-2008 12:27 PM |
| Framing Roof Joists for Addition when top Plate is not Level | personalt | Framing | 3 | 07-20-2007 06:52 AM |
| Pressure Treated Wood | rjordan392 | Carpentry | 4 | 05-28-2007 02:23 PM |
| trim coil over pressure treated wood?? | Lt.H | Windows, Siding and Doors | 7 | 04-14-2006 12:12 AM |
