Trade: Framing
Top-mount Vs. Face
here's my situation. one of my upcoming gigs is a 4k foot house. originally they had the steel girders in the basement dropped with a 12" tji floor on top. easy enough.
then the kid said he wants to tuck the steel flush to the floor. dropped all the beams in the mudhole for us to pack out and set the tji's up on facemount hangers. which to me is a ton of extra work, plus the beams will still drop around 1/2" lower than the bottom of a 12" tji. the alternative is to plate the top of the steel with an lvl ripped to size, upsize to a 14" tji to keep everything flush and use top-mount hangers. now.... i've used topmounts to drop entire decks before, but was never too comfortable doing it. mostly because of the suspension effect, the bottoms are all fairly loose. anyone care to throw in your two cents? and no, i don't care what simpson or the engineers say. |
Re: Top-mount Vs. Face
truss it
Trade: Framing
Re: Top-mount Vs. Face |
I don't know, why not try something silly like do what the plans say to do.
KemoSabe
I've packed the web on dozens of steel I-beams. It's not that time consuming. I glue all the laminations, fill one side, trap them with pony clamps, drill through, pack the other side, drill back through and bolt with carriage bolts. 20' beam takes about an hour with 2 guys. I like the positive connection with facemounts. I also drop some glue in the hanger and run a Simpson screw up through the bottom diamond in the hangers. I got into the habit of leaving the joists about 1/8" short to minimize squeeks, although packing the webs and toe-nailing into the beam is another option. Flush steel beams are notorious for hanger squeeks, as well as nails in the decking where they don't belong.
I always use wood X-bridging, even on I joists.
#6 | |
Re: Top-mount Vs. FaceQuote:
KemoSabe
I've done the topmounts with a 2x6 bolted to the flange and thought it seemed a little hokey. Seemed to work out fine, just looked unfinished to me.
#8 | |
i am just looking for an easy way out of spending a day in that hole working these beams. one of them is a w12x89 which has a 12 flange. i could weld these hangers on but i hate the way weld fillet makes the plywood ride high over beams. guess i'll just suck it up for a day and get it done the "right" way |
#9 | |
KemoSabe
#10 | |
i did big beams like that, but always off a slab. he is afraid to backfill until I get the deck done so it's like a mexican standoff - I don't want to jump in the hole, he is paranoid about a landslide |
#11 | |
KemoSabe
I did about five homes for him before I went back to building off of pilings. I found it easier to start 8' up than working around a moat.
Trade: Framing Contractor
I've dome this several times before and they don't move believe it or not. we glue and bolt lvl's to the top of the I-beam and just use top-mount hangers and that's it. Have to pack out the I-joist at each side of the hanger when doing this.
Joe Carola |
#13 | |
so we have. the hole. the moat. and the pile of dirt. the pile of lumber is more often than not on top of the pile of dirt. a one day deck turns into a 3 day ordeal. and on top of all that long island is hurricane zone now so we have to do hold-downs before we get out of the ground. major pain. they look nice when they're finished though |
#14 | |
http://www.betterheader.com/ibeam.asp
Joe Carola |
#15 | |
KemoSabe
#16 | |
KemoSabe
#17 | |
i always block my webs regardless. |
#18 | |
i think joe is going to talk me into hanging this kid's deck jump on that bandwagon it doesn't take long to convince me to take the easy way out |
#19 | |
KemoSabe
I was using the booms alot with one builder. Shorter loads, more frequently. |
#20 | |
Trade: carpenter
| Do I market on the internet or face to face? | constructonomics | General Discussion | 4 | 08-13-2009 08:28 AM |
| New one handed sawzall accessory, the forearm mount | dmuck | General Discussion | 26 | 08-02-2009 10:45 PM |
| Almost blew my face off... | CScalf | General Discussion | 13 | 06-22-2009 05:56 PM |
| Face frame hinging basics | Gus Dering | Finish Carpentry | 5 | 04-07-2009 08:38 PM |
| How do i mount a Tankless to rock wall? | akerplumber | Plumbing | 13 | 03-28-2009 02:48 PM |
