TJI SPAN Question
I have a homeowner wanting me to build him a 24' x 28' garage with a 11' x 20' bonus room above. The garage will be standard 2x4 construction with insulation, sheetrock, vinyl siding and have a 10/12 shingle roof. He has plans that were drawn by a local draftsman. His plans show using 16" TJI's spanning 24' as floor joist as with NO center LVL or Beam. I questioned the lack of a center Beam and he tells me that the draftsman and the truss company providing the TJI's assured him that they were properly rated for that span and that no center support was needed. I have only been building for a few years and haven't used TJI's that much so I am still a littele green with them. His lowest bid thus far is 85.00 a square foot so I feel like I can get the Job for 75.00-80.00 per sq ft but I am a little reserved about taking the job.
Looking at the GP website I see that the TJI's are in fact rated for the span but I still wonder about the need of a center LVL. Not saying that it is right or wrong would anyone accept this job based on his plans? |
Trade: Construction
Re: TJI SPAN Question |
I like Green things
Re: TJI SPAN Question![]() ![]() Goodness, some of these things make my head hurt.
The TJIs that I'm used to using you would need to use 16'' ones and you would need to be 12'' on center. Even with that, they still deflect like crazy. I would imagine the floor would be a bit bouncy.
Go with an LVL in the middle supported on both walls and use a steel post in the center. |
Trade: Carpentry & Remodeling
Your own doubts aside,.. if the manufactures specs are ok and you install all the proper squash blocks or web stiffners, bridging etc. i don't see a problem. There wont be any point loads on the floor right? There are diff grades of tji as well, 110- 560 series. we just did a floor system with 18" 560 series. Just dont walk on them unless you brace them with some 1x!!
Do what you would do, as if i won't Do anything after you Did It! |
Eater of sins.
Trade: Designer/Drafter Extrordinaire
At that span the garage is just at the limits for conventional construction which would require 2x12s at 12" O.C. D.F. or Larch considering a dead load around 10 lbs. and a live load at 30 lbs.
Now I don't know how the rest of the garage is designed which might impact the floor other wise so I am not giving you any kind of advice on weather or not to proceed but i would do it conventional const. You will still get some bounce with the 12s but I think not too bad. What concerns me is only charging 85.00 per sq. ft. WTF? How do you make money at that price? Is this in Mexico? Here in So. Cal 125.00 would be more in line even for a garage, not including drafting and engineering. Andy. |
#7 | |
Re: TJI SPAN QuestionQuote:
A 1 1/8" x 9 1/2 will not support as much as a 1 1/2" x 16" speaks for itself. Most REAL lumber yards will be able to help size them for you (software supplied by the manufacture) As for the sq ft pricing...how do you price anything by the sq ft? Example 10x10 room has 100 sq ft 40 ln ft of wall maybe 40 studs 2x50 room has 100 sq ft 104 ln ft of wall maybe 80 studs |
#8 | |
#9 | |
Uh, I'm talking dimensions... This is the brand we use, and right in the table it will show a 16'' TJI set at 12'' on center... http://www.kentinternational.ca/broc...System/TJI.pdf |
#10 | ||||
672 x 75.00= $57,120.00. This is a nice pay day. We are hungry down south and the jobs are few and far between. ![]()
Custom Stuff
Trade: General Contractor - Custom Renovations
Why not just truss it? The out to out is only 24'. Truss company could spec those out easily and you wouldn't have to worry about 'redesigning' a job you are only being paid to build. I would at least do a cost comparison between truuses and stick building. Less labor, no hangers, quicker to weather in. Not a sermon, just a thought.
__________________________________________________ ___________ I EXPECT THAT SOMEDAY I WILL SEE THE FRUITS OF MY LABOR. IS IT SOMEDAY YET? ![]() Clifton, Great Falls, McLean, Fairfax Station, Manassas, Virginia Renovation Contractor |
Trade: Lead Nail Bender....
have your local lumber or truss company work up an attic style truss. They can design the trusses with a 14-16' opening in the center of the truss for this "bonus room" the pitch will be step, but it would be my prefered choice. I would feel more comfortable with that, they have computer programs and went to school for that, it is beyond me.
I would also always go with a deeper beam if my head room allows. Keep in mind that there is a ton more in floor design than reading tables. The 16" I's may work in the situation, but would feel like you were walking on a trampoline. The deflection has to be high. If the truss idea fails, consider running a flush mount lvl down the center of the garage and hanger the I's from that. Trusses might be less labor....chaaaaa ching.........
Project Manager
Trade: Residential Remodeler
Im actually finishing up a Master bedroom above an existing 24'x24' garage below. The architect sized up 14" TJI's 16" O.C. from end to end with no beam in between. We did install bridging in the center however. Deflection is ok, nothing above normal. Roof loads from above are being transferred to the existing walls and foundation below. No pressure in the center besides standard live loads.
I would check the manufacturer span tables for your project. The sizing depends on the TJI series number, and they also give you calculations for what the expected deflection will be. |
#14 | |
Pompass Ass
Trusses typically work better for most cases, especially when you figure all the extra labor and material to use TGI's and then there is the issue of running your Mechanical systems. Remember span charts will list the maximum span and load allowed, it doesn't always mean that is the correct use. |
#15 | ||
#16 | |
Trade: Framing Contractor
Joe Carola |
#17 | |
Are you trying to tell me I cannot use a 16" TJI at 16 oc? I did not say a 16" TJI could not be used 12"oc, just there is no such thing a 12" oc TJI's and 16"oc TJI's What if my span was 12' or only 8'? What I was saying is... There really is no such thing as 12" oc ones or 16" oc ones. There are different series ones that are rated for spans, loads and deflection. A 1 1/8" x 9 1/2 will not support as much as a 1 1/2" x 16" speaks for itself. Read what I said, not what you think I said |
#18 |
Some engineers will call for odd spacing. We are building a house where they called for 18" 560 series @ 12" O.C. because of a custom organ being installed over the floor there. But you are right, they are not specd on spacing, but series.
#19 | |
BTW that's what the little diamond is for, on your tapes, if some of you did not know. I also have some specs on my desk now that the "designer" wants floor trusses 11 7/8" x 24' TJI 560's @ 8" oc. So... with 3 1/2" wide top and bottom cords it does not leave much room for nailing (hammer or gun) |
#20 | |
Trade: Contractor
| Answer a Question with a Question | Nathan | Off Topic (Non Trade) | 151 | 10-07-2008 03:07 PM |
| Span question | bikerboy | Introductions | 5 | 08-23-2008 07:44 AM |
| span question | FRAMERBEN | Decks & Fencing | 12 | 05-17-2008 03:39 PM |
| Question Regarding Span | nicolas | Masonry | 5 | 02-05-2008 11:01 AM |
| header span question NJ | kimmel40 | Framing | 32 | 05-01-2007 11:42 AM |
