#41 |
Trade: Framing,Remodeling,General Contractor
Re: Tgi Framing
I thought it was TJI ?
#42 | |
KemoSabe
Re: Tgi FramingQuote:
Guess it's just me and you Neo.
__________________________________ "Walking the fine line between production and perfection" __________________________________ |
| The Following User Says Thank You to loneframer For This Useful Post: | A W Smith (10-28-2009) |
#43 |
KemoSabe
Re: Tgi Framing
#44 |
Re: Tgi Framing
Actually, it's simply I-joists. TJI stands for Truss Joist International.
#45 | |
Al Smith
#46 | |
KemoSabe
#47 |
Re: Tgi Framing
seems we've taken a turn to discussing cross bracing...just today I was thinking about using a solid piece of dimesnional lumber cut at an angle and nailed in-so the block would be say for instance a 15 1/2" block beveled on both sides then nailed in the 14 1/2" joist bay. Would that not be sufficient? Reason I ask is because after a floor system is installed it would seem difficult to install the top of cross bracing (correct/incorrect?)
interesting job I'm on-3 story apartments where severe deflection has been resulted from overspaned dimensional lumber (19' spans 12" joists at 12"OC w/ 1.5" of gypcrete). anyhow, one of the units had cross bracing in the kitchen and the joists were nice and straight...the other unit had no crossbracing in the kitchen and the joists were out of plumb about 1/2" in 12". when the joists twist they lose strengh...hopefully a PE will back me up on this statement. |
#48 | |
KemoSabe
#49 |
Re: Tgi Framing
Seems logical to me. I'll do some research on this. What I wonder is if there really is a practical difference between briding and blocking. Assuming the blocking is installed in a straight line and nailed properly, why would it act differently than bridging?
#50 |
Re: Tgi Framing |
#51 | |
KemoSabe
#52 | |
Just look at the Doppler image to see how dry we are![]() Found this quote using Bing, but don't really want to register to get his info. I agree, check with the i-joist manufacturer first. As a consultant engineer, I have fixed a lot of bouncy floors. One of the solutions that I recommend to my clients is an engineered wood bridging product called IBS 2000. Having tried many remedies such as full depth i-joist blocking, lumber type blocking or full depth plywood backers, I have found that the IBS 2000 is the best solution. It is premanufactured to fit any depth and spacing and is very easy to install. The manufacturer also has a free software program that will help you predict how the floor will feel before and after the IBS 2000 is used. PE, Washington state http://boards.hgtvpro.com/eve/forums...1/m/3041095843
http://picasaweb.google.com/TimothyUhler www.pioneerbuildersonline.com https://plus.google.com/u/0/photos/1...0542215/albums Last edited by Timuhler; 10-28-2009 at 11:07 PM. Reason: to avoid too many posts in a row :-) |
#53 | |
KemoSabe
We used to get GRN 2x10s at 9 5/8. Gone back to basements and they were 9 1/4 max. Some smaller. We see mostly S-Dry now, due in part to a major problem with fungus in the GRN lumber. S-dry will still stabilize at about 3/16 less than dimension at delivery on a 2x10.
#54 |
Re: Tgi Framing
Check this out http://www.ilevel.com/roofs/pres/slide/player.html
#55 | |
Re: Tgi Framing
http://www.builder.hw.net/walls-and-...o-feature.aspx
"Wind Worthy A home's wall and roofing design and construction method, if undertaken properly, ultimately creates a shell that is stronger than the sum of its parts, when it comes to load resistance. Here again, fasteners and adhesives play a key role. Experts at the NAHB Research Center observed the following about the lateral pressures exerted by strong winds: One-story buildings are less vulnerable to wind damage than two- or three-story buildings. Hip roofs typically perform better than gable-end roofs. Moderate roof slopes perform best (4:12 to 6:12) in terms of roof uplift. For composite shingles, six nails per shingle are recommended, not the typical four nails. Window openings should be protected to avoid pressure changes inside the home in high-wind situations.Floors: Secret Strength Studies by the NAHB Research Center and others have found that modern floor systems often test out two to three times as strong as individual joists, because all of the structural components are joined together via nails and adhesives. This construction technique—particularly the addition of adhesives—has been shown to create a floor system that reduces the bend in any single joist by up to 60 percent. Quote:
http://www.awc.org/pdf/TR05.pdf check page 18 |
#56 | |
KemoSabe
#57 | |
Al Smith
#58 |
Re: Tgi Framing
I think one of the references talks about vibration not being affected or not affected much from blocking or cross bridging. Also, I thought that cross bridging was mentioned as a way to keep the floor stiff over long distances.
#59 | |
KemoSabe
#60 | |
I took a class at JLC LIVE a few years back and the teacher said that when joists are spaced 16"oc and sheathed, that because they are acting as a unit with the joist on either side, that you are actually 15% stronger. It seems to me to be logical that blocking would help keep the floor a little stiffer, but the data evidently show that up to and including 2x12, it isn't statistically significant. What I wonder is if the cross bridging benefit you are seeing would also be there after the drywall is installed on the underside of the joists. In other words, you are feeling with the bridging what you'd feel anyway if the drywall was on. Therefore it isn't worth doing? I don't know. I'm going to email our engineer and see what he says. |
| Bracing pyramid hip framing please help. | TurnkeyConst | Framing | 15 | 06-24-2011 11:30 PM |
| Framing Documents To Die For | NC2X4 | Framing | 33 | 09-17-2010 11:45 AM |
| Mold growth on framing? | jhark123 | Business | 24 | 03-17-2009 03:24 AM |
| Framing Knee Wall with Metal Studs | arawas | Framing | 6 | 02-18-2009 08:03 PM |
| framing fire place opening | Marcus1 | Framing | 2 | 09-16-2008 09:28 PM |
