I used to think so.......
TapCon Shear?
I have been asked to anchor a beam hanger into concrete using TapCons (3" x 1/4"). I am more comfortable with a Simpson rated screw or "titan". Anyone care to voice a pro opinion if the tapcon option is okay, or NO WAY?
Mike |
Young Gun
Trade: Smartass
Re: TapCon Shear?
I am more partial to the simpson concrete bolt. I dunno if the tap con will sag over time. They hold well but I have never tested it like you need too! Hope somebody on here has had to do it.
Re: TapCon Shear?
I would say unless you find paperwork that states what the load capacities are, the inspectors won't let you get away with it.
Trade: carpentry
Re: TapCon Shear?
I think all the load ratings and shear values are printed on the box. I have used Tapcons successfully in similar applications. Make sure to read the fine print, because if my memory serves me correctly, Tapcon requires you to over spec with a certain ratio. I can not recall what it is, but they specify it on their chart.
Re: TapCon Shear?
I remember a long ago nails vs screws for hangers (not the one some hammerhead has going now) that said tapcons were the only screw that simpson would allow. I can't verify it though
'The trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.' - Ronald Reagan |
Steve
Re: TapCon Shear? |
Re: TapCon Shear?
I don't like the Tapcons. They seem to be very brittle. I dont trust them.
http://www.itw-redhead.com/tapcon_perf01.asp http://www.icc-es.org/reports/pdf_files/UBC/3370.pdf http://www.itwbuildex.com/tapcon.htm |
Trade: Electrician and Remodeler
Re: TapCon Shear?
How much weight will this beam be carrying?? Is there any reason you can't pocket the the cement and place the beam in the pocket. I personally wouldn't trust tapcons to hold any serious weight. Could you explain the actual situation a little more for us.
Barry |
Trade: carpentry
Re: TapCon Shear?
i don't think that tapcon would print charts showing designated load and shear values if their fastener wasn't intended for that purpose. As long as you meet their criteria, you should be ok.(or else it's their liability)
LET ME SHOW YA SOMETHIN!!
Trade: I do that too!
Re: TapCon Shear?
I wouldn't use them for any shear application. It seams if you don't drill the hole just right and you put too much torque on them when screwing them in they snap really easy.
DO IT!! DO IT!! DO IT!! |
Re: TapCon Shear?
What kind of weight is going to be on this hanger?
What size of beam? The Tapcons are basically the same as the Simpson 3/16" and 1/4" Titan screws, and have basically the same tension and shear values. The Simpson HU and HUC hangers use these smaller screws. The Titan HD screws are a lot stronger and are used in the 3/8" to 5/8" sizes on the LGUM and HGUM hangers. So depending on your load decide which hangers to use and I would follow what the Simpson book says. Look on pages 140-141 in the 2008 Simpson book. |
Re: TapCon Shear?
The plan calls for a pocket in the concrete (which has a bucked out opening below it).
The builder doesn't like beam pockets. Insulation I think. He wants it hung. A crew was sent out by the bldr to get the floor system installed already. They have gone ahead with the tapcons. The beam spans the house and has 2 posts under it plus a post under the end at the far wall. The beam is built up 2x12s that have all the floor joists resting on it. I am no engineer...I just hate deviating from the approved plans with something structural. It may be totally fine...I just wanted to hear some other opinions. I will be framing the main structure soon, and I sure don't want a load failure. |
#13 | |
Re: TapCon Shear?Quote:
Re: TapCon Shear?
That is just wrong on so many levels. I would ask innocently if they had a engineer sign off on those changes, or possibly ask a BI to just "stop by on the way to another job to look around". I think it would be a whole bunch mo better to get that addressed before you start building up. Get it fully approved or fixed before going forward, easier that way.
Handle It!
Re: TapCon Shear?
TapCon/Blu-Mol.............Anchoring sill/floor plates, furring strips, and stuffs like that.
Load bearing???? HELL NO!
Al Smith
Re: TapCon Shear?
this hangar here?
http://www.strongtie.com/products/co...UM_MASONRY.asp or this one? http://www.strongtie.com/products/co...GLT_GLULAM.asp |
Re: TapCon Shear?
Actually the Simpson HU/HUC/etc. are rated for use with a Tapcon type screw. The Simpson screws for these hangers have the same load ratings as a Tapcon in the same size.
But I would still wonder what the load is on the hanger, and if it is within the allowable limits of these type of hangers. http://www.strongtie.com/products/co...rl_masonry.asp |
#18 |
Sweeper of fine saw dust
Trade: Project Manager by day, Cabinet maker for fun
Re: TapCon Shear?
grk makes screws that are load rated. i wouldnt use tapcons, i shear them off screwing them in sometimes.
#19 | |
Handle It!
Often!
#20 |
Trade: Kitchen & Bath
Re: TapCon Shear?
Builder ought to consider resting 2 3/4" of the beam in a 5 inch pocket and foaming in behind it.
Imagine, if just one fastener strips out in the concrete then technicaly the shear rating on the whole hanger is kaput. I'm all for insulation, but I don't sacrifice my structure to achieve it. "Damn Mabel, I sure was warm til the house fell down!" |
| Window replacement,block home- tapcons? | MHMConstruction | Windows, Siding and Doors | 12 | 08-13-2008 12:53 PM |
| Block Shear , Stone Shear , Got One? | Driftwood | Masonry | 0 | 07-30-2007 06:55 AM |
| A Funny One for You All..... | Brendakeen | Electrical | 26 | 11-24-2006 12:09 PM |
| ss110a shear for fiber cement siding? | willbone3 | Construction | 4 | 04-05-2006 10:07 PM |
| Shear strength of 1/2 galvanized bolt? | Mike Finley | General Discussion | 4 | 05-24-2004 12:22 PM |
