Strapping?
Old 08-20-2009, 10:06 AM   #21
Re: Strapping?
Originally Posted by knucklehead View Post
What do engineers know?
I think it helps, personally. I lived in a house that had a 16' span with a bounce when the kids were running around. I put solid blocks in and it got rid of the bounce.
I have seen this myself,
done dozens of retrofits.
It works in the real world.
Engineers don't always live
in that one.
And it doesnt matter how old,
deflection is deflection.
neolitic is offline
Old 08-20-2009, 12:26 PM   #22
Fentoozler
Celtic's Avatar
Re: Strapping?
Originally Posted by Gus Dering View Post
He was razzin Loneframer with that comment.
It's not always about you.
...and I should have known that.....
Celtic is offline
Old 08-20-2009, 07:12 PM   #23
KemoSabe
loneframer's Avatar
Re: Strapping?
So you forgot to put it in before you put the plywood down?
Ha ha, not exactly. I've retrofitted wood X to eliminate the persistantly squeeky metal straps. No matter how taught you get them up front, in a year or so the stuff gets loose and you get deflection in the joist that is loaded as you walk across the floor. With wood bridging, the deflection is eliminated by proper load sharing by the neighboring joists. I've also replaced a few that were beaten out by other trades, but that is another thread.
loneframer is offline
Old 08-20-2009, 08:26 PM   #24
ClemS's Avatar
Trade: Framing
Re: Strapping?
I guess that would work, Aren't the metal ones made specifically for 16" centers?
metal x-bridging is made in several different lengths. the one to use would depend on joist spacing and joist height.
ClemS is offline
Old 08-20-2009, 08:52 PM   #25
Joe Carola's Avatar
Trade: Framing Contractor
Re: Strapping?
They make metal bridging for installing after the deck is down.
http://www.strongtie.com/products/co...tb.asp#gallery
Joe Carola
Joe Carola is offline
Old 08-20-2009, 10:12 PM   #26
KemoSabe
loneframer's Avatar
Re: Strapping?
These are a good solution to the dilemma and with these "drive in" type, they won't go slack with shrinkage.
Old 08-20-2009, 11:08 PM   #27
Joe Carola's Avatar
Re: Strapping?
I used something like those one time back in 1984. That was the last time I saw them.
Joe Carola
Old 08-30-2009, 02:50 AM   #28
bradgunn's Avatar
Re: Strapping?
Just thought I'd jump in here: you're getting good feedback, but if your plan includes new tile, and you've already got the sub floor off, and you're up for doubling the joists, maybe you should think about lowering the level of the existing joists so your floor comes out the right height.
Without knowing your spans, I would nevertheless guess that doubled 2x6 joists would more than replace your existing, and carry any extra load.
I know this wasn't your question, but it's something to think about.
But I would definitely take out the cross bracing, replace them with solid blocking. Use glue and ringshanks, and check for shiners - the floor won"t squeak. Or sag.
Good luck, let us know what you decide, and how it turns out.
bradgunn is offline
Old 08-30-2009, 09:44 AM   #29
KemoSabe
loneframer's Avatar
Re: Strapping?
I found a couple pics with wood X bridging for ya. I like to set the bottoms immediately after the decking goes on. As the lumber dries, the bridging gets tighter due to shrinkage of the joists. I run 2 rows on long spans and believe me, when all is said and done, there is no spring in the floor.
Old 08-30-2009, 11:55 AM   #30
cbfx3's Avatar
Trade: Framing and General Construction
Re: Strapping?
One option to do after the fact would be to tie the joists together with a long 1x running perpendicular. this would obviously only work in a crawlspace (or if floor has a dropped ceiling under it) Shares load without squeaks associated with blocking. If I have a GC request bridging I will ONLY use 1x4 x bridging. I refuse to bridge with solids.
cbfx3 is offline
Dead blocks or strapping for trusses Csavage1 Carpentry 3 04-20-2009 01:04 PM
Strapping John1 Drywall 8 02-07-2009 04:15 AM
Insulating brick with 3/4 strapping downwithfloors Insulation 11 10-29-2008 06:59 PM
Insulating brick with 3/4 strapping downwithfloors Drywall 1 10-28-2008 07:40 PM
Studs on strapping Maplehead Framing 1 06-14-2008 02:15 PM
