Steel Studs In Bulkhead
Old 05-04-2007, 04:26 PM   #1
DSB_Const's Avatar
Trade: Residential Carpentry/Framing
I have primarily stuck to residential construction with a few small commercial jobs. I have been asked to take on a fairly large project to partition and install drywall in a commercial building using metal studding. I have used metal studding on vertical walls in the past but most of the residential framing here is wood. One area of the building has several bulkheads and different ceiling levels that the owner wants drywall on, requiring both vertical and horizontal run steel studding. The tracks for the vertical build downs can be fastened directly to the concrete slab between floors. My question is, what is the best way to fasten the horizontal studs to the vertical. Should a track be fastened to the vertical studs or screw the horizontal studs directly to the vertical?
DSB_Const is offline
Old 05-08-2007, 08:56 PM   #2
Canook's Avatar
Trade: Metal Framing, Acoustical Ceiling, Drywall.
Re: Steel Studs In Bulkhead
Using tracks will make the job look more professional and will make it easy on you if you have to fire-block your vertical wall at horizontal wall's elevation height.(and the tracks provide more nailing for your drywall). But but screwing a stud to another stud works as well...your choice.
Canook is offline
Old 05-08-2007, 09:30 PM   #3
Commercial Contractor
Mud Master's Avatar
Trade: Commercial General Contractor
Send a message via AIM to Mud Master
I would use track for the bulkheads, it is what I have always done. If you would need blocking for one reason or another, it is much better. Also, it is more professional to install a 25 gauge track to the bottom of the bulkhead than to install a 25 gauge stud. They will also sit inside each other alot better.
Plus, when it comes time to hang, the installation will go alot smoother because everything will be in thier correct place.
Originally Posted by katoman View Post
And when the day is done, I can look myself in the mirror, with pride, and say " you're a craftsman, well done. "
Mud Master is offline
Old 04-02-2009, 03:12 PM   #4
consolidatedbui's Avatar
You should always make the screws have the stress in a shear fashion opposed to a tensile fashion
consolidatedbui is offline
cutting steel studs 25BRIAN General Discussion 28 05-22-2009 09:41 AM
Brick Veneer on steel angle iron sandyman720 Construction 9 07-15-2007 05:20 AM
First time framing with steel studs nywoodwizard Remodeling 10 05-01-2007 08:57 PM
framing a door in a steel stud wall River Rat Dad Framing 5 10-21-2006 07:37 AM
Any links to framing with steel studs IHI Framing 7 01-08-2005 09:19 PM
