Southern California Framing
Old 12-30-2016, 07:03 PM   #1
ACEVEDO's Avatar
Trade: FRAMER
Rewards Points: 66
I would like to share a few photos of a coastal build we currently have underway. Words cannot express how proud I am of our team’s artisan-ship.They are framing to a standard that one would expect for finish.
Entire frame framed with LVL throughout , every cut sealed with Marine Grade Varnish , all sheathing screwed with galvanized fasteners
Big thanks to LP Building products for supplying us with the Beautiful LVL
I will keep posting progress pictures of this build as we go..
Southern California Framing-ace-lp-4.jpg   Southern California Framing-ace-lp-6.jpg   Southern California Framing-ace-lp-2.jpg   Southern California Framing-acevedolp2.jpg   Southern California Framing-acevedolp11.jpg
Southern California Framing-acevedo-framing-del-mar-5.jpg   Southern California Framing-acevedo-beach-16.jpg   Southern California Framing-acevedo-lp-beach.jpg
ACEVEDO is offline
The Following 6 Users Say Thank You to ACEVEDO For This Useful Post:
Californiadecks (12-30-2016), Dirtywhiteboy (05-11-2017), griz (12-30-2016), hdavis (12-31-2016), Peter_C (01-05-2017), wallmaxx (01-12-2017)
Old 12-30-2016, 08:44 PM   #2
Bull Trout's Avatar
Rewards Points: 186
Re: Southern California Framing
Looks like a great project all around
Bull Trout is offline
The Following 2 Users Say Thank You to Bull Trout For This Useful Post:
ACEVEDO (05-03-2017), sosaobed (01-04-2017)
Old 12-30-2016, 11:14 PM   #3
GC/carpenter
Californiadecks's Avatar
Rewards Points: 2,602
What city? Nice work by the way! Salt water air worries?
Californiadecks is online now
Old 01-04-2017, 11:40 AM   #4
gGriffeth's Avatar
Rewards Points: 88
Sweet pictures, that's a nice place to be working all day. What's the guy in the second picture doing? Looks like a router?
gGriffeth is offline
Old 01-04-2017, 04:01 PM   #5
GC/carpenter
Letting in a strap. I assume.
_________
The Following User Says Thank You to Californiadecks For This Useful Post:
Old 01-04-2017, 11:39 PM   #6
gGriffeth's Avatar
Rewards Points: 88
What is "letting in a strap"? Making a space for it so its flush with the wood?
Old 01-04-2017, 11:43 PM   #7
GC/carpenter
Yes. Not sure your age but the same concept as a let in brace we used to use for walls. The strap is to tie everything together. It's let in so it's flush. A let in brace gives a wall its strength due to its angle. They use metal let in straps now. It used to be 1x. Although that strap on the deck isn't a brace. But it's let in.
NJGC (01-10-2017)
Old 01-05-2017, 12:06 AM   #8
ACEVEDO's Avatar
Trade: FRAMER
Rewards Points: 66
Thank you guys
Yes project is right on the water , in Northern San Diego
We countersink all hardware Ltp4's , straps, etc flush into the substrate.
All framing is framed with LVL by LP building products
Here's a video they did for us last year
https://www.youtube.com/watch?v=shyoA2R-1z4&sns=em
ACEVEDO is offline
The Following 2 Users Say Thank You to ACEVEDO For This Useful Post:
Californiadecks (01-05-2017), slowsol (01-05-2017)
Old 01-05-2017, 12:13 AM   #9
GC/carpenter
Thank you guys
What s dream to not have to deal with #2 crown, bows, twists etc. Every board the same. Yeah I'm jealous!
Old 01-10-2017, 07:45 PM   #10
Krok's Avatar
Trade: Mold Generator
Rewards Points: 844
What CAdecks said, but with his 1x my guess is those were diagonals at the wall corners to prevent racking. The one above I'd guess is some type of seismic protections in their code.
Krok is offline
The Following 2 Users Say Thank You to Krok For This Useful Post:
Californiadecks (01-10-2017), gGriffeth (01-10-2017)
Old 01-10-2017, 08:04 PM   #11
GC/carpenter
Yep. I've had to put a horizontal strap all the way around a whole building with one continuous strap. Usually when there a lot of large openings.
Old 01-10-2017, 08:16 PM   #12
Krok's Avatar
Rewards Points: 844
Horizontal strapping? What would that do? That's crazy. Wouldn't staggered blocking be just as good AND piss off the insulation guys?
Krok is offline
Old 01-10-2017, 09:07 PM   #13
GC/carpenter
I know. You'd think it would need to be diagonal to give any strength. But it was a strap called out by engineers. It usually is used on maybe one wall. But I've had to do it all the way around the building. Top and bottom of the wall. One at header height the other at sill height.
Old 01-12-2017, 10:20 AM   #14
Krok's Avatar
Rewards Points: 844
Must be trying to squeeze out every last percentage of stability, "fkit, just have the framers run straps top and bottom".
I used to think the amish knew what they were doing until I saw them almost take all the siding off a garage and there were no letins or ply, the wind came up and it came alive--so did the amish, scrambling for bracing. The beard brigade scrambles.
Krok is offline
Old 01-16-2017, 12:25 PM   #15
ACEVEDO's Avatar
Trade: FRAMER
Rewards Points: 66
Here are a few more photos and preventive measures we take on coastal homes.
In photos 1 & 2 you can see the benefits of the LP LVL material treated with Site-Cote by LP
In photo 3 you can see how we take the time to seal each piece of beam fill by first filling each countersink cavity with “rapid seal” by Sto. Corp. We then seal the gap between the steel and wood filler, and finally cover the entire beam with two coats of “EmeraldCoat” by Sto. Corp.
In photo 4 you can see that we wrap the nailers with a jiffy seal membrane to keep them from rotting against the Steel I beam
Southern California Framing-acevedo-attention-detail-rain-1.jpg   Southern California Framing-acevedo-attention-detail-rain-2.jpg   Southern California Framing-acevedo-attention-detial-rain-4.jpg   Southern California Framing-acevedo-nailer.jpg   Southern California Framing-acevedo-rain-9.jpg
ACEVEDO is offline
The Following User Says Thank You to ACEVEDO For This Useful Post:
Californiadecks (01-16-2017)
Old 01-16-2017, 12:52 PM   #16
Designer/Contractor
Rio's Avatar
Rewards Points: 422
Perforated shear wall technique to pick up more shear value on that line.
Rio is online now
The Following User Says Thank You to Rio For This Useful Post:
Old 02-01-2017, 09:22 AM   #17
SBE Builders's Avatar
Trade: Framing
Rewards Points: 211
It's a good idea to seal all the LVL's. I had 14" LVL's swell to 14 3/4" this last winter. Pain in the ass to fix.
Did you get a building inspection before you covered up the nelson studs? With all the missing nails in your LVL hangers I would question if all nuts and washers are on the nelson studs, if I were a building inspector.
Also, this is the first time I seen HUS hangers used on LVL lumber. Normally it's HGUS or HHUS hangers. Double-shear nailing hangers are not usually called out by a structural engineer for LVL lumber.
Sim
SBE Builders is offline
The Following 2 Users Say Thank You to SBE Builders For This Useful Post:
Kowboy (02-04-2017), NJGC (02-01-2017)
Old 02-01-2017, 12:38 PM   #18
Trade: Framing
Rewards Points: 211
Excellent video on your use of LP Solid Start LVL's and your company. I've used the Solid Start LVL's before and complained about the wax they put on the LVL's, but with my 14" LVL's swelling to 14 3/4" this winter in the SF Bay Area I'll probably ask for the LP Solid Start products this year.
Thanks for posting this video on LP Solid Start.
Sim
Old 02-01-2017, 12:47 PM   #19
Trade: Framing
Rewards Points: 211
We dap , which is the correct word for dadoing the hardware, our straps, but have never seen an LTP4 dadoed into the shear wall plywood.
Sim
Southern California Framing-cmst14-1.jpg   Southern California Framing-cmst14-2.jpg   Southern California Framing-cmst14-3.jpg
The Following User Says Thank You to SBE Builders For This Useful Post:
Old 02-01-2017, 12:58 PM   #20
Trade: Framing
Rewards Points: 211
We also dap the bottom of beams for MST48 straps.
Southern California Framing-dado-1.jpg   Southern California Framing-dado-2.jpg   Southern California Framing-dado-3.jpg   Southern California Framing-dado-4.jpg   Southern California Framing-dado-5.jpg
The Following 6 Users Say Thank You to SBE Builders For This Useful Post:
402joel (02-04-2017), ACEVEDO (05-03-2017), asevereid (02-04-2017), Dirtywhiteboy (05-11-2017), fourcornerhome (05-03-2017), Jaws (02-04-2017)
Looking for southern ma framing sub contractor jmontgom Help Wanted or Looking For Work 0 09-21-2015 06:38 PM
Union work in Southern California, any info? Oskar Construction 4 01-25-2013 04:06 PM
Hello from Southern California SoCal Introductions 5 10-21-2010 02:51 PM
New Property Solutions for Southern California (San diego) 101PropSolution Help Wanted or Looking For Work 0 09-13-2010 05:24 AM
New to SITE!! Southern California Timedesign Introductions 2 01-09-2009 10:18 PM
