Soffit Backing Formula
Old 03-26-2007, 11:39 PM   #1
RadiusFramer's Avatar
Hello everyone,
I have a question for those who apply soffit backing before standing walls.
Is there a formula you use based on the roof pitch as to where to snap your line to attach soffit backing before standing the walls. I've thought about this for a while and it seems like it would save a lot of time up on a ladder. If so what do you do about raised heels on your trusses?
Thanks in advance
RadiusFramer
RadiusFramer is offline
Old 03-27-2007, 08:27 PM   #2
KentWhitten's Avatar
Re: Soffit Backing Formula
It's some relatively simple trig related to your pitch plus you have to figure out seat cuts depth, where you are going to snub off the tails, how wide your fascia board is, etc.
Raised heel trusses, depending on the soffit material, I either don't do anything at all, or you can use nailers like sheetrock nailers, between the truss bay. Lotta work though.
Funny how the spell checker underlines soffit and sheetrock. I swear they are real words.
If you don't have a construction master out in the field, it will be tough. Possible but lots of handwritten figuring.
Draw out the side view of your rafter/truss. Say your overhang is 18" at 8" pitch, then the drop will be 12" from the edge of your framing. say the seat cut of your rafter is 6" just to use for ease. so now instead of 12", you are at 6" from your top plate. Now all you have to figure is out on the end of the tail, how far down to you want to snub the long point of your rafter/truss. 1x8's you roughly go 5-6". just say 6". add that to your drop, you get 12" which is where you will chalk the line for the BOTTOM of your nailer. Don't make the mistake of putting it on the wrong side of the line.
Personally, when I do this, if I do this, I would just tack the board on the wall straight, then double check when everything else is framed for the roof to make sure it all comes out right. You will look good if it works right for you, but if you mess up, you will look like an idiot to the builder when you have to take it all down.
KentWhitten is offline
Old 03-27-2007, 09:32 PM   #3
Charitable animal
Bone Saw's Avatar
Trade: decks
A Squared+bsquared=c Squared
Bone Saw is online now
Old 03-27-2007, 11:04 PM   #4
Home Repair Specialist.co
hrscammisa's Avatar
Trade: carpentry
Boy if it works what a time saver great idea I will try that my self
hrscammisa is offline
Old 03-28-2007, 08:31 PM   #5
Lol
THrown-in insulation: No soffit vents... Ted W Insulation 19 08-15-2009 12:35 PM
Aluminum soffit estimate? K_Tile Windows, Siding and Doors 24 07-25-2008 11:56 AM
roof or soffit vent? ch0mpie Remodeling 4 10-02-2006 05:41 PM
Need Help With Hardy Soffit Pricing abelc Windows, Siding and Doors 1 02-20-2006 12:37 PM
Soffit pburchett Windows, Siding and Doors 10 01-14-2006 06:46 PM
