Sheathing Walls On The Ground Or Standing?
Old 01-06-2009, 10:11 PM   #41
Gary H's Avatar
Re: Sheathing Walls On The Ground Or Standing?
hughjazz, there are a few builders here that sheet the walls after they are standing. That is taking the long way home. But the boss on those crews are not doing the grunt work. They are riding around in their trucks bitching how he can't make any money. We always have to house warp the walls. I even tried knocking off 50 cents a square foot not to do it. No luck.
Gary H is offline
Old 01-06-2009, 10:14 PM   #42
Gary H's Avatar
Tim, can you post some more pictures? I tried to find them but did not have any luck.
Gary H is offline
Old 01-06-2009, 10:16 PM   #43
I will this weekend. I'm heading to Portland, OR for a timber framing class on eyebrow roofs tomorrow night through saturday. I can't wait
Timuhler is offline
Old 06-07-2009, 07:11 PM   #44
Do I work here?
rick0913's Avatar
Trade: carpenter
I always do sheathing,housewrap &when possible set widows on the ground.I only stand first on walls built on slab or foundation.I always check foudation wals for level w/transit or water level *(long pieice of clear plastic tubing filled w/water,cant be out of calibration, costs next to nothing, most accurate levl known to mankind) If the floor is level & you are as picky as I am when it comes to cutting plates & squaring the walls you can't go wrong. I have tried both ways & will never be convinced that there is any valid reason to do anything more than absolutetely necessary after the walls are up. Back in the days of masonite&T111
siding I even did the siding on the ground & hung the soffits at the top of walls completely finished except for the facia board.
rick0913 is offline
Old 06-07-2009, 07:45 PM   #45
Do I work here?
rick0913's Avatar
Trade: carpenter
I also build any bumpouts on the wall while its onthe deck complete w/roof framed & sheated.Fireplace chases are an excellent example, they are not only easier by far to build on the wall while on the floor, they also act as a temporary brace when standing the wall.Once the bottom plate of the chase hits the floor that wall cant tip on out.I beleive that any one *Qualified to run a framing crew can easily figure out how to pre build the soffits so the rafters or trusses will plane to the top of the subfacia.I also pre-cut all rafters including hip & valley jacks ,usually after the floor is decked but before walls are built.I like to do this after hours or on weekends so I don't get distacted. I have had many framers act like this is some kind of amazing feat but I'msure w/a little thought anyone who can frame can figure it out easily.
rick0913 is offline
Old 06-07-2009, 07:53 PM   #46
Home Depot aisle walker
willworkforbeer's Avatar
Trade: home remodeling
Originally Posted by Cole View Post
Frame / Stand / Sheathe
What plumb walls? Much easier on the trim guy, punch guy says thanks too.
willworkforbeer is offline
Old 06-07-2009, 08:25 PM   #47
KemoSabe
loneframer's Avatar
As if you guys didn't know.
loneframer is online now
Old 06-09-2009, 08:21 PM   #48
LA Crosby
LA CROSBY's Avatar
Trade: Boat Builder, Framer, Finish Carpentry
Originally Posted by K2 View Post
I liked stand and sheath with the plywood run horizontally staggered and laid out so the vertical breaks are not on the plate lines. But that's not the way I did it most of my life. Either way is just as fast for me and the house will be there a thousand years regardless... I usually did it the way the crew knew it best and here in the west it was generally laying down.
Roger that, just the way I learned. Over lap the sheathing. I also nail down the bottom plate at an angle on the inside to hold it in place. Then when you stand the wall, the nails hold it while it goes up.
LA CROSBY is offline
Old 06-09-2009, 08:42 PM   #49
MattK's Avatar
Trade: Framing, Remodeling
I think ive read 5-6 threads revolving around sheathing in the air or on the ground. Funny thing is alot of the same names get involved in each one. They always end up with everyone agreeing that their way works best for them and its what they are most comfortable with. I will never sheath an entire house in the air for many reasons, and I respect all the reasons why guys hate the idea of doing it on the ground.
I do think some of the different techniques are related to what region you learned or currently work in...
MattK is offline
The Following 2 Users Say Thank You to MattK For This Useful Post:
LA CROSBY (06-09-2009), Timuhler (06-09-2009)
Old 06-09-2009, 08:58 PM   #50
solar guy
naptown CR's Avatar
Trade: solar contracting
and the equipment you own also
naptown CR is offline
Old 06-09-2009, 09:02 PM   #51
KemoSabe
loneframer's Avatar
Or the design of the buildings you are sheathing.
Exterior sheathing question tthomas Windows, Siding and Doors 5 12-26-2008 07:13 PM
Ground Up or Ground Down(no it is not another debate) darren Electrical 18 04-12-2008 07:19 PM
Temp Road on Wet and Unstable Ground Trencher Excavation & Site Work 12 02-05-2008 10:40 PM
"Green is some kind of safety ground.." GregS Electrical 13 01-27-2008 09:13 PM
Bowed Walls on historic garage genesisremodel General Discussion 2 03-16-2004 07:30 PM
