Sheathing Walls On Ground.......
Old 10-26-2009, 08:17 PM   #61
Kgmz's Avatar
Re: Sheathing Walls On Ground.......
Originally Posted by crovello View Post
Attachment 24489Trying to get my foundation crew to place anchor bolts to within a quarter inch is not easy.
Thats why I use those plastic anchor bolt standoffs and place the critical ones myself. Also make the foundation crew use them for all the regular anchor bolts. Got tired of them wet setting them and they were all over the place, meaning placement from outer edge of foundation. Really tees me off when setting sill and the bolt is on the inner edge of sill completely missing the board or just barely catching it.
Also per code here you are not supposed to wet set the bolts, they should be held with those plastic anchor bolt holders and then the concrete is poured. Some inspectors here won't sign off on the foundation if they don't see those bolts hanging before the pour.
Kgmz is offline
Old 10-26-2009, 08:24 PM   #62
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Attachment 24489Simpson HDU hold downs. The 5/8" threaded rod passes thru the floor framing and connects to a 5/8" anchor bolt with a coupling. These need to be connected to nearly every window openning on this project so the foundation crew needs to place many anchor bolts in exact locations. The other option is to set anchors in place with epoxy later. I am still not sure what method workes best. Trying to get my foundation crew to place anchor bolts to within a quarter inch is not easy.
This is why I did not sheath walls while laying down on this project.
Out here in the land of shaky earth hold downs are old hat.
The framer usually always makes an appearance for a day prior to the pour to lay out and place the hold down anchors. Or forever hold your tongue.
Those relatively new phd's with the lags are a breeze compared to the older ones with the through bolts.
Gus Dering is offline
Old 11-02-2009, 08:47 PM   #63
cbfx3's Avatar
Trade: Framing and General Construction
I run into these quite often in my commercial jobs.. ours are usually on the corners and 8' in from the corners. Ours are the BIG ones,,, 7/8 bolts that go all the war to the footing so placement is usually a bit off. We usually lay the quad that it bolts to out using an actual bracket and just squaring off of it. It seems to go quicker if you pilot the screw holes ... We have a little tool kit just for these with a big wrench, big socket .. right angle drill adapters .. pilot bits ect....
cbfx3 is offline
smoke walls naptown CR Commercial Construction 18 09-11-2009 06:29 PM
Block Walls DaHammer Masonry 29 03-06-2009 07:11 PM
Why Build ICF monsterconstruc Green Building 32 09-28-2008 11:48 PM
Bridging for above grade Concrete Walls ETHICS05 Construction 1 11-21-2005 12:43 PM
