Round Porch..?
Old 08-02-2006, 01:30 PM   #1
ecooke21's Avatar
Trade: Rremodeling..finish carpentry, etc
Round Porch..?
I need to frame a porch that is round..I have some ideas, but I am hoping there is a tried method for perfect results. any ideas?
the radius is about 14' I will be attaching the ledger board to the house and framing perpendicular to the ledgerboard..thanks
ecooke21 is offline
Old 08-02-2006, 04:59 PM   #2
Tom R's Avatar
Re: Round Porch..?
Not sure exactly which part you're asking about, - - but I guess I would lay it out on paper first, - - then once the beams (parallel to the ledger board) are in just let the joists run at least a few inches wild, - - then pencil-in the radius (minus the rim-joists or fascia) across the tops of the joists, - - then cut 'em plumb and install your (layered?) fascia and start deckin'.
Tom R is offline
Old 08-02-2006, 05:06 PM   #3
IHI's Avatar
Re: Round Porch..?
What Tom said is about the easiest method. When we did the 1/2 round stairs for a deck we built I drew it up on paper so I knew what size loumber I needed to stagger it back each side of the center and installed all the joists letting them run wild. Found my half way point and with a string tied round a pencil drew the radius.
If you dont want a perfect half circle you can run a string at the end and leave it as loose as you need to then just push the pencil up against the string and the string itself will oblong out towards the center but come back in one the ends with a nice gradual curve. That does'nt sound realy easy to understand for the oblong look, sorry about that but in reality it is very easy.
IHI is offline
Old 08-02-2006, 09:55 PM   #4
ecooke21's Avatar
Re: Round Porch..?
sorry, i should have been more specific..I am having trouble figuring out how to instal a curved rim joist..should I just lay out my 2x's "wild", cut them plumb and install one section of straight rim joists, one at a time? Then bend my fascia?
sorry about the confusion
ecooke21 is offline
Old 08-02-2006, 10:08 PM   #5
Tom R's Avatar
Re: Round Porch..?
Not something I've done, - - and maybe someone knows better, - - but I think once I got the wild's cut plumb, - - I'd install 'individuals' between (like blocking) right at the ends of the joists. Then I would 'shim-out' to at least two equally-spaced intervals on each block (out to the radius), - - and then apply my curved fascia.
Tom R is offline
Old 08-02-2006, 10:09 PM   #6
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Round Porch..?
That would work. But what I would do & have done is make a series a saw kerfs on the back side of the rim joist. The kerfs are about half the thickness of the joist (3/4" for 2x) and cut about every 3" - 4". This allows you to "bend" the rim joist to the curve of the deck.
The views expressed in this post are merely opinions of named poster and in no way shall be deemed meaningful by members of the herd. By no means does anything posted by named poster mean a damn thing for anyone else partaking in this thread.
maj is offline
Old 08-02-2006, 10:11 PM   #7
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Round Porch..?
Actually........ With some of the crap lumber we get these days...... you could prolly find a precurved 2x at the yard!!!!
maj is offline
The Following User Says Thank You to maj For This Useful Post:
mikeswoods (09-27-2010)
Old 08-02-2006, 10:17 PM   #8
Tom R's Avatar
Re: Round Porch..?
Should be right on top of the pile at Home Depot!!
Tom R is offline
Old 08-02-2006, 10:19 PM   #9
Tom R's Avatar
Re: Round Porch..?
This is a good suggestion, too.
How about some more details on the 'finished' product.
Treated??
Cedar?? Redwood?? Ipe??
Composite??
Picture-framed decking??
Tom R is offline
Old 08-02-2006, 10:30 PM   #10
ecooke21's Avatar
Re: Round Porch..?
I am using a 5/4 x 4 Mahogony, with a composite fascia(to bend easily)
ecooke21 is offline
Old 08-02-2006, 10:50 PM   #11
Tom R's Avatar
Re: Round Porch..?
Either way will work, - - sounds like maj's way will give you a more solid backing for that very flexible (1/2" thick?) composite fascia.
Tom R is offline
Old 08-02-2006, 10:54 PM   #12
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Round Porch..?
ecooke.....What's the framing? Treated?
'cause with the method I described, you could do away with the fascia. Get a good looking rim joist, kerf it & bend it..... you're done.
maj is offline
Old 08-02-2006, 11:03 PM   #13
Tom R's Avatar
Re: Round Porch..?
See, - - I picture-frame all my decks, - - so the rim joist could only work as a backer for me, - - or the kerfs would be in the finish.
Tom R is offline
Old 08-02-2006, 11:12 PM   #14
unlicensed hack
maj's Avatar
Trade: wood butcher
Re: Round Porch..?
Gotcha there Tom. I didn't think about that. I've been doing that lately too. Makes for a cleaner looking edge.
maj is offline
Old 08-04-2006, 08:38 AM   #15
RobertCDF's Avatar
Trade: Custom deck builder
Re: Round Porch..?
Sorry I did not notice this thread before.... For a curved rim joist rip 1/2" PT ply into strips as wide as your framing lumber ex 9 1/4" for 2x10 and then just bend it into place and add 2 more layers of ply to make it 1 1/2" thick.
RobertCDF is offline
Old 08-04-2006, 01:31 PM   #16
IHI's Avatar
Re: Round Porch..?
What are you using to fasten them? Granted I initally tried bending with water logged ply on my curve steps and found the radius to be too tight and it'd either break the plywood layering or give notchy type radi instead of a nice flowing curve. For a porch I dont see a problem due to size, but the steps we did it was pretty tightly bent so we had to move to lexan...nobody locally carried any composite type material at that time so we used what was available, plus he was talking about back lighting the risers anyways in the future.
IHI is offline
Old 08-08-2006, 09:29 AM   #17
FRAME ON!
A+Carpenter's Avatar
Trade: Decks,All phases of remodeling,
Re: Round Porch..?
First of all how big is your radius for on your porch? Reply back to this thread with your dimensions. Your rim joist can me manipulated to some extent.
There are a few methods to do this. TAKE IT FROM A REAL FRAMER
A+Carpenter is offline
Old 08-08-2006, 05:54 PM   #18
Tom R's Avatar
Re: Round Porch..?
Ummm, - - maybe re-read his first post??
Tom R is offline
Old 08-08-2006, 06:05 PM   #19
Tom R's Avatar
Re: Round Porch..?
By the way, us fake framers are real interested in what you have to add here, - - tell us some real tricks, will ya??
Like ya' always do?? . . .
Tom R is offline
Old 08-08-2006, 06:09 PM   #20
Back from the dead...
ProWallGuy's Avatar
Trade: Paperhanger/Painter
Re: Round Porch..?
Tom, I knew it. I had you pegged for a fake framer all along.
ProWallGuy is offline
Round rail posts mikec Decks & Fencing 6 05-12-2011 10:29 AM
How to level out a concrete porch? ProVolley9 Masonry 17 08-27-2008 09:09 PM
Question with quarter round haskl33 Carpentry 14 05-31-2008 07:49 AM
Paint your Porch? Chris G Off Topic (Non Trade) 1 01-31-2007 02:08 PM
How would you frame this porch rebuild? karma_carpentry Framing 10 04-08-2006 07:45 PM
