Roof Trusses - Nail To Interior Walls???
Old 02-02-2010, 09:52 PM   #1
bimmerdream's Avatar
Trade: Improvement
Just wanted to see what everyone thinks...
I personally like to nail roof trusses to anything they touch. Your opinions?
bimmerdream is offline
Old 02-02-2010, 10:25 PM   #2
carpenter72's Avatar
Trade: carpentry
Re: Roof Trusses - Nail To Interior Walls???
Yeah, we always nail them to interior walls to keep em strait and on layout for drywall ect.
carpenter72 is offline
Old 02-02-2010, 10:29 PM   #3
smeagol's Avatar
Trade: new construction and remodeling
x2
smeagol is offline
Old 02-02-2010, 10:38 PM   #4
BillD's Avatar
Trade: General contractor
I always used to nail them now I would use the truss uplift clips to secure them at interior partitions.
Bill
BillD is offline
Old 02-02-2010, 10:48 PM   #5
Trade: Improvement
well yeah, thats what the truss man would say, but has anyone ever had any problem with nailing them to every top plate the bear on??? I haven't.. I have however heard plenty of horror stories about drywal separating in the winter, etc...
Practical vs Theoretical...
Old 02-02-2010, 10:52 PM   #6
David Festa
festerized's Avatar
Trade: Framing Contractor
Yup what bill said
I hate doing this way, inspector does want the truss nailed, and instead they want the use of a clip.
On one job, truss spec. sheet called out that interior walls must float ½” from truss and use goal post clips. We had to pack up all exterior walls with ½” plywood. Its not easy seting trusses when you can’t nail the bottom.
I would like to point out we don’t use a crane if trusses are under 400lbs or is under 20’ high
If it’s a 2 story house I just use the crane to get them up there. Lay them down I get that big hunk of swinging metal off my sight
I was taught old school using “pussy sticks”
3 guys on the ground using their pussy sticks and 3 guys in the air pulling
Addition Contractor Bayville Home Addition Monmouth Beach NJ Contractor Jackson NJ
“Photography is not art, It’s just a Xerox of what just happened”
festerized is offline
Old 02-02-2010, 11:11 PM   #7
curtis fulton's Avatar
Trade: framing
yep nail them to interior walls too
curtis fulton is offline
Old 02-02-2010, 11:27 PM   #8
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
We used to until they started requiring STC clips on every truss to partition connection. If you use those clips then you do not nail them, the trussed need to be able to move up and down. Those may be required only for a seismic zone 3 or 4, I'm not sure.
KennMacMoragh is offline
Old 02-03-2010, 12:40 AM   #9
SEMI RETIRED
griz's Avatar
Whatever the truss engineering specs say. 99.9% time the truss is attached with a clip at both ends & on top of interior walls. In snow country (200+ lb snow load) used crush blocks w/A35 on both sides. Never have seen bottom cord nailed to interior walls. Rat runs keep them on layout.
griz is offline
Old 02-03-2010, 05:34 AM   #10
KentWhitten's Avatar
Trusses are designed to float above interior walls. Except where there's an interior load bearing wall, you're to use the clips.
Have I before? Yes. Would I now? No.
The longer the truss in general, the more deflection is in the design.
Salmon Falls Cabinetry
KentWhitten is online now
The Following 2 Users Say Thank You to KentWhitten For This Useful Post:
D.Foster (02-18-2010), Willie T (02-03-2010)
Old 02-03-2010, 08:45 AM   #11
WOOD TICK
roughrider's Avatar
Trade: Custom Homes/remodeling
Most general contractors around here will freak out if every wall is not nailed to a truss. have never even seen a clip around here (except on the ends).if you dont nail the walls to the trusses how do you keep your interior walls level, strapping?
roughrider is offline
The Following 2 Users Say Thank You to roughrider For This Useful Post:
festerized (02-03-2010), SC sawdaddy (02-03-2010)
Old 02-03-2010, 09:12 AM   #12
framer
steves's Avatar
Trade: framing
As a rule we do not nail to interior walls unless of course it is a bearing point.
But I have no problem toe nailing to the bottom chord to hold the wall or the cord straight.
steves is offline
Old 02-03-2010, 09:15 AM   #13
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
Framerman is correct. Never, ever, nail interior walls directly to trusses. Never!
It is a sure way to eventually have cracks develop at the lid-to-wall intersections. (Not using ceiling clips, especially)
Not to mention it is a flagrant violation of design criteria, and can often alter truss strength.
Even before clips (thirty years ago) we knew better.
Also, someone mentioned that they nailed where trusses were 'bearing' on interior walls. Unless this is a designed and designated bearing point, no interior walls should have trusses even touching the top plates at all.
The drawing below shows both a truss uplift clip & a couple of ceiling drywall clips. We all need to be using both.
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is online now
The Following 5 Users Say Thank You to Willie T For This Useful Post:
bwalley (02-03-2010), CanCritter (02-18-2010), Cjeff (02-07-2010), D.Foster (02-18-2010), katoman (03-06-2010)
Old 02-03-2010, 10:05 AM   #14
Framer53's Avatar
Trade: Framing
Willie, that may be fine and good where you live, but is not done around here.
Framerman I have heard the horror stories, but have yetsimpson to make money. to see any around here. I think this may be overblown or another way for
Framer53 is offline
Old 02-03-2010, 10:25 AM   #15
SC sawdaddy's Avatar
I have always nailed off every truss everywhere it crosses a wall. I've been doing it wrong all these years?
Never had a problem with it nor seen it done any other way.
SC sawdaddy is offline
Old 02-03-2010, 10:28 AM   #16
General Contractor
Willie T's Avatar
Actually, if you return to houses framed several years ago, you will often find cracks running not only along the wall-to-ceiling intersections, but also on the vertical wall corners.
This is due to the normal movement (movement, not settlement) all houses experience during climatic (temperature and humidity) changes.
Even here, we still have inspectors who have not kept up with the advancements in the industry, and continue to insist on nailing all the drywall tight in corners and intersections. This continues to create exactly the same problems we have had for decades. But they seem to only know rules, and not reason.
In recent years we are finally learning that many of the hard, fast rules about insulation do not work the same in all areas. Yet the inspectors insist of the same installation rules here in Florida as in Maine.
Anything may be tradition, accepted, and even legal or required. That doesn't necessarily make it correct nor the best way to build. Unless my hands are tied by the Building Dept. I will always strive to build the better way.
And we built "sliding" connections for wall/truss intersections long before Simpson even dreamed of Uplift Clips. (BTW, I agree that many Simpson requirements are no more than lobbying efforts on that company's part to increase profits.... but not in this case.)
Old 02-03-2010, 10:29 AM   #17
Ceilings just float?
Looks like there would be a curve in the finished ceiling between truss and deadwood unless crown was installed.
Old 02-03-2010, 10:39 AM   #18
General Contractor
Willie T's Avatar
Yes, exactly. The edges of all interior ceilings should be left to float for 7" or more. (I think 12" is the limit for doubled lids) The clips keep them from sagging, and also hold them in their originally 'mudded' locations when the trusses 'uplift' every year so those edges won't crack.
Same idea for vertical 'mudded' wall corners. They even make clips for these corners, though I don't think they are really necessary.
Notice in the photo below that this wall was probably built about 1/4" to 1/2" shy of touching the trusses. (considering the DW thickness)
The Following User Says Thank You to Willie T For This Useful Post:
Old 02-03-2010, 11:08 AM   #19
Thom
thom's Avatar
Block between trusses with 2X6's which overhang each side of the interior wall. The edge of the drywall is nailed/screwed to the blocks, not the truss. Because the blocks are attached to the wall this will keep the joint from cracking. The next set of nails/screws must be about 8" out and attached to the truss. This 8" piece of sheetrock, with one end attached to the wall/block and the other end attached to the truss will flex to allow the truss to move up and down.
The 2X6 blocks should fill the space between trusses, generally 22-1/2". The trusses should slide up and down in the space created but should have no lateral movement. Do not nail the truss to the block.
thom is offline
The Following User Says Thank You to thom For This Useful Post:
mics_54 (02-03-2010)
Old 02-03-2010, 11:14 AM   #20
General Contractor
Willie T's Avatar
That's one of the methods we used before the clips came along. But the clips cost so much less, and are easier and faster to install when the cost and time of cutting up blocks is figured in.
Need a "flat" roof Guru... Bill Z Roofing 31 08-15-2011 08:16 PM
Safe Roof Cleaner looking To Network With Roof Contractor. 4thGeneration Roofing 4 09-25-2009 11:43 PM
pulldown stairs and roof trusses 24" oc ezj62 Roofing 14 01-30-2009 09:23 AM
Metal roof question Burby Roofing 11 01-22-2009 01:16 PM
roof hacks.......OMG mikeybobo Roofing 27 01-04-2009 05:14 AM
