Reverse Gable Porch Roof
Old 07-18-2007, 03:50 PM   #1
Master Mechanic's Avatar
Trade: Home Improvement Contractor
Rewards Points: 75
Hello
Master Mechanic is offline
Old 07-18-2007, 07:50 PM   #2
K2's Avatar
Trade: Colorado master electrician, EC, B-1 GC
Rewards Points: 2,000
Re: Reverse Gable Porch Roof
Originally Posted by Master Mechanic View Post
I'm installing a revrese gable porch roof. I'm going to use fastners to support the both gables for sheer resistance. For supporting the header on the brick wall side I have to use 2 2x4's against the brick and I'm going to cover them with columns. Now, my customer swears the by "talking" to other contractors there is another way of supporting this roof. This is an existing brick house that I'm installing this roof on to. The only other way I can do is is by opening up the brick and running the header through the wall and supporting it by opening the interior wall and adding another header/or 2x4"s inside the wall. That would be a lot more money. Tell me I'm right, she also wanted me to install a ridge vent to let the "hot air" out. Can someone please I'm right so I don't lose my sanity,
Larry
Aiello Contracting Inc.
I'd probably go for a pocket in the brick unless I'm missing something.
K2 is offline
Old 07-18-2007, 07:51 PM   #3
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
I can't picture what you're doing, what is a 'reverse gable roof'?
How would a header be hidden by columns? I'm confused (often?)
reveivl is offline
Old 07-18-2007, 07:55 PM   #4
Tom R's Avatar
Rewards Points: 2,036
It's a gable roof perpendicular to a gable roof.
Picture a cape cod with an A-roof coming off the front.
(at least, - - that's what I'm picturing, - - I think the term 'reverse gable' defines the way the 'back' of it dies into the existing roof)
Tom R is offline
Old 07-18-2007, 08:03 PM   #5
go do it's Avatar
Trade: general contracting
Rewards Points: 258
are you calling a hip roof a reverse gable?
i have nerver heard of that term before.
if i have the picture right you want to support the rafters with a beam that runs back twoards the house that has a brick veneer, and support these beams with 2-2x4's that will be covered with a column of some type.
if that is right i think that is one way of doing it.
but i would not attach the 2x4's just to the brick veneer. i would drill and lag bolt to the framing in the wall.
also provide a spot footing for the 2x4's
go do it is offline
Old 07-18-2007, 08:16 PM   #6
go do it's Avatar
Rewards Points: 258
you were right tom
http://www.homedesignersoftware.com/...?faqNumber=456
my suggestion would still work though.
just one way for this situation
go do it is offline
Old 07-18-2007, 10:49 PM   #7
K2's Avatar
Pretty good chance you'd hit air.
K2 is offline
Old 07-18-2007, 10:52 PM   #8
K2's Avatar
What'sa Cape Cod??? Sounds like fish.
K2 is offline
Old 07-18-2007, 11:10 PM   #9
go do it's Avatar
Rewards Points: 258
never know what you will find untill you drill it
kind of like picking up a girl at a bar
go do it is offline
Torch down(flat roof) leaks BAD...can you give advice ASAP? Detail Guy Roofing 22 01-05-2013 06:42 PM
NEED PICS OF ROOFS WITH SHINGLES WITH A TIN PORCH ROOF please read TurnkeyConst Construction 1 07-30-2007 12:22 AM
Low Pitch Roof solutions Fixer Roofing 4 02-18-2007 11:09 AM
Raising a porch roof paintr56 Construction 5 05-10-2006 06:43 PM
Do You Need A New Roof ??? Perfect Roofing Roofing 0 02-10-2005 02:46 AM
