I used to think so.......
Remodelling New Framing
Framer builds front entry as directed by GC.
HO would like it bigger. GC tells framer to make it bigger. Framer makes it bigger. For me that's....Think it. Draw it. Build it. Think it [more]. Draw it [again]. Build it [more]. My main concern was...do I tear it all down and start over - 2 days at least and try to salvage some materials. Or could I add on to it without creating an elephant of weight up there - 1 day tops and less material waste. PS. I like it bigger. Here's the pix. Fire away. The Original - 8 foot span over beams The MOD - 10'-2 1/4" over both new beams Last edited by wallmaxx; 01-15-2009 at 03:02 AM. |
Re: Remodelling New Framing
Nice work, for a framer.
Steve
Will the Ho want the support posts moved farther apart? Do you have any straight on shots of new config?
There will be two posts on the left and two on the right - pairs.
The inner posts will be bearing...the outer for show. |
Nice save.
And a neat "WTF" for some future remodeling guy to scratch his head over!
Mod / ArchiBuilder
Great job, figuring out how to work with the existing.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
Latest Pics
Lessons learned. Huber Zip Roof system breaks down when installed in the rain. The tape DOES NOT stick!! |
Trade: Residential Remodeler
Very creative solution.
Thanks for the comments. My brain is tired. That Zip tape doesn't stick to the wood in thick fog either....so that's what is chappin' me right now.
This is what I like about this CT forum. We can share our collective experiences and be somewhat "ready" for the next hiccup. In my younger days I would have been p*ssed about having to redo perfectly acceptable work. But my best friend taught me...if they are paying you to do it over...do it and get paid. |
Professional Instigator
How big are the columns going to be or the tops and base?
The width of the overhangs where the columns are going to set to support it looks awfully wide in one of the photos. Wondering how it will look with the columns under it. Just thinking out loud again Last edited by rbsremodeling; 01-15-2009 at 10:41 PM. |
#11 | |
Re: Remodelling New FramingQuote:
#12 | |
Its supposed to be twin columns on each side...some kind of structural architectural thing...GC hasn't been specific as of yet. Last edited by wallmaxx; 01-15-2009 at 11:26 PM. |
Trade: Home Builder
Since framing techniques are obviously different in different parts of this country, I would like to ask you a question.
What do you call the 2x you have nailed flat in the valley that the seat custs of the rafters sit on? Do you have a quick method of finding how far back from the actual valley to nail it down, so that the roof plane lands in the valley (if that 2x is just square cut)? That may sound "dumb", I know. I am a little embarrassed to ask. In Wisconsin around my area, nobody does that. We snap our valley lines and then nail the rafters on the sheathing in the valley. I have seen that flat board used in valleys in other pictures and videos around the web. I like the idea of using it. If you have a quick method of locating it and it's name, I would appreciate it. Before anyone wants to take my ignorant question as a chance to jump on me, I have been framing houses since the 80's. In Wisconsin, we are governed by the UDC, not the IRC, so no it is not illegal per our code and therefore I don't do it "wrong". We also build all of our buildings with trusses. Most builders order a "valley kit" which is a set of trusses which are progressivly smaller which get fastened to the other trusses to form the valley. Myself, I don't like the valley kits so I (as well as many others) hand frame our valleys and we land our valley rafters on the sheathing. That board would make for a stronger valley that wouldn't be so spongy and I wouldn't have to worry about the ice & water or the shingles breaking/tearing when someone walks up the valley later. Sure, my way is legal and passes inspection and meets the requirements of 40 psf, but I like that way and am willing to learn a new trick and put out a better product. That is if someone is willing to teach an old dog a new trick. Btw, nice fix wallmax. A lot faster than having to tear down the smaller structure and start from scratch. Very creative. |
#14 | |
It is what it is
Trade: Roofing, Remodeling, Concrete
Looks good
Patriot Broadcasting Network |
For this application I just visually plane across the top of the porch rafters and have someone adjust the lay-on valley board accordingly. I was never taught to pop a line, since the board has "thickness" a popped line would be in the wrong location. You could also use a level, as a straight edge, across the top of the intersecting roof system.
A big wannabe
Trade: Framing, decks, trim, Remodels, ground up.
I call it a valley pad. I do it just like wallmaxx but alot of times I do pop a line as both an angle finder and a reference line. I than take the top edge of the pad and butt it into the ridge. Plane the top edge of the pad with the top edge of the ridge and measure to my popped reference line, making it the same all the way down and checking it at the plate line before I nail it off.
#18 | |
#19 |
Trade: Home Builder
Thanks for the responses!
Some of you guys discussed a 1x10 as a "valley pad". In the picture wallmax has, it looks like 2x material. I suppose it is personal preference which to use or convienence of which is on hand. Thanks for the replys and maybe my next hand framed valley I will give this a try. I like the concept of stiffening the valley better than what I have been doing. No, "valley pads" are not required in all fifty states. (yet) Like I said, Wisconsin uses the Uniform Dwelling Code as its building code. I know most of you guys talk about the IRC, or something similar. I don't know if those two codes are related or if one is derived from the other. Either way, my code does not require them. Let me also state that all codes are the minimum. Just because something is required doesn't mean that I can't do it to offer a better product. It would probably blow your mind what isn't required with trusses and what we do with them, yet still obtain our 40psf. It isn't that we are incompetent, it is that we were taught that way and no other way is required. Doesn't necessarily mean it is "right" either. So again, thankyou for your patience for explaining something that is probably pretty common knowlege with you guys. |
#20 |
Who erases all the pencil marks and measurements written everywhere?
| Bracing pyramid hip framing please help. | TurnkeyConst | Framing | 15 | 06-24-2011 11:30 PM |
| Licensed and Regulated Framing?? | wallmaxx | Carpentry | 17 | 01-05-2011 09:56 PM |
| hilti framing gun? | mikeybobo | Framing | 8 | 10-02-2009 05:22 AM |
| Looking framing works in NJ/PA/MD. | User16938 | Help Wanted or Looking For Work | 0 | 10-26-2008 06:48 PM |
