Reinforce Floor Joists Under A Jacuzzi?
Old 08-21-2008, 07:48 PM   #1
Newbie
Kevin75's Avatar
Trade: Home Renovations
I have a client that wants a two person jacuzzi installed in the bathroom on the main floor of a ranch house with a basement. Maximum floor loading would be 59lbs/sf. How do I determine for certain whether I need to reinforce the floor framing for this? Are there any "rule of thumb" methods when installing a jacuzzi, or is always a matter of checking span tables? Also, my copy of the 2006 IRC shows span tables for 30# and 40# live loads. How can I use this when the jacuzzi has a load of 59#/sf?
Thanks,
Kevin
Proverbs 18:9 "One who is slack in his work is brother to one who destroys."
Kevin75 is offline
Old 08-21-2008, 07:59 PM   #2
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
Re: Reinforce Floor Joists Under A Jacuzzi?
Sounds light for a whirlpool tub... How many gallons?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 08-21-2008, 08:17 PM   #3
Newbie
Kevin75's Avatar
These are Jacuzzi bath tubs....not your large 6 or 8 person hot tubs. The units vary from 58 to 89 gallons. Those load numbers are on the Jacuzzi "Espree" product specification sheet. All the models vary between 51 and 59 lbs/sf for floor loading, so I assumed the highest. The homeowner didn't choose a model yet.
I just looked at this link (as opposed to the folder from Lowes!) and found a discrepancy in the loading for one of the units.
http://www.jacuzzi.com/pdf/ESPREE.PDF
The max for the 60"x42" model is listed as 52 #/sf in my brochure and 67#/sf in that link. I'll have to double and triple check these numbers once the homeowner chooses a model.
Kevin75 is offline
Old 08-21-2008, 08:19 PM   #4
BirmanBuilders's Avatar
Trade: Framing
in new construction we usually double the joists under the tubs.
If at first you don't succeed hit it harder!
BirmanBuilders is offline
Old 08-21-2008, 08:29 PM   #5
Newbie
Kevin75's Avatar
I could sister joists once I open the floor up, but I think I'll be hard pressed to get them doubled for the full span since the basement is finished. (Drywalled ceiling) Would sistering the joists in mid-span do anything other than reduce deflection and add dead weight? I can't imagine they would increase the load carrying capacity of the beams since they wouldn't extend full-span.
Kevin75 is offline
Jacuzzi 2 pole 20,30 Bkessler Electrical 10 06-10-2008 03:45 PM
jacuzzi install question shazamyman Plumbing 8 05-04-2008 11:49 PM
reinforce floor for fireplace insert install 72chevy4x4 Framing 3 09-09-2007 03:22 PM
Floor framing support for a jacuzzi FMKConstruction Construction 2 01-18-2007 12:11 PM
