Raising A 78-inch Ceiling (entire House)
Old 08-14-2009, 01:23 PM   #21
Re: Raising A 78-inch Ceiling (entire House)
Originally Posted by Joe Carola View Post
Are you saying to drop the grade in the basement 30" ? If so, you would have to underpin the entire foundation because your exposing the existing footings and going lower then them.
I'm trying to find out how the guys
wanting to drop the elevation of the
entire first floor are planning to deal
with the exterior grade.
Sounds like they are proposing that he
turn it into a sort of "garden level"
affair.
Just wondering what I missed.
neolitic is offline
Old 08-14-2009, 04:46 PM   #22
KennMacMoragh's Avatar
Trade: Repair/Remodel
Send a message via MSN to KennMacMoragh
entire fist floor are planning to deal
affair.
That's where you need to be creative.
KennMacMoragh is offline
Old 08-14-2009, 04:52 PM   #23
I don't, he does.
neolitic is offline
Old 08-14-2009, 10:47 PM   #24
General Contractor
Willie T's Avatar
Location: St. Petersburg, FL Minds of moderate caliber ordinarily condemn everything which is beyond their range.
It CAN be done. Whether legally or not..... ???
"True eloquence consists in saying all that is necessary, and only that which is."
François Duc de La Rochefoucauld
Bill Everett - St. Petersburg, FL
Willie T is offline
Old 08-15-2009, 11:17 AM   #25
LetItBeLEED's Avatar
Trade: green building
Great ideas, however cranes are not an option because the driveway includes a narrow bridge across a mountain stream. Location of the house at least is central PA. There is a basement... it's not quite a walk-out. There's a lot of foundation wall exposed in front and the grade in back is 12" below the sill... but the lay of the land is such that we could drop in back 24" or so, so the notion of dropping the floor joists into the basement is interesting, but would require a lot of electrical/plumbing/HVAC. LoneFramers idea of LVLs on the top plate is interesting also. Thanks for the great ideas to check out.
LetItBeLEED is offline
Old 08-16-2009, 07:28 AM   #26
72chevy4x4's Avatar
least expensive method might be to drop the floor system down 18" assuming you're high enough above grade. If you're in an area that requires permits and engineer specs for work, an engineer's report may be necessary to confirm the foundation is up to the added weight of 'lifting' any portion of the house, at which time you may be required to bring it up to spec, assuming a 100yr old foundation is NOT up to today's specifications.
have you considered building an addition onto the place and converting the 6.5' tall space into bedrooms for the kids?
how tall are the doorways on the first floor? I would imagine less than 6'?
72chevy4x4 is offline
Old 08-16-2009, 08:03 AM   #27
Home Work Pro's Avatar
Dropping the floor into the basement doesn't make sense. You would ruin the basement space and you would end up having to make a ledge around the perimeter. Not to mention door issues and steps.
I think Lone's idea is the only one that makes any sense but I would raise all load area's with steel beams. They could be easily posted and enclosed.
Extend all mechanicals in the 1st floor walls, rebuild the step area, repair the exterior and repair or re-drywall the 1st floor.
Or just rent it to short people.
Home Work Pro is offline
Old 08-16-2009, 09:45 PM   #28
72chevy4x4's Avatar
I would think it likely the basement is not full height...maybe the OP can comment
Old 08-16-2009, 10:01 PM   #29
ClemS's Avatar
Trade: Framing
didn't think anyone in 1910 knew what platform framing was. correct me if I'm wrong.
ClemS is offline
Old 08-16-2009, 10:17 PM   #30
Grand Rapids Remodeling
Paulie's Avatar
Why change it? Does the proposed change justify spending all that money on a 100 year old house? I guess everyone will have their own answer but for me I wouldn't even think about it.
Paulie is offline
Old 08-18-2009, 10:35 AM   #31
JamesKB2's Avatar
Trade: GC Residential / Light Commercial
I think you're right Clem. That is most likely a balloon framed structure.
If it is, raising the second floor off the "supposed" top plate of the first floor walls is not an option, because there won't be any top plate there.
More than likely the floor for the second story is ledger, either let in or sistered to studs.
I'd have to see it to come up with a viable solution. There might not be one!
I will build you whatever you want, just draw it on the back of a big enough check.
JamesKB2 is offline
Old 08-18-2009, 10:53 AM   #32
Well, the date of construction was just a guess, and probably a dumb one based on Clem's comment. It's a platform. The basement is same height as the other floors, BTW.
Another issue, of course, with lifting the 2nd story is changing the footprint of the stairs which would have to be redesigned since otherwise they'd extend into the kitchen or the doorway to the kitchen. It's busting the bank, though I still may ask some hand-tool weilding Amish guys what they'd charge to do the lift the old way.
LIKELY CONCLUSION: the short people can probably talk us down in price.
THANKS FOR THE IDEAS FOLKS!
LetItBeLEED
Old 08-18-2009, 11:13 AM   #33
JamesKB2's Avatar
Well, if it's platform, then it could be done. You still have utilities to deal with too, wire runs will be short, HVAC changes, plumbing if there's a bath upstairs.
If you didn't buy it right, with a gut and jack in mind, you're not going to do well with it. Stairs are just one of the worries.
I'd have bought it cheap if it was burnt out, with a total gut in mind. Otherwise....
JamesKB2 is offline
Old 08-18-2009, 11:13 AM   #34
New and Remodel Carpentry
cooks's Avatar
Trade: General Contractor/Remodelor
just jack the second floor. cut out the short walls and drop second story to first floor level. then build addition next to it and use doors and windows from cut out section if you want them to match. problem solved.
cooks is offline
Old 08-18-2009, 11:51 AM   #35
LetItBeLEED
This is far from comprehensive,
but it's a start when trying
to guess a date.
(Toilet tanks have long had the
date stamped inside,which can
at least help date the last remodel.)
http://www.inspect-ny.com/interiors/AgeofHouse.htm
neolitic is offline
Old 08-18-2009, 03:36 PM   #36
Thanks for the toilet-tank tip, Neolitic. I never realized that.
Cooks, good idea but the edges of the rooms are under sloped rafters + dormers. Of course, you didn't know that since I left that detail out of my prior posts. Simply removing the first floor and setting the second floor on the foundation would make for a very strange look.
Thanks again one and all.
Old 08-18-2009, 03:43 PM   #37
LEED,
You did notice the link too
didn't you?
neolitic is offline
Old 08-18-2009, 04:04 PM   #38
Interior Renovations
KellyD&B's Avatar
You can always go from a 2 story with low ceilings to a 1 story with high ceilings...
KellyD&B is offline
Old 08-19-2009, 01:03 PM   #39
Nailerconstruct's Avatar
Trade: Framer from head to toe!!!
Revised
Tear it down and start fresh or keep it the way it is.
Nailerconstruct is offline
Repairing freeze damaged plumbing -whole house. matt832 Plumbing 5 08-09-2009 03:23 PM
paint flaking from the ceiling...cause/solution?? lornmastro Painting & Finish Work 26 03-06-2009 03:14 PM
Inexpensive sprayer for a ceiling roof-lover Painting & Finish Work 6 01-22-2009 07:41 PM
Suspended Ceiling Costs ?? SBI Drywall 4 08-22-2008 10:50 AM
Raining in the House oldfrt General Discussion 9 11-07-2007 11:10 PM
