Rafters 16" Or 24" Centers
Old 09-14-2009, 08:55 AM   #1
dvd's Avatar
Trade: contractor
I have a roof plan for a cut up roof but it is laid out on 24" centers. Do you guys frame rafters with 24" centers or 16" centers it is a 12/12 hip style roof with several of the common rafters at 28' long (10 of them) I will be using 2x12's to frame roof. Also do you put your ceiling joist on 24" also or 16"? Thanks for any help.
dvd is offline
Old 09-14-2009, 09:32 AM   #2
KentWhitten's Avatar
Re: Rafters 16" Or 24" Centers
24" oc is fine.
Salmon Falls Cabinetry
KentWhitten is offline
Old 09-14-2009, 09:34 AM   #3
Builder/Remodeler
ChrWright's Avatar
Trade: Builder/Remodeler
Send a message via Skype™ to ChrWright
What will your roofing material be?
Asphalt? Tile? Slate?
Christopher Wright, CR: President @ WrightWorks, LLC/President @ Central Indiana NARI, Named to the 2010 REMODELING Big50
www.WrightWorks.net - Facebook - Twitter - Carmel Remodeling
Indianapolis Kitchen Remodeling Contractor - You Can Get There From Here
ChrWright is offline
Old 09-14-2009, 09:37 AM   #4
SC sawdaddy's Avatar
I like 16" on rafters
24" on trusses.
Just my method.
Democracy is two wolves and a lamb deciding what's for dinner.
Liberty is a well-armed lamb contesting the vote.
SC sawdaddy is offline
Old 09-14-2009, 10:21 AM   #5
Sagebrush48's Avatar
Trade: comercial drywall and acoustical ceilings
Thumbs up
your ceiling joist should be same as rafters. remember your rafters and joist should be sitting on your wall studs. so if your wall studs are 24" on center than your joist and rafters can be also. if wall studs are 16" than so should your rafters and joist.
Sagebrush48 is offline
Old 09-14-2009, 10:31 AM   #6
dvd's Avatar
Trade: contractor
roof covering material will be asphalt shingles and 5/8 osb
dvd is offline
Old 09-14-2009, 10:32 AM   #7
I used to think so.......
wallmaxx's Avatar
24" requires clips or thicker plywood. It's nice for fat guys to get through the rafters easily.
16" is what I grew up with and prefer. No clips, the plywood lays stiffer.
Check with your surrounding stick framers. Find out what is "the standard" is, and then build above that.
wallmaxx is online now
The Following User Says Thank You to wallmaxx For This Useful Post:
dvd (09-14-2009)
Old 09-14-2009, 10:47 AM   #8
dvd's Avatar
Trade: contractor
I will go with 16" just the homeowner noticed on the plan 24" centers and thought I was overbuilding. But I will go with 16" as most do. Thanks to all the replies I appreciate professional opinions helps give one a good direction.
dvd is offline
Old 09-14-2009, 11:04 AM   #9
ARI001's Avatar
If the plans call for 24" oc then that is how you should install the rafters. I would assume you bid the job based on the plans and specifications. If so by putting the rafters on 16" oc you are costing yourself money in both time and materials, not to mention legally you must do a change order whether you intend to charge for the difference or not. Just a tip: You should make yourself familiar with all the specs and drawings before bidding and refer back to them constantly while bidding any job that has them. You should also review them on the job at least once daily.
ARI001 is offline
The Following User Says Thank You to ARI001 For This Useful Post:
cbfx3 (09-14-2009)
Old 09-14-2009, 11:04 AM   #10
mics_54's Avatar
Trade: contractor
Where is it? Nobody cares about energyand heat loss? I thought energy was the big thing these days?
mics_54 is offline
Old 09-14-2009, 11:29 AM   #11
dvd's Avatar
Trade: contractor
So even if wall studs are at 16" centers still build the roof with 24"centers? The rafters will not land ontop of wall studs but it will have double top plate.
dvd is offline
Old 09-14-2009, 11:44 AM   #12
UpNorth's Avatar
Trade: Engineer & Ret. GC
Why in the world are you asking virtual strangers?
As they say in cards, who dealt this mess? Is there an architect? How about an engineer? How about a responsible building inspector? What about your local building code?
Roofs are framed at 24" centers in virtually every part of this huge country, from the deep snow country, down throught the great plains, into the deserts and river bottoms, hurricane country, earthquake country, and more. This, all atop bearing walls framed at 16" centers.
Here, with huge snow loads (90 psf at ground), roof framing is routinely done at 24" centers, and the sheathing is 5/8" OSB. And everything built here has to exhibit the wet seal of a NY state PE or architect.
You need a local pro to advise. Not someone from here.
UpNorth is offline
Old 09-14-2009, 12:13 PM   #13
ARI001's Avatar
Regardless of how it is done and the location it is done in the approved plans and specifications are what you need to follow. If you question the spacing of the rafters do so to the person who specified it. Then if the spacing is changed do a change order and adjust your bid accordingly. It does not matter what anybody here or anywhere else has to say about the spacing. You have the approved documents in your hand and those are what you need to follow.
ARI001 is offline
Old 09-14-2009, 12:24 PM   #14
Birch's Avatar
(Is this your first time?)
Read your framing specifications.
I agree, if you need to ask, ask a locally recognized expert, like the local building inspector or permitting authorithy. Either 24 or 16 centers on rafters is typical, or common practice. I prefer 16 on studs and joists with rafters at 24, joists stack next to studs and rafters stack directly over studs, 24 o.c. rafters stack over studs every other rafter layout, or 48" o.c.
I always layout studs under rafters, but not always on the same o.c. spacings.
Birch is online now
Old 09-14-2009, 01:20 PM   #15
knucklehead's Avatar
Trade: Framing,Remodeling,General Contractor
If it is my choice, I will go with 16" 90 percent of the time.
You can span farther without purlins.
You don't have to use clips on sheeting. Although I will use 2 clips on a sheet so you get the proper spacing.
No 'lateral support " between the joists and rafters needed.
knucklehead is offline
Old 09-14-2009, 01:39 PM   #16
dvd's Avatar
Trade: contractor
Thanks for all your responses all of you have a good point I will have a 18'6" horizontial span for the rafters and I will be using a 2x12x28 to get the length I need on several of the rafters that will run from ridge to outside wall plate. most of the others will cut into hip/valleys. I would rateher overbuild and be safe as to meet code and possibly have sags, dips, etc. You guys ever had any problems using 24" with 5/8 and clips?
dvd is offline
Old 09-14-2009, 05:26 PM   #17
Warren's Avatar
Trade: framing/remodeling
I use clips on 16 oc also. At least on the ends. It helps with keeping the plywood evenly spaced.
to the guy who said if your walls are 16, then your rafters should be too, what about trusses?? Cmon dude!
Warren is online now
Old 09-14-2009, 05:36 PM   #18
Joe Carola's Avatar
Trade: Framing Contractor
It's a Regional thing. We never frame rafters 24" centers. If your plans are drawn by anArchitect, why are you nopt following them and puttinmg them 24" centers? The day I get plans with rafters 24" centsres, that's when I'll frame 24" centers. I did get a plans 24" centers a couple years ago on an adsdition. Clips suck.If you frame 24" centers all the time, they probably don't suck.
Bottom line for you is if it's on the set of plans drawn by an Architect you have to follow them and can't change them unless the Archy agrees and signs off on them. Also as you've been told framing 24" centers is no problem anywhere so far.
Joe Carola
Joe Carola is offline
Old 09-14-2009, 05:38 PM   #19
Joe Carola's Avatar
That's not true at all.
That's not true either. Houses are framed every day with 16" center walls and 24" centers rafters as you have read on this thread.
Joe Carola
Old 09-14-2009, 06:32 PM   #20
cbfx3's Avatar
Trade: Framing and General Construction
I'd do it like the plan... easier for you.
cbfx3 is offline
sagging hip rafters CharlesD Framing 23 07-14-2009 10:51 PM
joist centers using 3/4" cedar Old Sawdust Decks & Fencing 32 12-02-2008 09:52 PM
shallow roof and sagging rafters boman47k General Discussion 0 11-20-2008 12:14 AM
Cut rafters sit on wall top plate or on top of floor sysstem? wallmaxx Framing 21 07-31-2008 09:38 PM
Why 16" centers TNRocks General Discussion 32 01-21-2008 12:36 AM
