Plywood Direction Effect On Floor Bounce Over I-Joist
Old 12-30-2008, 08:12 PM   #21
I used to think so.......
wallmaxx's Avatar
Re: Plywood Direction Effect On Floor Bounce Over I-Joist
there is no grain in obs or any pressed product. Staging a lam at the mid point or close reduces deflection to almost nothing. read you stuff. lateral movement is gone with brid
ing. Think before you speak? ugly dog also?
OSB
oriented strand board...the fibers are laid down somewhat directional in the glue before pressed. Over 14 1/2", the plywood is weaker one way than the right way.
I just went through this last week, decking a house. The cut guy was trying to use up all the scrap rather than cut full sheets. He sent me up a triangle cut from the plywood in the wrong axis direction. I asked for a new piece and had to explain that it was too weak to walk on.
Sorry B-man. "Your data on the Mig is inaccurate."
And what's with dis'in a man's dog? Be nice...be professional.
wallmaxx is offline
Old 12-30-2008, 08:36 PM   #22
borat_borat1950's Avatar
Trade: framing
OSB =
1 Question, why are all you GC's on the framer forum? You screw us down on footage and then come here to rub it in on how stupid we are!! Nathan needs to create a forum for GC's who are all about themselves. I may get cut and thunked as the mod said, but I'm not backing down from GC's who no nothing!!
borat_borat1950 is offline
Old 12-30-2008, 08:52 PM   #23
Originally Posted by personalt View Post
The 9 1/2" ijoists I am using are rated for a 16' 8" span for L/480 deflection..
The house spans about 28 feet in width. In the back part of the house I ran the ijoists accross the house and there is a middle wall supporting the ijoist midspan.. That section of the house is fine as far as boucing.
However the front part of the house there is one room accross the whole 28' feet. This room is abot 14' deep. In this section of the house I ran my i josts front to back from the front of the house to a steel renforced LVL. This area bouces.. When looking at it from below it is not the beams that are bouncing but the ijoists itself.
I think this might be why, I started applying subfloor in the back of the house with the plywood going front to back (accross the joists).. However for the last 14' I continued running the plywood front to back (with the joists). In that area I have the bounce. Does running the plywood with the ijoists contribute to floor bounce? Everything is laid out correctly such that all my long plywood seams split the ijoists. Everything is glued and the crap was nailed out of it.
Is the direction of the plywood the major factor here?
I have three possible soltions
-Renforce both sides the I joist on both sides with rim board to make them stiffer. This is what is shown in GPs manual as a way to renforce cantilevers so should be helpful
-Add blocking at the mid point. I think this might be helpful as the ijoist seems to roll slightly as it starts to sag plus tieing them together will distribute the load somewhat.
-Add new i-joists in between these making the ijoists 8' on center at that point.
- Add filler block and anohter i joists (double them up).
Any recomendations? I dont like the idea of going 8" on center as that will make hard for highats.
Adding blocking is cheaper then renforcing but if I need to reinforce the ijoist after adding the blocking I will end up ripping the blocking back out. So maybe add the rim board to both sides of ijoists first and if that doesnt cut it I can then add blocking to that?
Was not changing my plywood direction when the joists changed direction my problem here?
gp manual is here(page 23 of 56 shows the method I was thinking)
http://www.gp.com/build/product.aspx?pid=1390
The joke is you!
Doesn't matter how many micro-lams
one puts under joist, if the plywood
runs the wrong way.
BTW: The OP is 14 months old.
Maybe it's been taken care of?
I don't know about "obs," but OSB
is called Oriented Strand Board, and oddly it is oriented.
However you are the only one talking about
OSB.
The OP referred to plywood, or didn't you notice?
neolitic is offline
Old 12-30-2008, 09:07 PM   #24
Dan_Watson's Avatar
http://www.fpl.fs.fed.us/documnts/fplrn/fplrn059a.pdf
http://www.tecotested.com/techtips/p...signcapacities
http://www.tecotested.com/techtips/p...plicationguide
http://www.lowes.com/lowes/lkn?actio...ld/GdPlWd.html
http://www.apawood.org/pdfs/unmanaged/strucii.pdf
They all say the same thing. Plywood has a strength axis:
Sheets and/or layers of veneer are typically oriented with their grain at 90 degrees to each other and arranged in an odd number of plies or layers, resulting in a structural panel that has its greatest strength axis in the direction parallel to the face grain (typically the 8' direction).
And as stated before and seems to be overlooked, if H clips were not used the bounce could be from the lack of a lock between the individual sheets of ply since the T & G is over the 8' length. The bounce may have been between those sheets and not the entire floor.
Dan_Watson is offline
Old 12-30-2008, 09:12 PM   #25
wallmaxx's Avatar
Are you something special...specialized?
I have been a framer since 1989. Recently I have had the opportunity to take on larger and or different projects than "just framing". In WA state, the law is, if you are going to be licensed in more than one specialty...you need to up your bond and insurance amounts and become licensed as a general contractor.
You are starting to sound like one of those "know it all framers." Whining about "all the GCs." Go, make your money and have a great life. Throwing tude here is a real sign of weakness.
You might know some things...and then again I'm sure you don't know everything. I was working hard at giving you a chance...but in my book, you are representing yourself poorly on this forum and I'm done.
Maybe your momma failed to teach you the golden rule as a boy. Where does it get you in life to be an azz all the time?
wallmaxx is offline
Old 12-31-2008, 05:28 PM   #26
Joe Carola's Avatar
Trade: Framing Contractor
Originally Posted by Joe Carola View Post
Your not supposed to run plywood with the joists, period. You've probably voided the warranty on the I-joists also by doing that.
So when you spout off about plans and spec's and engineers, and then in the next word say the framer has to check everything or he's ****. Just think to yourself, AM I REALLY A GOD OF CONSTRUCTION, or just someone blowing thier piehole!!!!! To me your a joke.:laug hing:
I said probably because about 16 or 17 years ago when we started using I-joists this came up in a conversation one day when some homeowner ran the plywood with the I-joists and a builder who was a framer for 20 years before that said that he thinks that it would probably void the warranty.
It was the first and last time this ever came until this thread because no one ever runs plywood with the joist that I've ever seen whether you use I-joists or 2x joists. Will it void the warranty, I really don't know or care because it would NEVER be an issue, or be talked about.
As far as your other comments, you talk like your 10 and obviously are ignorant and lack social skills and you apparently think who you are when it comes to framing, I don't. Your thread about, "I'm new to this forum" was a complete joke and you embarrassed yourself.
I am a framer. This is a framing forum, where do people like carpenters, remodlers, roffers,(yes I spelled it right), BUILDERS (THE WORST), and anybody else who is not a framer, get off on giving us framing advise!!!
I will take advise from anyone who is not a framer if they give one and it sounds like a good one. I don't think I'm above anyone or that juvenile thing you said, "God of construction" or whatever. You said this because I just said that a framer should know how to frame the correct size stairwell? That's all it was, plain and simple!
Do you want to sit here and try to go toe to toe with me as framers or do you want to try and compare notes and help each other out with anything that has to do with framing? Or, do you want to keep talking like this?
Joe Carola
Joe Carola is online now
no plywood? phinsher Roofing 28 04-18-2010 06:48 PM
RO Sander Orbit/Disk cutting direction... Ted W Tools & Equipment 0 03-10-2007 05:12 AM
Floor Joist dante1 Flooring 0 02-14-2007 06:02 PM
3/4 Hardwood laid parallel to joist? pburchett Flooring 9 10-08-2006 11:37 AM
HELP! HELP! Joist Hangers allsolutions Construction 19 05-27-2006 11:08 PM
