Plunge Router - Anybody Use It For Framing? - Framing - Contractor Talk
Old 03-22-2015, 01:08 PM   #1
MattK's Avatar
Trade: Framing, Roofing, Siding
Rewards Points: 1,096
As I'm sure many of you do, I receive 'Tools of the Trade' magazine quarterly. In the recent addition, the magazine was covering tools a framer carries and one in particular is a plunge router with a flush cut bit.
The magazine says he uses this for cutting window and door openings without the need for any sheathing layout, either cut to fit pieces or snapping lines for circulaw saw cutouts...this eliminates both. It says it's faster, much neater than the sawzall and chainsaw applications.
Thinking about when I used to frame full-time, I can think of multiple applications where this would be beneficial...Subfloors, sheathing gable ends on the ground, window and door openings, etc.
Anyone use this currently and able to back this up? My thinking is I currently have a 1 3/4 HP PC router and small trimmer for other uses. Doubt either would have the strength needed so to switch to this application, I'd probably need a 3+ HP router, as the framer in the article uses.
--MATT
Add your Facebook Business Site to "THE LIST"
http://www.contractortalk.com/f12/if...-should-79504/
Page 77 has the updated, complete list.
MattK is offline
Old 03-22-2015, 01:11 PM   #2
David Festa
festerized's Avatar
Trade: Framing Contractor
Rewards Points: 2,030
Re: Plunge Router - Anybody Use It For Framing?
we sawzall our openings, tried the router once, hit a nail killed the bit never tried it again
festerized is offline
Old 03-22-2015, 01:13 PM   #3
kiteman's Avatar
Rewards Points: 16
I do it about half the time on windows and doors. Just my 1 1/2 (?) craftsman. Never did it for 30 years, always snapped and cut.
An old framer once told me "For years I thought I was the best damn carpenter in California. Come to find out I'm just competent."
kiteman is offline
Old 03-22-2015, 01:16 PM   #4
MattK's Avatar
This is my thinking too. When sheathing, an occasional nail will miss the jack and could be very dangerous to hit with a router spinning at 25,000+ rpm.
--MATT
MattK is offline
Old 03-22-2015, 01:18 PM   #5
David Festa
festerized's Avatar
I have my laborer cut out the windows, keeps them busy and its good practice using power tools and cutting a straight line
Old 03-22-2015, 01:19 PM   #6
MattK's Avatar
So this is a newer method for you then. Obviously, you wouldn't continue if it wasn't more efficient. How does the lesser HP router hold up? Get any bog down on 7/16 OSB or do you notice you have to go a little slower due to the router size? I'll have to experiment with mine, maybe it'll be strong enough.
--MATT
MattK is offline
Old 03-22-2015, 01:32 PM   #7
kiteman's Avatar
Rewards Points: 16
Well, it cuts at a steady clip, won't out run a saw or a stihl, but a nice cut. Cut out before nailing off. I'm using the diablo bits.
Thers been a couple long threads on here pro and con. I'm pro-router now.
kiteman is offline
Old 03-22-2015, 01:49 PM   #8
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,727
Just another one trick pony tool that doesn't need to be taken out every day in my opinion. We tried it, and did not feel like it saved time or increased accuracy.
Easy Gibson
Warren is offline
Old 03-22-2015, 02:01 PM   #9
Texas Wax's Avatar
Rewards Points: 1,132
Amana makes a 2 1/2" - 3" triple flute - big difference in speed of cutting. Woodworkers store or rockler...a little more than the diablos tho.
Texas Wax is online now
Old 03-22-2015, 03:00 PM   #10
C2projects's Avatar
Trade: General Contracting
Rewards Points: 1,084
I used to snap out the doors and windows, I've only sawsalled them when either having to move/add/fix a window plavement. Now I solely rout out windows. And most straight runs. You set a few staples to hold your sheet down then do the rest of the window after you route it. I've never hit a nail/staple. It really probably isn't any faster than an experienced guy snapping and cutting, but its idiot proof. You can give it to your labourer and have him route them out as you staple.
Proper Prior Planning Prevents Piss Poor Performance
C2projects is offline
Old 03-22-2015, 04:59 PM   #11
mako1's Avatar
Rewards Points: 1,094
I've done it several times and found even with a 3 1/4 hp PC router that it is slower and the osb really wears the bits out quick.The bits I wee using were pretty high quality and and I could have bought 3 saw blades for what 1 costs.
I just snap a line and cut out with a circular saw or sawzall.
mako1 is offline
Old 03-23-2015, 11:53 PM   #12
Framer87's Avatar
Trade: Framing
Rewards Points: 1,156
We use 2 1/4 hp dewalt d-handle. Use it for windows and gables. Have had the worst luck with expensive bits and only buy the cheapies now, which last longer. There is no way that we could snap and cut faster than routering openings. And to pull out another tool only happens 3 times per house
Framer87 is offline
The Following User Says Thank You to Framer87 For This Useful Post:
Sabagley (03-27-2015)
Old 03-24-2015, 04:53 PM   #13
marcsmith's Avatar
Trade: carpentry/cabinetmaking
Rewards Points: 34
Just a couple tacks before you route, fairly quick and super simple. Finish nailing after it drops. Its like the drywallers roto zip just a bit bigger.
marcsmith is offline
Old 03-24-2015, 05:26 PM   #14
Framer53's Avatar
Trade: Handyman
Rewards Points: 366
Sorry guys, if you are snapping lines and cutting with a saw, you are behind the times.
We always used proter cable 3 horse and cut everything we could with the router. Stairwells windows, doors, gables etc.
To say it takes more time is ridiculous and you need a larger router.
By the way, the person Tim is a member here and frames some beautiful houses , he is the one that tools of the trade was written by.
Framer53 is offline
The Following 4 Users Say Thank You to Framer53 For This Useful Post:
C2projects (03-24-2015), Framer87 (03-24-2015), marcsmith (03-24-2015), Sabagley (03-27-2015)
Old 03-24-2015, 08:02 PM   #15
MattK's Avatar
I'll definitely mess with it the next time I have the opportunity. If it's the same Tim from Oregon or Washington, I've read many of his articles and believe I've talked to him once or twice on here. Someone(think it was him) was telling me about mass-production, gang cutting ridge rafter cuts with a chainsaw mount for adjusting the angle. Even had a video on it and it's an impressive jig if you could justify the setup time.
--MATT
MattK is offline
Old 03-27-2015, 08:13 AM   #16
Rewards Points: 746
Our Bosch router died last week and I had to go back to the lines and saw method. I hate that method.
Ordered a Makita 3 1/4 hp router and had it 2 days later. In the meantime we sheathed over the windows and routed them after (1st floor so it was easy)
I think we'll be using it today so I'll try and get some video and post it this weekend. It is much much faster and perfectly clean.
This comes up as an argument every so often and I used to jump in. Now to each his own, but you will love using a router. Sheathe your walls while they are on the ground and route them before you nail off. You will love it.
Timuhler is offline
The Following User Says Thank You to Timuhler For This Useful Post:
C2projects (03-27-2015)
Old 03-27-2015, 08:46 AM   #17
kiteman's Avatar
Rewards Points: 16
What he saiid.
kiteman is offline
Old 03-27-2015, 11:27 AM   #18
Talking Head
EthanB's Avatar
Rewards Points: 162
I'm not a framer and I guess it shows here. I cut them out from the inside with a really aggressive sawzall blade so I don't have to bother snapping lines.
I remember using routers when I worked for my first GC though. Having all those OSB chunks down my shirt isn't a favorite memory.
Planer.....
EthanB is online now
The Following User Says Thank You to EthanB For This Useful Post:
festerized (03-27-2015)
Old 03-27-2015, 07:38 PM   #19
SAcarpenter's Avatar
Trade: residential/remodeling carpenter
Rewards Points: 938
I bought a 1/4" shank panel bit for $16. It was the only one they had. I haven't had the chance to use it yet but I'll try it sooner or later. I'm convinced but tryouts to get 25 other guys on board is a whole other story. Not to mention we would the. Have to buy 5 routers and all the bits which i know the boss wouldn't go for
You can rest when you're dead
SAcarpenter is offline
Old 03-27-2015, 07:44 PM   #20
SouthonBeach's Avatar
Rewards Points: 1,027
I think that using a router to cut out the opening is much quicker & you can give to job to a less skilled person to do with little instruction.
I will agree that you need a big hp router to hog it out efficiently.
SouthonBeach is offline
Made in USA product list J.C. General Discussion 361 10-07-2018 11:16 AM
Router bearings shot? dkillianjr Tools & Equipment 8 03-14-2013 11:06 PM
Router talk....101..... PrestigeR&D Tools & Equipment 94 12-16-2012 10:58 PM
spiral bit cutting with plunge router woodworkbykirk Finish Carpentry 10 06-11-2010 04:34 PM
deep plunge with a router rokosz Finish Carpentry 9 11-13-2008 08:29 PM
