Opening Up A Load Bearing Wall
Old 01-18-2011, 01:07 PM   #1
Brandon Goodall's Avatar
Trade: Trim Carpenter
I will admit, I am a trim carpenter by trade, and I love what I do. I recently bought a 50's model basic ranch home, and i want to remove a 12'-16' section of the load bearing wall. I havent done much framing work in quite a few years, so I figured I would throw this out here to see if I could get any good suggestions, from ya'll framers. If i can do this without placing a beam I would prefer to do it that way, with the already low 8' ceilings I dont want to have anymore drops in the ceiling if I can get away with it.
I have added a quick sketch to refrence, hopefully I can get some good ideas, living in an enclosed ranch is not ideal, and I would like to open the flow up as much as possible.
Brandon Goodall is offline
Old 01-18-2011, 01:14 PM   #2
JustaFramer's Avatar
Trade: Exiled For Life
Rewards Points: 2,000
Re: Opening Up A Load Bearing Wall
Get a engineer involved. And ask them to give a shoring plan too. Also you don't take out a bearing wall and replace it with nothing. And your sketch it no where enough to give good advice about what won't get you and others killed. You are in over your head.
JustaFramer is offline
Old 01-18-2011, 01:55 PM   #3
aptpupil's Avatar
Rewards Points: 1,894
yeah, this is trouble. without knowing what is above or below or having a better idea of what existing conditions are, you're not going to get safe advice about something like this. you're likely looking at either a very expensive project or a beam that will take up some ceiling space.
talk to an engineer.
aptpupil is offline
Old 01-18-2011, 02:52 PM   #4
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
I don't think you are in over your head. Just looking for a site engineered solution to a common problem.
If this was my house and I had no fear of working without a permit...
Assuming your working with a stick framed roof;
-Move all your crap the out of the living and kitchen
- Demo the drywall from the ceiling and bearing wall
- remove every 2 out of three ceiling joists
- use the old ones as prop sticks from floor to ridge along side of the ceiling joists you have left in place.
- Tear out the wall
- Clear span properly sized TGI's from rafter to rafter, front to back. Fur out the webs and bolt them to the rafters. Make them as long as you can yet still get them in and have some bearing on the plates
- When you spot several across, remove the rest of the joists, leave a couple posts for good measure and fill in the rest.
- make king posts from ridge to a catwalk on the TGI's. Plywood gussets at the rafters near the ridge and the catwalk to tie them all together wouldn't hurt.
- If your existing rafters are undersized and were framed with mid span purlins, either drop new legs to another catwalk or take the opportunity to sister in properly sized ones before the TGI's go in.
Thats just me though. I wouldn't do it if I didn't have confidence to overbuild while taking a flight on the seat of my pants. Again, my house, no fear about the lack of a permit.
Side note- you could do a more complicated but similar system and get that ceiling up to 9' and create a tray ceiling.
Good Luck
Now that I took the time to give you an answer, do us all a favor; Go fill out your profile and start a thread in the intro section and tell us what your bucket is all about. That is how we roll. Welcome to CT
Gus Dering is offline
The Following User Says Thank You to Gus Dering For This Useful Post:
Darwin (01-18-2011)
Old 01-18-2011, 03:05 PM   #5
Geometrist
Warren's Avatar
Trade: framing/remodeling
Rewards Points: 6,419
Climb up in the attic and see if the house was built with trusses or not. If it is trusses, talk to an engineer to verify that the wall is not load bearing. Remove as much wall as desired. If the wall is load bearing, there is no magic fix. Something will have to carry the load, and be supported from below. If you have a basement or crawl space you can go below and see where the loads will transfer to. If the house is a slab, you may have to cut the floor, excavate, and pour a properly sized footing at each bearing location.
Easy Gibson
Warren is offline
Old 01-18-2011, 03:11 PM   #6
3bar's Avatar
Trade: carpenter
Rewards Points: 460
get in the attic and snap a picture.
if you have trusses, more than likely, just the exterior walls are load bearing, since your span is not that long.
if the roof is stick framed, then you probably only need a beam to support the ceiling joists. you can make the beam hidden, but that would be way more work than just placing it below the ceiling level.
3bar is offline
Old 01-18-2011, 03:12 PM   #7
PaulPrice's Avatar
Rewards Points: 226
if you have trusses, you might not have anything to worry about, although i guess 50's would be pretty early for trusses...... whats the length front wall to back wall?..... you could certainly do what gus was saying but you might be able to get away with conventional lumber if the span is not that great
PaulPrice is offline
Old 01-18-2011, 03:15 PM   #8
Fish Magnet
Cairncross's Avatar
Trade: Finish Carpenter
Rewards Points: 75
I cant tell you how many of my friends have bought a house, and ask me over for advice because they want to remove a wall, and they never do the job. You may not be that guy but thats my experience.
First post and it's for advice...
wardellbuilders.com
Cairncross is offline
The Following User Says Thank You to Cairncross For This Useful Post:
AustinDB (01-18-2011)
Old 01-18-2011, 03:20 PM   #9
Any one want to take bets that the roof is stick framed with 2x6's? There would not be enough bearing for TGIs on the exterior walls
Old 01-18-2011, 04:15 PM   #10
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
Originally Posted by Brandon Goodall View Post
and i want to remove a 12'-16' section of the load bearing wall. I havent done much framing work in quite a few years, so I figured I would throw this out here to see if I could get any good suggestions, from ya'll framers. If i can do this without placing a beam I would prefer to do it that way, .
What do you mean by that? You need a beam whether it's a steel beam or wood beam.
Joe Carola
Joe Carola is offline
Old 01-18-2011, 04:32 PM   #11
Eater of sins.
ScipioAfricanus's Avatar
Trade: Designer/Drafter Extraordinaire
Rewards Points: 1,046
I think he means he doesn't want to use a drop beam. Flush beam would work.
Send me your details on the as-built framing and I will show you how I might (or might not) go about possibly dong something similar to a house I might (or might not) own that is very similar to your framing detail.
If you know what I mean.
And not for free either.
God, I am such a whore.
Andy.
ScipioAfricanus is offline
Old 01-18-2011, 04:35 PM   #12
UpNorth's Avatar
Trade: Engineer & Ret. GC
Let's pretend Brandon introduced himself as having a different profession. Say, a restaurant owner, or an accountant.
What would we be advising him to do?
UpNorth is offline
Old 01-18-2011, 04:44 PM   #13
katoman's Avatar
Trade: carpenter
Hire a licensed carpenter who could then determine if a spec from a structural engineer was required.
katoman is offline
Old 01-18-2011, 04:53 PM   #14
Thom
thom's Avatar
Rewards Points: 4,748
Brandon, you don't know enough to know what you don't know. There are many on this board who would help you if you were in their area. Without including you location in your profile, there is really no way for others to know if they can or cannot help.
thom is offline
Old 01-18-2011, 04:53 PM   #15
I like Green things
WarnerConstInc.'s Avatar
Rewards Points: 3,496
Just pause a lot when you tear stuff out.
Tear out, pause (see if anything falls) then repeat.
Warner Mill Works
Facebook
YouTube
WarnerConstInc. is online now
The Following 2 Users Say Thank You to WarnerConstInc. For This Useful Post:
AustinDB (01-18-2011), dprimc (01-18-2011)
Old 01-18-2011, 05:00 PM   #16
Geometrist
Warren's Avatar
And don't forget to listen for creaks and groans.
Easy Gibson
Warren is offline
Old 01-18-2011, 05:03 PM   #17
I like Green things
oh yeah, those too!!
Warner Mill Works
Facebook
YouTube
Old 01-18-2011, 05:06 PM   #18
Lack Of All Trades
Darwin's Avatar
Trade: Construction & Home Improvement Services
I just opened up a load bearing wall at investment property. It's not really that hard. You must build temporary support for the load. The main thing is to have a good electrician on hand to relocate any receptacles.
I did mine EXACTLY like Tom...
+ YouTube Video
Darwin is offline
The Following User Says Thank You to Darwin For This Useful Post:
aptpupil (01-18-2011)
Old 01-18-2011, 05:37 PM   #19
Gus Dering's Avatar
You woosie.
There is no time for that. Plenty of noise from all the debris falling and the radio blaring away. Not to mention the coughing from all the blown in insulation you are choking down. Maybe a spark from cutting through a lighting circuit or two.
I happen to know for sure that this can be done by the way.
Old 01-18-2011, 06:09 PM   #20
Project Manager
CookeCarpentry's Avatar
Trade: Project Manager
Rewards Points: 2,016
Originally Posted by Gus Dering View Post
You woosie.
That what can be done? You haphazardly cutting thru electric? Or you haphazardly removing a load bearing wall?
Cause I can do both....probably at the same time....
CookeCarpentry is offline
Flush LVL beam, 2x10 joists, bearing wall above, shrinkage UpNorth Framing 20 11-02-2010 09:07 AM
What size steel beam to use for load bearing wall??? brianmvp Construction 16 07-29-2009 05:56 AM
ICF Load bearing ledger fastening CCBuilder Construction 3 12-19-2007 10:18 AM
Weight Limits for Load Bearing Studs... StudioDan Carpentry 8 09-13-2007 10:12 PM
