Go Back   Contractor Talk - Professional Construction and Remodeling Forum > Trade Talk > Carpentry > Framing
Old 09-04-2009, 04:14 PM   #1
New opening in SIPS home
SIPS is pretty much all new to me in general so modifying an existing one is even newer.
I'm looking at putting a new door into a SIPS wall, is this even possible? I would assume there is a way to but curious if anyone has had experience with the right way...
Its just a 3-0/6-8
Thanks
Nine is offline   Reply With Quote
Old 09-04-2009, 04:44 PM   #2
tomstruble's Avatar
Trade: siding
do you know the manufacturer? usually they have a detail
but ordinarily you just cut your R.O. then route the foam for 2x bucks
i would use a couple of beads of spray foam before i set the 2x
screw the 2x thru the sheathing on the outside and to the drywall on the inside
add the wrb, sliding it under the existing one on top
tomstruble is online now   Reply With Quote
Old 09-04-2009, 04:48 PM   #3
Maker of fine kindleing
Gus Dering's Avatar
Trade: cabinet maker
I found this.
HOW ARE WINDOWS AND DOORS INSTALLED IN FOAM CORE PANELS?
Openings for windows and doors are cut and framed in the manufacturing process at the plant. They are located per the approved drawings.
It is from these guys web site. Bet they know the answer.
Good luck
http://sipsteamusa.com/contact.html
Originally Posted by WarnerConstInc. View Post
Gus is right.
Gus Dering is online now   Reply With Quote
Old 09-05-2009, 01:58 PM   #4
Yeah, I would absolutely think this would work fine without loosing any structural value.
Thanks for both your help
Solving the Housing Crisis, this is lengthy but good reading PMI General Discussion 8 03-26-2009 05:17 AM
The House of Tomorrow from the Recession Today NC2X4 General Discussion 11 02-28-2009 05:05 PM
Bad Home Plans Cost US! NC2X4 General Discussion 0 02-28-2009 01:34 AM
Permits pulled at Home depot rbsremodeling Business 9 10-16-2008 01:51 PM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
