Trade: carpentry
Need Some Help Making Arched LVL's????
Ok i need to make my own LvLs that are not a true raduis. custom shaped very close to a true raduis but not true.. they need to measure like a 4x6 beam, 20 feet total lenght,
i was thinking taking 20 foot 2x4's rip them in half planning both sides so i am able to bend them to the arch i need. and glue six of them toghether in a jig . will this work. it is going to be used for a ached roof over a pool house. with 2x6 t&g for sheathing .. any ideas on how to do this??? and make them strong... thankss |
#2 | |
Trade: Framing Contractor
Re: Need Some Help Making Arched LVL's????Quote:
Joe Carola |
Sean
Correct - you definitely need to get an engineer to draw it up
FYI - last time I checked you need a longer board than 20' to make a 20' arch. Depending on the bend / arch you are looking for, you can get a Glulam that's cambered - but it depends on exactly what you are looking for & you didn't give enough info I have seen beams made with 1/4" plywood bent & glued up but as stated above you will need an engineer to help you out with type of wood, glue, other connections, load and how much it will spring back after being released from the form. |
Mod / ArchiBuilder
I agree with Joe, please consult an engineer.
Tulsa's Leader in Outdoor Living Construction | Facebook | Tulsa Pergola Builder | Tulsa Outdoor Kitchens |
yeah, get some help on this one, bending changes the loads it can handle.
Trade: Construction
Perfect responses above...
For my own curiosity, what radius are you looking at bending the beam to? And is this a fakie beam out in front under the eaves that's just for show or is it a load-bearing structural member? Mac |
Trade: carpentry
the beams will be supporting the weight of the roof. the structure is only 14 feet by 20 feet, 14 feet left to right is were the beams will span,
the ridge is only 30 inches above the top plate so its not a very sharp radius. i figured the beams would be 20 feet total length , |
My lumber yard can actually order arched glulams.
As to making your own, if an engineer signs off on the design, you can use 1x4's, and stagger the length.......glued and nailed......how do I know? hundreds of barns were built this way...all those old round tops, look at the wooden frames, and that is what you will see.
Trade: carpentry
is there a benifit to using stagered lengths? if i can use all single lengths is that better, or staggered are stronger???
If you don't do it as a truss,
you'll still have to accommodate for outward thrust/spread.
Up to the engineer that draws the design. If we are talking strictly why, then try to find 22 or 24 foot long 1's free of defect for this.....I suppose you could order finger jointed material, but the old timers simply staggered the laps in the 1x4's.
Does that mean what it sounds
like it means?
Put your location in your profile! (Sorry....it seems there really are dumb questions) Last edited by neolitic; 11-02-2008 at 09:55 AM. |
Trade: Pretty much anything with wood
Instead of using KD lumber I would use douglas fir decking. You can make a jig on the ground or on the side of a building and then glue it up with epoxy. You usually allow for 10% spring back when gluing a curve like that. Probably would be easier to just order an arched lam though.
#14 | |
Trade: Framing
#15 | |
Trade: Remodle and Framing
Have a 1/2" flitch plate made and bolt and glue your lams to it.
| What are people REALLY making doing hurricane work?? | bew102 | Help Wanted or Looking For Work | 7 | 10-16-2008 12:16 PM |
| drilling for elec. cables through LVL's | Magnettica | General Discussion | 10 | 07-25-2008 09:51 PM |
| Pay Scale........ not making what I want | mikeybobo | Business | 21 | 01-29-2008 08:28 PM |
| downspout making formula | stlgutters | Roofing | 11 | 01-08-2008 11:15 PM |
| What should i be making an hour, i feel way underpaid | Little | Excavation & Site Work | 10 | 10-08-2006 10:01 AM |
