Need To Figure Out How Much To Charge For Making An Opening Between Two Rooms
Old 11-03-2008, 10:31 AM   #1
erivas06's Avatar
Trade: remodeler
Question
Hey guys im new to the game and got my first side job. I Need to figure out how much to charge for making an opening between two rooms. The opening will be about door size, i want to either go 32" or 48" so i can use the existing studs and the height will be door height. The opening is going to be between to offices so they can walk back and forth. Also relocate and outlet to the side of it.
so far i got sheetrock i i think around $5 or so and need cheap home depot carpet to fill in the hole between the opening. How much should i charge in labor. i was thinking maybe 4hrs of work at 30hrs seem fair? i guess also mud and paint and sanding.......
erivas06 is offline
Old 11-03-2008, 10:51 AM   #2
I used to think so.......
wallmaxx's Avatar
Re: Need To Figure Out How Much To Charge For Making An Opening Between Two Rooms
Are you serious?
This site is mostly viewed by people who frown on helping someone bid a project over the Internet. That's akin to a blind man teaching someone how to zero a weapon by demonstration. (Okay, sorry to all the blind hunters out there.)
Anyways, bid what you need to make for you. Everyone's costs are different.
I wish I had the time to link to all the threads that start this way and have been answered similarly.
Above all, do a good job.
wallmaxx is online now
Old 11-03-2008, 01:30 PM   #3
Fentoozler
Celtic's Avatar
I think $120 plus $5 in material is an awesome number for this job.
Celtic is offline
Old 11-03-2008, 01:59 PM   #4
orson's Avatar
Trade: Kitchen & Bath
Why don't you just tell the people you're "new to the game" and therefore cannot provide an estimate, but you're willing to do the work at a cut rate of $xx an hour plus materials since you're just doing "side work" and don't have insurance to actually cover them in case you slit your hand to the bone with a carpet knife or some other such calamity that will cost them many thousands of dollars.
orson is offline
Old 11-03-2008, 02:52 PM   #5
rbeck3@ec.rr.co's Avatar
Trade: framer-inside/outside trim- asphault roofing/remoldeling
a door way so they can walk back and forth. That's brilliant, I've never thought of such . Throw in an extra buck three eighty for the door. But besides that you my friend are in business. Good luck , be sure to tell us how it goes.
passingwindII
rbeck3@ec.rr.co is offline
Old 11-03-2008, 04:51 PM   #6
Kaiser's Avatar
Trade: Project Management
For a 32" opening with a strip of carpet $7.32 for a 48" opening with a strip of carpet $8.78.
Moving an Outlet $43,897.02 give or take. Hope that helps
"Go confidently in the direction of your dreams. Live the life you have imagined."
Henry David Thoreau
Kaiser is offline
Old 11-03-2008, 05:30 PM   #7
Proud Plumber
Proud Plumber's Avatar
Trade: Plumbing/Building Contractor
You mentioned your first side job. Might I suggest Craigs List, it is an excellent source for job pricing and it is also a great way for you to mingle and understand your direct competition
Bill
"I'd rather die while I'm living then live while I'm dead".... Jimmy Buffett
Proud Plumber is offline
Old 11-03-2008, 05:51 PM   #8
Look at the link this thread has
brought up (bottom of the page)
http://www.contractortalk.com/f48/does-fireplace-opening-block-wall-opening-need-support-7465/
neolitic is offline
Old 11-03-2008, 06:15 PM   #9
dkillianjr's Avatar
dkillianjr is offline
Old 11-03-2008, 06:23 PM   #10
AtlanticWBConst's Avatar
Hey, I give the guy credit. Ususally they come on here with the title of "General Contractor", or "We do it Right!", and ask such a question.
At least he's honest. I appreciate that. Because of his honesty, I shall through out some bits and tips...
My tip: Simple solution for a newbi rookie doing a smaller job:
1.) Figure out your time. How many days will it take you? Starting out - be fair with your daily pricing (your day's pay, or hourly pay). Be realistic on your time; Include time to pick up materials.
2.) Factor in your materials costs + 20% mark-up.
3.) Factor in all overhead costs: Gas, insurance, etc.
4.) Also - You may need to account for a "fudge factor of 10% on materials for a job like that.
That's a good way to start out, on small jobs. NEVER, EVER pull numbers out of a hat. That is a solid way to get kicked in the arse on your budget.
Pricing a job is about budgeting the job.
Good Luck.
- Build Well -
AtlanticWBConst is offline
Old 11-03-2008, 06:34 PM   #11
I like Green things
WarnerConstInc.'s Avatar
Well, Atlantic was pretty nice, most people usually say a case of beer and a carton of smokes.
If it is 'side work' than it would seem you have done this stuff before?
You should know how long it will take, and how much money you need for the beer, cigs, cherry masters and than the strip club on the way home.
If I had to add all those up, um... I need at least 500.00 just to stop at the strip club!
Good Luck.
that was pretty nice huh?
WarnerConstInc. is online now
Old 11-03-2008, 07:04 PM   #12
Sean
SLSTech's Avatar
Two offices - sounds commercial - license required?
Relocate outlet - Min. Charge for an electrician is generally 4 hrs or are you licensed? So what are you going to do with that wire running throuh the new walkway?
$5 sheetrock - where? I need some - You are looking at 3 trips or using hot mud - even using hot mud you are still looking at a 2 to 3 hours just for this
Cheep Home Depot carpet to fill in the hole? Both offices have the same color & type that you can get at home depot? Glue down or pad
FYI - corner bead & mud first, then sanding, then paint
You might suggest using a regular door with a threshold so that they can walk between offices & still have some privacy. The real reason to suggest this, is to save them from a blatantly obvious hack job as described...
charging 4 hrs @ 30 hrs = WTF are you a lawyer by day?
SLSTech is offline
Old 11-03-2008, 07:17 PM   #13
Dan_Watson's Avatar
I hope this isn't a weight bearing wall....
Dan_Watson is offline
Old 11-03-2008, 07:28 PM   #14
Teetorbilt's Avatar
Always beat me to it, that would be my starting point. Here it would mean the difference between a permit and inspection or not.
Any chance of plumbing or wiring running through the wall?
Albert Einstein
Teetorbilt is offline
Old 11-03-2008, 08:00 PM   #15
Fentoozler
Celtic's Avatar
Originally Posted by Teetorbilt View Post
Any chance of .... wiring running through the wall?
Now why would you think that?
Celtic is offline
Old 11-06-2008, 11:10 AM   #16
bee1706's Avatar
Trade: Remodle and Framing
Ok! I'll give you a clue. If this space has trusses , then you need to cut the opening, if it's office space you nedd an opening of 34" (handicapped) if there are no trusses you need a header.You will never match carpet so you need a wood threshold. Paint will not match so you have to paint 2 rooms, plus trim.Your looking at almost 750 and thats low?
bee1706 is offline
Old 11-07-2008, 08:11 PM   #17
whaler's Avatar
Trade: carpenter
my thoughts exactly.I had help on my first side job many years ago. If a kid comes up and wants to learn and more important listen I'll go out of my way to help him as long as he's not an asshole.
whaler is offline
Old 11-07-2008, 08:49 PM   #18
whaler's Avatar
Trade: carpenter
I tried to Quote AtlanticWBConst in my last post.
whaler is offline
Tags
framing, sheetrock
Does fireplace opening in block wall opening need support? Square-One Masonry 6 11-22-2008 02:31 AM
how much to charge 3ndAhammer Roofing 9 09-16-2008 08:04 AM
What to charge for blue roof? iceman61 Roofing 5 09-16-2008 12:48 AM
Does fireplace opening in block wall opening need support? Square-One Construction 1 02-28-2006 01:59 AM
Somebody sell some Gass Rooms Glasshousebltr Construction 2 03-04-2004 10:46 AM
