Nails/Sheathing
Old 11-02-2008, 10:44 AM   #1
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Nails/Sheathing
We're putting on sheathing at one of our projects using #8 ring shanks with a cordless Paslode. One of the boxes turned out to be smooth shanks.
Considering the friction sensitive glue on these nails, would you still use them or just throw them out? I'd like to send them back and exchange them but they have used a clip or two before it was discovered.
What do you think?
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 11-02-2008, 10:51 AM   #2
Handle It!
MALCO.New.York's Avatar
Re: Nails/Sheathing
So............How many houses do you suppose are built WITHOUT Ring or Glue Shank?????
Use them and sleep easy!
Ultimate Wisdom---------
MALCO.New.York is online now
Old 11-02-2008, 02:09 PM   #3
Project Manager/Carpenter
TBFGhost's Avatar
Trade: Carpentry/Reno
Re: Nails/Sheathing
here is my question...who here uses Clipped head nails for framing? I know some placed don't allow them, but I am curious to see who still does....I am not looking to turn this into a debate about clipped vs FRH, or codes should say this or that...just who uses clipped head....
TBFGhost is offline
Old 11-02-2008, 03:13 PM   #4
topsail's trimcat
woodworkbykirk's Avatar
Re: Nails/Sheathing
clipped head are pretty much all any one uses in my area, ive used full heads only once just recently,
definitely better to have the full head, whats the point of driving a piece of wire into two pieces of wood that isnt gonna hold anything. i mean its scary how if you have to pull something apart and the end of the spike with the epoxy holds in the joined piece where as the end with the clipped head just pulls through your plate
woodworkbykirk is offline
Old 11-02-2008, 03:19 PM   #5
KentWhitten's Avatar
Re: Nails/Sheathing
walls or floor?
Either way, it's perfectly fine to use smooth shank nails for sheathing. I used it for floors for years. No rings for me. It's all in the application.
Some places may require it, like hurricane country.
Salmon Falls Cabinetry
KentWhitten is offline
Old 11-02-2008, 03:22 PM   #6
TBFGhost's Avatar
Re: Nails/Sheathing
LOL, I don't want to get into what is better, I just want to know what is being used.... otherwise this turns into a debate starting with FRH are better, but then it can be argued that clipped head nails provide just as much retention power due the type of forces that are placed on them in real world framing applications....
I just want to know what is using what and where.....
TBFGhost is offline
Old 11-02-2008, 03:29 PM   #7
genecarp's Avatar
Re: Nails/Sheathing
use em
genecarp is offline
Old 11-02-2008, 11:49 PM   #8
Young Gun
HallisseyDesign's Avatar
Trade: Smartass
Re: Nails/Sheathing
use em and I run full round. I have not fired a clipped head in like 4 years.
HallisseyDesign is offline
Old 11-03-2008, 12:44 AM   #9
Vrooman's Avatar
Trade: Builder, renovator
Re: Nails/Sheathing
I have used the Roundrive paslode nails before, I prefer those over clipped head for sure, but for some reason, my supplier only had them in stock for a few weeks.
If I am nailing sheets of OSB with clipped, I will adjust the depth of drive so it drives it flush. So many people let those nails blow 3/4 through the material..where is the holding power
Vrooman is offline
Old 11-06-2008, 12:12 AM   #10
"Your not done yet!!??"
Green Machine's Avatar
Trade: Framming/siding/millwork
Re: Nails/Sheathing
I like using staples as opposed to the 8d ringshanks. Only problem is that in our area, you have to double your nailing schedual on staples. you blow through alot of those things real quick.
Green Machine is offline
Old 11-06-2008, 11:32 AM   #11
bee1706's Avatar
Trade: Remodle and Framing
Re: Nails/Sheathing
I think you might be wrong?Reason being that the smooth shank will give way to expansion the ring shankes will hold?
walls or floor?
bee1706 is offline
