Nail Or Staple Plywood?
Old 11-23-2010, 08:23 AM   #1
bob14-0's Avatar
Trade: home construction
Rewards Points: 75
In the application of securing plywood decking/sheathing, which is preferred - nails or medium crown staple?
I'm seeing some great deals on 7/16" construction staplers, something we used in the day, but it seems most have gone to nails instead of staples.
Does anyone still staple roof and deck sheathing? You guys like the med crown stapler?
thanks, Bob
bob14-0 is offline
Old 11-23-2010, 09:03 AM   #2
Finishing Carpenter
Mrmac204's Avatar
Trade: finishing Carpenter
Rewards Points: 720
Re: Nail Or Staple Plywood?
I believe that a number of years ago the rules changed in my area. No stapling of wall sheathing etc. There may be exceptions to this, I've not done general framing for many years, but every site that I'm on folks are using nailers.
Mrmac204 is offline
Old 11-23-2010, 09:03 AM   #3
tlkropf86's Avatar
Trade: Custom Homes-Remodeler-Steel Erector
Rewards Points: 25
We staple a lot of OSB on roofs in particular, I don't know if they hold any better than nails or not.... It's just something we've done for a long time.
tlkropf86 is offline
Old 11-23-2010, 09:32 AM   #4
Framer53's Avatar
Trade: Handyman
Rewards Points: 320
We don't staple as we don't like to have to carry another tool and staples.
Framer53 is online now
Old 11-23-2010, 09:51 AM   #5
tlkropf86's Avatar
Rewards Points: 25
My main knock against stapling is that if a piece has to be pulled off the staples make a mess of things.
Old 11-23-2010, 03:46 PM   #6
topsail's trimcat
woodworkbykirk's Avatar
Rewards Points: 384
i know guys that do staple around here but they are few and far between, most builders dont trust them, yes they have holding power but no shear strength
woodworkbykirk is offline
Old 11-23-2010, 04:05 PM   #7
UpNorth's Avatar
Trade: Engineer & Ret. GC
Before we blather on too much from the seats of our Carhartts, some facts:
Wood shear walls are the most common element in the lateral force-resisting system of residential construction. Recent developments have made the use of staples, as a sheathing-to-stud connection, much more feasible and practical. Dynamic cyclic tests of wood shear walls using staples as connectors of sheathing to the studs were performed to determine load and displacement capacities. Enhanced details from standard construction were used to improve the performance of the global system including a double sill plate, a new refined panel corner detail, double staples along blocked edges, and backup bolts for hold-downs. At the strength level, the stapled wood shear walls with enhanced details performed above the International Building Code-IBC (ICC 2006) regarding peak load capacity; however, peak drift capacity was 88% of the specified capacity. The test results were used to determine acceptance criteria, which were compared to the ASCE 41-06 Standard for Seismic Rehabilitation of Existing Buildings (ASCE 2007). 2009 Earthquake Engineering Research Institute
UpNorth is offline
Old 11-23-2010, 04:44 PM   #8
Joe Carola's Avatar
Trade: Framing Contractor
Rewards Points: 1,012
thanks, Bob
You have to find out if your allowed first before you make any decisions.
Joe Carola
Joe Carola is offline
Old 11-23-2010, 05:52 PM   #9
Chopper's Avatar
Trade: Framing
Rewards Points: 25
Exactly Joe, code dictates first and foremost.
Chopper is offline
Old 11-23-2010, 05:57 PM   #10
kyle_dmr's Avatar
Rewards Points: 998
Up here, it is rare to see sheeting nailed off. Almost everyone uses staples. Now, in OSB staples are far superior imho, but 3/8 ply a fullhead nail holds better. 1/2" ply is anyones game. All depends on amount shot in. I personally only use staples. Cheaper, easier to carry with me and faster to shoot in. Less air in the compressor being used as well.
kyle_dmr is offline
Old 11-23-2010, 07:42 PM   #11
paradisemike's Avatar
Trade: Residential Contractor/Frame/Trim
Rewards Points: 75
Nails have far more holding strength than staples per University of Miami, Miami/Dade building code. Here we can only use nails, we commonly use 8d or 2 1/2" .131 diameter, and somtimes 2 1/2" galvanized ring shanks, nailed 4-6" on the seams and 8" in the field. We cannot use OSB plywood either. Near the coast we must glue down our first run of plywood. The head of a nail has a greater surface area than a staple, plus I've tried to remove both during demo. I used staples in the Carolinas along with OSB.
Staples are much cheaper of course, so if your building code does not require nails, then use staples.
How much square can a square square square if a square square just ain't square.
paradisemike is offline
Old 11-23-2010, 07:45 PM   #12
AJAX's Avatar
Rewards Points: 150
NAIL.
AJAX is offline
Old 11-23-2010, 07:46 PM   #13
I eat sawdust.
Winchester's Avatar
Trade: Deck Design/Build
Rewards Points: 2,000
Nope, you were correct. Last time I checked you gotta nail. The sheathing is the lateral wall bracing. You could probably staple if you wanted to do lateral bracing of some other kind.
Winchester is offline
Old 11-23-2010, 08:44 PM   #14
contractor king's Avatar
Trade: framing/roofing
I always nail plywood even though staples are cheaper plus its just one more tool to lug around.
contractor king is offline
Old 11-24-2010, 10:10 AM   #15
JT Wood's Avatar
Trade: carpenter
Rewards Points: 2,494
on the roof we use 7/16 osb sheathing with 1 1/2" med crown staples.
Same on the walls. except it's 3/8"
Airdrie AB Renovation Contractor | Kitchen Renovations | Basement Developments | Facebook
JT Wood Construction Serves Airdrie, Cochrane, Olds, Mountainview, Rockyview and Crossfield, Alberta.
JT Wood is offline
Old 11-24-2010, 11:06 AM   #16
UpNorth's Avatar
NY code, actually "New York State Residential Building Code, 2006 Edition," which is current, specifies this for what is commonly used on sidewalls and roofs, namely 7/16 rated OSB and 5/8 rated OSB, respectively:
Sidewalls, 7/16" crown 16 gage staples x 1-3/4", 4" at edges and 8" in field spacing
Roofs, 7/16" crown 16 gage staples x 2", 3" edges and 6" in field.
The nail most used, if staples are not, is a gun-driven 2-3/8" x 0.113 ringshank. Spacing opens up a little if nails are used, but not much.
For sure, the staples are less expensive than the ringshanks. Also for sure, one needs a separate gun for the staples, but the guns are light and easy to use, and keep one from having to unload framing spikes from the nail gun and reload with ringshanks. A 16 gage stapler weighs maybe 5 pounds versus a spike gun at 7.5 pounds to 8, and its mag capacity for 16 gage staples is far more than a spiker has for ringshank 113s.
UpNorth is offline
Old 11-24-2010, 05:16 PM   #17
bob14-0's Avatar
Rewards Points: 75
Not to hijack my original post, but 7/16 inch OSB? You must have 16" o.c. to allow for such a thin sheathing.
On Habitat jobs, at least in Michigan, we use 9/16 minimum 24" o.c., but prefer and often use 5/8" for roof decks. Unfortunately, we are not allowed to have pneumatics on site so we end up pounding 8's anyway!
Bob
bob14-0 is offline
Old 11-24-2010, 07:23 PM   #18
kyle_dmr's Avatar
Rewards Points: 998
Bob
Roof sheeting 7/16 16oc no H clips or 24OC with H clips.
They let 3/8 with H clips fly here on 24OC roof sheeting. I'm scared of it. I've went through a few sheets mid span
kyle_dmr is offline
Old 11-24-2010, 07:42 PM   #19
JT Wood's Avatar
Trade: carpenter
^^^^ What he said ^^^^^
JT Wood is offline
Old 11-24-2010, 08:01 PM   #20
bob14-0's Avatar
Rewards Points: 75
Wow! Okay, I guess to go code-plus doesn't hurt, that is, 9/16 or better. I've always thought 7/16 to be counter-intuitive; it's never felt stout enough to carry snow loads on roof pitch below 5:12 or, a heavy roofer, loaded with tools and dropping bundles between rafters would seem to invite disaster.
Habitat For Humanity has always defaulted, in my experience, to over-kill for fear of under building.
Thanks for the info, fellas. This is a very informative and professional forum - really appreciate it.
Bob
bob14-0 is offline
The Following User Says Thank You to bob14-0 For This Useful Post:
jkfox624 (11-25-2010)
Nail or staple? BCConstruction Flooring 32 01-29-2017 08:31 PM
Bondo on nail heads on new exterior siding? outsidethelines Painting & Finish Work 17 04-17-2014 06:52 PM
The war of plywood VS particle board Jimmy Cabinet Kitchens & Baths 47 09-18-2012 07:52 AM
Plywood vs particle board CarrPainting Roofing 27 07-14-2010 11:14 AM
OSB vs. CDX FRAMERBEN Framing 51 10-16-2008 06:57 PM
