Metal Studs For Furring Basement Ceiling
Old 12-28-2007, 04:27 PM   #1
erramoss's Avatar
Trade: architect
Hello,
I'm working on a basement that previously had a dropped ceiling because all plumbing was run on the underside of the floor joists. I'm putting in a drywall ceiling but I need to furr out the joists at least 3" to clear all plumbing. Is it acceptable to to attach 3 5/8” metal studs to the wooden floor joists and hang the drywall from these studs? I realize that I’ll have to add blocking between the rows of studs to keep them plumb, but I was just wondering if this method has been done by anyone here and been successful?
Thank You
erramoss is offline
Old 12-28-2007, 05:20 PM   #2
Restoration Crazy
Jason Whipple's Avatar
Trade: Restoration & Historic Preservation
Send a message via Skype™ to Jason Whipple
Re: Metal Studs For Furring Basement Ceiling
Originally Posted by erramoss View Post
Hello,
Thank You
It sure wouldn't be my first choice. I'm surprised that someone who has "Architect" under your trade would ask such a question.
Jason E Whipple, General Manager
Historic House Restoration, Cincinnati, Ohio
Facebook | Twitter
Jason Whipple is offline
Old 12-28-2007, 05:23 PM   #3
erramoss's Avatar
Trade: architect
Let me edit my response. First off, that wasn't helpful at all. Secondly, I'm proposing this method because I have several bundles of metal studs sitting in my garage and this seems to be the best opportunity to use them. I understand that this isn't the 'best' method for this scenario, but it's what I've got to deal with. The 3" depth is too deep for any furring channels, so if anyone has had to furr out with metal studs, any tips or problems that you ran into would help. I'm looking for feedback, not smug responses.
erramoss is offline
Old 12-28-2007, 05:48 PM   #4
Restoration Crazy
http://www.armstrong.com/commclgeu/e...amilyNameId=24
Facebook | Twitter
Old 12-28-2007, 06:01 PM   #5
erramoss's Avatar
Trade: architect
I appreciate the information, but from the looks of that product, it's still pretty similar to the acoustic tile grid system that I'm trying to get rid of. Unless I'm missing something on that product it only shows panels being installed in the grid system.
erramoss is offline
Old 12-28-2007, 06:07 PM   #6
Restoration Crazy
It's made to screw drywall to, not to set it in.
Facebook | Twitter
Old 12-28-2007, 06:08 PM   #7
RLGC's Avatar
Trade: General contracting
Sounds really cheesy. I hope this is not reflective of your architectual skills.
RLGC is offline
Old 12-28-2007, 06:08 PM   #8
Priced In
JustaFramer's Avatar
Trade: Exiled For Life
Why couldn't you use steel stud. Depending on the gauge they are used in drop ceiling all the time.
JustaFramer is offline
Old 12-28-2007, 06:08 PM   #9
erramoss's Avatar
Trade: architect
I'll look into that, I appreciate the information.
erramoss is offline
Old 12-28-2007, 06:11 PM   #10
erramoss's Avatar
Trade: architect
I know that I've seen similar framing techniques done using studs instead of channels. The fact that it's "cheesy" or not is irrelevant. Thank you to the two of you that provided helpful feedback and suggestions.
erramoss is offline
Old 12-28-2007, 06:18 PM   #11
Restoration Crazy
The suspension system will allow you to hang a perfectly level ceiling without dealing with the underside of floor joists with varying thicknesses. You'll spend a lot of time shimming the other way.
But I saw your edit and you can use the left overs if you want, but like I said before YOUR smug response and edit. It wouldn't be my first choice.
Facebook | Twitter
Old 12-28-2007, 06:21 PM   #12
erramoss's Avatar
Trade: architect
Yes, the method with the studs will definitely have its drawbacks, that being maintaining a level ceiling and dealing with the twist of the studs when they are fastened to the joists, but with shimming and cross blocking, I can deal with those drawbacks. Trust me, it's not my first choice either, but it's a cost issue more than anything.
erramoss is offline
Old 12-28-2007, 06:27 PM   #13
Restoration Crazy
The real cost of doing work you aren't trained to do is more than you know or are willing to admit.
If your not a framer and a sheet rocker you should let the pro's do it the way they choose to or don't do it at all. I can't tell you how many houses I walk into each year were the H/O has done the work themselves and it shows.
There is no value added when the job is done less than professionally.
Good Luck
Facebook | Twitter
Old 12-28-2007, 06:37 PM   #14
Restoration Crazy
I have to wonder why you would close off access to all those shut of valves for plumbing and most likely junction boxes that by code (any were) need to be accessible.
I'm sure as an Architect you have had all this moved to another location that is accessible, right?
Edit: At the least, you need to provide access doors in all of these locations.
Facebook | Twitter
Old 12-28-2007, 07:02 PM   #15
Priced In
I find nothing cheesy about firring with steel stud/joists. If you are worried about irregulatities then use some burke shims and set a elevation.
And don't go covering up shut offs.
Old 12-28-2007, 07:09 PM   #16
mickeyco's Avatar
Trade: Squirrel Handler
mickeyco is offline
Old 12-28-2007, 07:22 PM   #17
Restoration Crazy
Please tell me you tied those studs to the ceiling with wire or something.
Facebook | Twitter
Old 12-28-2007, 07:47 PM   #18
Pavola's Avatar
It's a floating ceiling system.
Pavola is offline
Old 12-28-2007, 08:06 PM   #19
Pavola's Avatar
What's cheesy about it? Same principle as using the ceiling grid systems mentioned above. You could install these studs with the same installation guides that come with those. Good use of material laying around IMO.
Pavola is offline
Old 12-28-2007, 08:40 PM   #20
Old School Marine
randomkiller's Avatar
Trade: Union Journeyman Electrician
The grid system is made to support the weight of 1/2" rock, the steel studs are not meant to support weight in that position, unless they are like a minimum of heavier than 24ga. Seeing those light gauge studs with the waffle pattern, it looks like a hack job.
"If we ever forget that we're One Nation Under God, then we will be a nation gone under." Ronald Reagan
randomkiller is offline
Framing with metal studs Rich Construction 39 12-16-2010 10:53 PM
Baseboard to Metal Studs? MHMConstruction Remodeling 17 06-03-2007 12:06 PM
Metal Studs Vs. Wood Studs Towatei & Co. Drywall 7 05-12-2007 11:03 PM
metal studs drywaller56 Carpentry 2 03-08-2006 08:12 AM
