Trade: builder
Metal Shims
Last week I did a home repair for a customer trying to sell their house built in the 1980's. The inspector had discovered some tapered shims used to support several girders and floor joists. The inspector required the fix to be done with metal shims not ripped wood material. We went to Lowes and bought several thicknesses of metal stock and did the repair. Obviously, the tapered shims were a no-no but have you ever had this type of fix required? Just the material cost the customer almost $100.
Re: Metal Shims
Always use metal for the permanent
shims. If they get so thick that you are building stacks, shim up a column base plate and fill under it with non-shrink grout.
A big wannabe
Trade: Framing, decks, trim, Remodels, ground up.
Re: Metal Shims
A hundred buck's worth of flat stock steel (1/8" and 1/4") at a metal yard should last for at least a couple houses!!! We usually cut them up into 1" to 3" strips, spray a little primer on them, and keep them in a bucket.
Trade: SE Carpenter
Re: Metal Shims
There is a black plastic shim made for concrete work you can buy that is rated at 50,000 psi (i beleive). Ive used 1/16, 1/8, 1/4 " They may come in other sizes. We have used thousands of them in wood buildings as tall as 5 floors. The struc engineer loves them.
We get them from a company called form services out of Baltimore. |
#5 | |
Trade: framing
Re: Metal ShimsQuote:
Trade: SE Carpenter
Re: Metal Shims
http://www.formservices.com/ they are about 2"x4" come in strips 12"x4" and snap apart.
| Metal framing for basement and drop cieling | joliet_man | Framing | 8 | 10-31-2008 06:40 PM |
| Metal roofing Help | The Boys | Roofing | 9 | 08-22-2008 09:28 PM |
| Metal Framing Help | gambinos1983 | Framing | 7 | 04-06-2008 08:01 PM |
| metal cold roof question ..... | Vermonster | Roofing | 30 | 09-06-2007 01:30 AM |
