Smart phone? Scan me!
Trade: Painting/Framing/Drywall
Medic!!! Nailer Down.. Nailer Down!!! Seems like for the last year or so I load a new coil and the first or second nail out of the new coil jams up. Usually I just hold back on the safety and let it fire out the double nails sittin in the barrel. Well today's was a bit different. The head came off of one and jammed the hammer in the out position about 1/4" from the end. It is stuck. I can JUST make out part of the head and the shaft is tucked into the opposite wall. I took the front of the gun off, after taking the back off and finding I couldn't do anything with it like that so it is easier to work on at least. What do do oh great guru's of the building world?!
Moderator
Re: Medic!!! Nailer Down.. Nailer Down!!!
Get a bigger hammer?
![]() I think it's gonna need some professional attention. Its probably had a bent part for a long time and now its just so worn it need some real TLC. Take it to the nail gun doctor and make sure he gives you a sucker. Even if you cry when you get the bill.
Re: Medic!!! Nailer Down.. Nailer Down!!! Looking at the plunger end of the shaft, it looks quite delicate. I bet they have some nifty plunger popper that we don't |
sOkay just fixt it. I took a mini roller frame and took the whole unit and basically reverse tamped the piston out. Everything is fine, no mushrooming of the pistion, all straight and I guess I shoulda did this before I took it all apart.. oh well.
Trade: Exteriors
If you get a jamb just use a small nail set to hit the drive pin back in
I do it all the time and works great |
Trailer park boy
I use a 3" nail turned backwards so the head is on the drive pin.
"Industry without art is brutality"
#7 | |
Re: Medic!!! Nailer Down.. Nailer Down!!!Quote:
flat screw driver or a mini pry-bar work too. |
while framing the repair guy who came to our sites would tell me that the ends of the piston or pin or whatever you call it would mushroom if the wrong thing was used. That is what got me paranoid about what to use. For my siding nailer those are $120.00 online
no thank you
#9 | |
Trailer park boy
He wants to be the one to do it and make some bucks from you.
| The Following User Says Thank You to shanekw1 For This Useful Post: | nEighter (08-06-2009) |
#10 | |
The fookin' thing will not mushroom. And $120??? It better come with some bling for that price! When your gun jams like this, and I know this for a fact since it's happened a few times to me, EVEN WITH THE AIRLINE UNHOOKED, YOUR GUN CAN STILL CONTAIN COMPRESSED AIR AND IF YOU'RE LOOKING AT THE END POUNDING ON IT, THERE IS A POSSIBILITY IT WILL SHOOT YOUR FACE!!!!!! If the drive pin does not drive down all the way down, it may not release the air inside. Extreme caution.......EXTREME!
Framerman.. hey what could be causing the damn thing to load 2 nails the first or second nail of every coil?
Trade: Log Home Construction/College Student
Bent wire welds not letting the coil feed right? I had a guy he would walk right over brand new coils then b***h with the gun would feed right. I love my Max coil framer but the coils need to be in pretty good shape when you load them in.
Trade: Exteriors
it is usually bad wire from what i have seen
but sometimes it is the feed o-ring that lets go the head will not mushroom it is tempered I have both Bostich and Hitatchi guns I think I might replaced 2 heads in 10 years on about a dozen guns and yes they go for between 90 and 120 if I remember correctly |
thanks for the feedback, I get the coils straight from the box.. I dunno maybe I twist em up putting them in.
I don't know much about coil nailers. The feeder part I always seemed to have troubles with. It could be the little grabber claws are worn maybe?
| coil framing nailer??? | johndel1971 | Tools & Equipment | 22 | 03-22-2009 11:00 AM |
| makita an901 nailer | johndel1971 | Tools & Equipment | 2 | 03-11-2009 06:38 PM |
| Senco 41XP finish nailer | maninthesea | Tools & Equipment | 9 | 02-26-2009 01:48 PM |
| Paslode 16 gauge Straight Finish Nailer For Sale | JPV123 | Contractor Swap | 0 | 02-22-2009 06:56 PM |
| Nailer question | Static Design | Flooring | 2 | 01-29-2009 10:57 PM |
