Low Slope Framing
Old 03-14-2005, 06:20 PM   #1
pratok69's Avatar
Low Slope Framing
hi guys, new here. like what i see so far. i have a cape cod w/ a gable roof now. i want to add approx. 8 ft to the back exterior wall and raise the roof to almost a flat pitch. its 9'-6" to top of ridge. 24' run front to back. or 12' from ridge to exterior wall. here in prairie village, kansas they use 2000 IBC and IRC. any pointers on what i need for a rafter to cary load. do i need rafter legs? as for the ridge i would like to span as far as is reasonable. how far will a LVL span between ridge legs.?
pratok69 is offline
Old 03-17-2005, 08:02 PM   #2
pratok69's Avatar
Re: Low Slope Framing
ANYONE, ANYONE ?? im looking for the code requirements on a near flat pitch roof (1/12 or 2/12) can i span from ridge to wall with 2 x 8 or 2 x 10 with no rafter leg ? what should i consider when going from gable to flat. currently the gable is framed with 2x4 rafters on 2' centers. do i need to match this layout on the opposite side? i would prefer 16" on center.
pratok69 is offline
Old 03-17-2005, 09:13 PM   #3
smartazz contractor
mtp's Avatar
Trade: commercial interiors
Try having a chat with your local building inspector
mtp is offline
Old 03-17-2005, 09:52 PM   #4
Teetorbilt's Avatar
theparrot is short but correct. Codes vary widely, you need to find out what yours are.
Teetorbilt is offline
Window header 2x6 framing Atlantex Framing 20 11-06-2007 10:55 PM
steep slope grading rccon Excavation & Site Work 19 08-12-2007 10:26 PM
Framing Roof Joists for Addition when top Plate is not Level personalt Framing 3 07-20-2007 06:52 AM
What type of slope can mini track loaders handle??? MC Excavating Excavation & Site Work 26 08-05-2006 09:09 PM
