Log Cabin Addition
Old 02-27-2009, 09:41 PM   #1
KemoSabe
loneframer's Avatar
Rewards Points: 12,202
Log Cabin Addition
This was a neat project. The addition was set on steel columns to allow access to the cellar door which is nested between two terraced walls.The roof framing is 4x10 roughsawn cedar. A 3/4" dado was plowed 3" down from top to allow for 2" ridgid foam insulation and 1" air space under plywood. Dado received cedar 1x6 T&G v-groove planks. Siding was custom milled to simulate board and batton. Logs were channeled out to receive 2x6 wall framing and eventually were cut away to allow access to room. Framed, roofed, sided and trimmed this one and did foundation piers/ columns which were eventually boxed in by homeowner.
loneframer is offline
Old 02-27-2009, 09:46 PM   #2
Maker of fine kindling
Gus Dering's Avatar
Trade: cabinet maker
Rewards Points: 12,490
Re: Log Cabin Addition
That would have looked really cool with a couple girder logs holding up the floor system.
Have you ever worked with logs?
Gus Dering is offline
Old 02-27-2009, 10:08 PM   #3
KemoSabe
loneframer's Avatar
Never had the oportunity, although I grew up with a guy whos father built Ward log cabins. Never hooked up though. This was another scenario of homeowner design. I can't recall ever looking at a drawing. It was permitted for sure 'cause we had a pier footing inspection.Wasn't around for the others though.
Old 02-28-2009, 04:19 PM   #4
reveivl's Avatar
Trade: Renovations
Rewards Points: 1,000
How did you deal with the movement issue where the framing abuts against the logs?
reveivl is offline
The Following User Says Thank You to reveivl For This Useful Post:
Gus Dering (02-28-2009)
Old 02-28-2009, 05:24 PM   #5
KemoSabe
loneframer's Avatar
All the logs were hewn flat with a chainsaw, chisels, etc.Foam sill sealer was applied to reduce drafts, then abutting framing members were lag screwed to logs at approx. 16" centers. The existing cabin was around 20 years old and had pretty much stabilized. Addition floor framing was 12" TJIs with web packing at connecting point at cabin. Counter flashing was let into logs at about a 10 degree bevel and bytyl rubber sealant was used to embed. The interior photo was taken a couple years after completion when I was asked back to estimate a shed dormer on the front of the cabin, but ho health issues prevented the project. No apparent issues with movement and no complaints.
Old 02-28-2009, 06:03 PM   #6
Gus Dering's Avatar
Don't shy away from a hybrid job if you get the chance. I think you would love doing stuff like this.
Once you get your mind to think center line of log, as opposed to striking lines on the edge of dimensional lumber, working with logs is really fun.
Since you love pictures here is a few.
Have you ever read a book without the pop up pictures?
Log cabin addition-windham-kitchen-006.jpgAttachment 16061
Old 02-28-2009, 06:18 PM   #7
KemoSabe
loneframer's Avatar
Cool stuff Gus, I would jump at the chance to do a log job, heck, it is an excuse to tool up right?
As far as popup books, they are still far and away my favorite. I'm thinking about trying to get a framing techniques book deal, just working out the bugs now. How to get a 128th scale balsa wood structure to fold flat for example.
Wiring Addition jaymay75 NEC Discussion 18 07-24-2009 08:13 PM
My House - Ideas for addition BHR Carpentry 29 03-02-2009 11:12 AM
Need Help w/ a Bathroom, closet, and laundry layout in addition TurnkeyConst Remodeling 8 12-15-2008 11:50 PM
Winterizing a cabin Kevin75 Plumbing 1 11-24-2008 08:39 PM
Heating system suggestions for a cabin in UP MI. Flying Monkey HVAC 5 08-22-2007 10:40 AM
